DIY installation of AVIC & other aftermarket HU's for W203 (Warning! lots of images!)
#826
White 2005 C240
So what I am "hearing" is that the FM antenna needs power but you can only get it by hooking up 12Vs to the black wire off the FAKRA connector, not the wire from the anntenna adapter itself. The antenna adapter wire doesn't need power to make it work.
#828
White 2005 C240
gotcha, I'll let you know. I plan on doing mine within the next week or two and I have the VW adapter
so maybe the stock HU gives the antenna power when you turn on the FM radio! Has anyone ever asked or found out why the VW adapter is powered, or is it just an adaptation from another vehicle that fits the MB and is cheaper?
#831
C230 Kompressor Sport Sedan
iphone integration (ipod hookup and bluetooth for phone part)
steering wheel controls
navigation
ability to customize
I'm looking at a budget of about $1,200 for the whole project which is over priced since you can find the HU for ~$600 online with google.
#832
Hey guys, I'm new to the Forum and kinda new to the MB ownership. I found this... http://cgi.ebay.com/ebaymotors/Merce...fAudioQ5fVideo
and I was wondering if anyone knows if it is a direct replacement for the unit in my 05 C230? I don't have Nav but I want it.
Thnaks,
Brett
Thnaks,
Brett
#833
2008 c350 SG - 2004 c240 Wagon BS
Thnaks,
Brett
Thnaks,
Brett
Good price though.
#835
05 C230K Coupe
i dunno if this is inappropriate to ask but Im in the Vancouver area, i have an 05 c230 coupe, and I would love to get this Pioneer F90BT installed in my car as well as a speaker upgrade. Does anyone know where I can get this install done if I supply all the equipment? Im willing to drive a bit (washington) if necessary.... pm me if you think its better
#836
wow i was thinking about the new pioneer but i'll stay with my Avic D3. after all that trouble installing the steering and ipod controller lol
The D3 will do just fine lol
#837
1 Post
'10 E63 Obsidiant Black; '06 R350 Alabaster White; 05 C55 Obsidiant Black (sold)
Just finished installing an F90BT onto my '05 C55 with H/K system, it took me more than 8 hours!! (Of course this is my first car stereo job)
I wanted to write a DIY guide but the installation alone was too much for me, plus my camera is with my girlfriend so i couldn't take any pictures. However if anybody has any questions, I'm more than happy to share my thoughts.
BTW, The Scosche adapter worked fine on my car.
#838
White 2005 C240
Yeah, I just got through installing mine in my 05 C240 and let me tell you I was disappointed with how things went, not my first install but my most intricate one. I plan on doing a writeup as well, I took pictures. This week I will put it all together and write up my experience. I main problem was with the wiring adapters. I bought the VW style and it doesn't match for some of the critical wires. I ended up wiring things to my cigarette lighter wires. I am still getting a weak radio signal, I know several people have had this problem. I will be working it out this week. I also have the powered VW antenna adapter. Let me know which wiring adapters you bought.
My install included a GPS antenna system, a backup camera , and the HU unit.
#839
I just purchased an Eclipse avn 5435, and the dash kit/wiring harness:
http://cgi.ebay.com/ws/eBayISAPI.dll...m=230159549227
Im installing this in my 2006 c230, will this be an easy job? How hard will it be to wire up with this harness?
#840
White 2005 C240
That's the kit I bought, well the one he offers for the C class . Like I said I'm not happy with it. The power wires are messed up, well at least for my car, 05 C240. The yellow main power is constant 12V no matter if the car is on or off ,so it will drain the battery and leave the radio on 24/7. The illumination wire doesn't have power at all. The ACC wire only puts about 8V when car is off, not sure if that is enough for my radio to keep the memory good, i'll find out soon.
So basically you have to find a switched power source, I used the cigarette lighter, but there are two power wires on it. One is for night time cigarette lighter light, which is what I used for my radio illumination, and one is a switched 12V, I used it for main power. I believe the harness is the cause to why the radio FM signal is weak or maybe the antenna adapter is wrong. I'll figure that out too.
#841
1 Post
Hey Grim-
Connect your yellow wire out from the HU to the red wire on the metra harness, and the red one from HU to the yellow one from the harness.
Read the option B in the link-
https://mbworld.org/forums/3164961-post777.html
#842
White 2005 C240
But the red wire has voltage after the car is off, don't want to drain my battery...please explain. Iread that but I thought it was on older setups, i'll look at it again. ANy idea about the illumination wire, why it doesn't work?
#845
08 E63
The yellow wire on any after market radio has to be constant 12V to keep memory, it will not drain your battery as long as you leave the red ACC wire connected to the cigarette lighter plug for ignition. leave the illumination wire as is it will work fine with no problems.
this is the antenna adapter i used in mine which seems to work fine. http://www.installer.com/item/displa...php?it=40-eu10
#846
White 2005 C240
Not sure if I am happy with the wiring adapter ,when I get it all straight I'll know more.
jreC230 I think I may order that one an see how it does for me.
Does anyone know why there are two antenna jacks on the back of the stock radio, which is better to hook up to a custom HU (yellow or black)?
#848
White 2005 C240
I will have mine all solved today so I can give you all the info you need, since you have an06 it should be the same as mine. Except for the antenna, I ordered the passive adapter because I can't get the powered one to work well (yet)
#849
C230 coupe, 335i
That's for the 2005 and up "new style" radio. 2002 to 2004 sedans and coupes have a different adapter, like the one linked below.
http://cgi.ebay.com/ebaymotors/Merce...22010011r15825
But I already bought the wire harness and antenna adapter locally, and for me 02 without bose, everything except for bypassing was pretty much plug and play(color matched the wires) to the F-series. Everything works great, AM, FM, etc. I am using BHA1784 and BAA7 from this link
http://www.bestkits.com/SearchResult...001%20-%202004
#850
1 Post
Alright I got one question, for the 05+ with H/K systems, are the 2 speakers in each doors (both front and rear) wired in parallel or in series? If they're in series, does that means the load is 4 ohms for each set ? ( I read somewhere in this forum that its 2 ohms each speakers for the H/K system)
Reason I'm asking this is that my HU reboots itself whenever a higher bass kicks in. I need to figure out what did I do wrong.
