DIY installation of AVIC & other aftermarket HU's for W203 (Warning! lots of images!)
#876
![Smile](https://mbworld.org/forums/images/icons/icon7.gif)
hi guys im having a serious issue. I just had a Pioneer F90BT installed along with speakers and amp. I also used the Pioneer Car.Pi.i.133 steering wheel adapter. I sorted out the issue with the radio reception, but for whatever reason i lost complete control of the heater/defrost/etc beneath the HU. the light will come on, on the buttons but i dont get any heat or defrost or anything. Now my installer is telling me hes tried everything and im gonna have to take it to the mercedes stealership....anyone have experience with this issue??
#878
its there at the install place right now they told me they double checked everything and im gonna have to take it t o the dealership, which is gonna take at least a month for me to even get them to look at it..ahhh jeez this is not good
#880
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
#881
I was wondering if anyone could help me with my Z1 install.
I have a 2002 C240 with a build date of 09/01. I purchased the Metra harness 70-9401 but for some reason the Z1 is not powering on. It looks like the pins for the harness do not correctly lineup with the cars plug.
Does anyone know of there is another harness that I should be using or what color wire the ground, constant, switched, dimmer, and power antenna are?
#882
02 cl203
^ i am having the same problem, pull out the plug and move them to the correct position. Mine current only works if all power and acc line is wired to one line, which i think is acc, since it stays on when car is off. Any one have the wire diagram for the stock radio.
grim any luck with the reception, my sucks also.
#886
02 cl203
so no luck on bypassing my unit but i did fix the power issue and the radio reception.
I did have to run the acc wire to the cigarette light so i also used the illumination from there.
Radio reception was due to the crappy extension wire from pioneer, I twisted the wire by their control unit and it got better but then moved back.
#887
C230 coupe, 335i
http://www.avic411.com/forum/
That's where I learned how to bypass my f-series.
#889
Kenwood DNX-8120??
Whats up guys,
I just read the last half of this thread, but didn't find what i was looking for. I'm most likely gonna get the Kenwood 8120. I want to hook this up to the steering controls. Ive seen the Pioneer with controls, but has anyone done this with the Kenwood?? If you have, can you post pics and part numbers for the steering contols. I went to 2 different stereo shops and they both told me i need 2 modules for this to work. For those that have have the 8120, what do you think of it?? ive only heard good things from my friends that have it... Thanks!!
#890
1996 MB E320 & 2010 Nissan Elgrand
Whats up guys,
One thing I like about 8120, it has a built in audio processor for DTS 5.1, Dolby ETC. Others: higher resolution, built-in GPS and bluetooth and higher power output.
#891
I was going to get the 8120 before nd I was told you can hook it up to the steering wheel. YES, you need modules, can't remember the code, pretty straight forward if you look for them,
i need to find those part numbers though so i can just buy everything and take it to my installer... ive pretty much searched everywhere and i think i found 1, the pac one, but the stereo shops told me i need 2 modules??? i dont think they're gonna tell me what they are unless i buy it from them... ill search some more...
#892
did you end up getting the 8120?? if not what did you get? Yeah its a good HU, pretty much has everything you need without any add-ons..
I'm sure some members know what modules you need, try to post in Audio section. I remember I needed to get 2 modules for my Alpine, but I didn't do it and it's been fine for me as long I have the remote.
I tried to search for the modules in my local shop's website and the modules aren't there anymore, used to be in their website.
GL
#894
02 cl203
^ mine is the antenna cable provided with the radio, if i jiggle it the reception gets better but when driving kinda hard so i try to listen to my phone instead
#895
#896
For those of you having problems with the am and fm reception I figured it out and solve the problem by connecting the antenna control on the avic harness to the blue and white stripe of the metra harness for our car. Fm now has a great reception.
#897
08 E63
The blue and white wire is the remote turn on for after market amplifiers i recommend to switch it to the solid blue which is the power antenna wire. (but if you don't plan on adding after market amps leave it alone)
#898
I was refering to the metra harness for our car and not the avic harness. If I remember correctly there is only one blu and white wire in the metra harness.
#899
2005 C240 4Matic
Ok I am lost and maybe it is me but I have a Pioneer D3 with rear view, ipod cable and bluetooth module. Thanks to this thread I was able to locate the SCOSCHE MZ2347 and appear to fit just right. Question, what else do I need to get this to work? Steering wheel controls would be nice but not as important as NAV… this is going into a W203 05 with H/K system.
Side note; am replacing speakers with Infinity reference components and a pair of JL audio subs with a 5 channel amp.
All I need to know if there is any wire harness that I must get!!!!
Thanks guys !!!
Thanks guys !!!
#900
Does anyone know if the pac audio SWI-CAN/SWI-PS will work on the 2005 c230 for steering control? It shows on the website it will work for 2002 and 2004. Are they different in the wiring harness?
