DIY installation of AVIC & other aftermarket HU's for W203 (Warning! lots of images!)
Old Sep 28, 2009 | 04:04 PM
  #926
jcnash's Avatar
2002 Mercedes Benz C230 Coupe
Just finished an install of an AVIC F-700BT with XM. Had some issues where I coudln get any power through the harness, so i had to tap into the cigarette lighter lead for power and illumination, but pretty straightforward other than that. Works great.
I also have some experience with the electronics inside the AVIC units, so if you guys have any questions on how to repair your AVIC's, holler at me.
Thanks for the great write ups/DIY's.
Old Sep 28, 2009 | 10:31 PM
  #927
WaveyKat's Avatar
Something Slow
are you getting good Fm/AM Reception with that Unit?
Old Sep 28, 2009 | 10:35 PM
  #928
jcnash's Avatar
My FM reception has definitely reduced from the OEM HU, but its not too bad.
I just connected the antenna directly into the plug on the AVIC using the adapter.
Old Sep 29, 2009 | 07:22 PM
  #929
IllusionX's Avatar
2006 C230 6spd > C300 4Matic
I just picked up a 2006 C230, I'm not sure if I have the Bose/HK system. I did go to a local shop and they told me the same thing, that the whole car would have to be rewired. I have a F90BT that I took out of my old car that I'd really like to put in. Ive been doing research and what not, I used that site listed earlier in the thread http://old.mbclub.ru/mb/faq/?lng=eng but I'm not sure still. How would I go about checking?
Old Sep 29, 2009 | 07:29 PM
  #930
maverik259's Avatar
05 C230K SS (sold), 06 C55 (sold), 08 Yamaha R1 (sold), 16 X5M
it'll say h/k on your speakers somewhere...if it doesn't then you dont have it...also you would have the ability to adjust an equalizer in your settings on the h/u...again if you can't then youd ont have h/k...if you dont have h/k then you DO NOT have to rewire your care!
Old Sep 29, 2009 | 08:52 PM
  #931
ROLLNNN's Avatar
2005 CLK320 Vert & 2005 CLK55 AMG
Anyone know if i can watch TV in my car?? i have the Kenwood DNX8120. Can i just hook up a digital tv tuner and get reception??
Old Sep 29, 2009 | 10:16 PM
  #932
TxBenz08's Avatar
2002 C240
Initially I had weak FM reception, but I figured out I was plugged into the wrong antenna. My stock HU had two antenna type wires, a mini plug (white in color) and a flat type plug (Black in color). I used a non powered 40-VW10 antenna adapter. Now my FM reception is just as good as the stock HU.
Old Sep 29, 2009 | 11:07 PM
  #933
IllusionX's Avatar
cool, thanks. I just have to pick up a new gps antenna, I have the vw harness, euro adapter and dash kit, I just need to call zurich and make sure if a local shop does it it won't void my warranty.
another stupid question is why does the car yell at me whenever I turn my lights on saying a left substitute bulb is on? what does that even mean lol, I'm used to jap cars, this is so fancy.
Old Sep 29, 2009 | 11:12 PM
  #934
jcnash's Avatar
I used a very similar adapter. The one I used doesn't have a wire running from one end to the other. Its just a plug on one end and a female jack on the other for the antenna. I plugged in the flat black plug to the adapter.
Anyone know what the other small, round antenna type plug is?
Old Sep 29, 2009 | 11:14 PM
  #935
jcnash's Avatar
Thats just a warning that your lights are on when you pull the key from the car, unless were talking about two different messages!?!? Switch it to AUTO mode and remove the key. the beeping should stop.
Old Sep 29, 2009 | 11:45 PM
  #936
maverik259's Avatar
i think your thinking of 2 different messages...thats not a "left substitute bulb" and I have no idea what that is...google it or something
Old Sep 30, 2009 | 08:28 AM
  #937
WaveyKat's Avatar
Something Slow
Two Antenna hmm. never heard of this! my car has the Regular Black Euro Antenna had to get the 40-VW10 adapter but Reception still SUCK.. i disconnected the Factory Antenna and connect a Metra Amplified Antenna and the reception is better.
Old Oct 4, 2009 | 07:10 PM
  #938
IllusionX's Avatar
I'm going to have to take a picture and post it. I tried changing the bulbs, I went on sylvanias site, bought those and they didn't fit. More confused? Gimme a bit and I'll post back. I'm going to be doing either clear or smoked side markers, any recommendations?
Old Oct 4, 2009 | 08:10 PM
  #939
samaritrey's Avatar
Super Moderator
THE C350
lol this is really funny. it means that your running light i assume is burned out and that the car has substituted another light so that you still have a working light. so you should have a bulb out warning in the messages section of the ic it will tell you what bulb is out then replace it and you will be good to go. and i am almost 100% sure it telly you about that in the owners manual . good luck sounds like you might need it.
Old Oct 4, 2009 | 08:13 PM
  #940
samaritrey's Avatar
Super Moderator
THE C350
5007 Tail light
7506 stop light
7528 Rear side marker
do what i do go buy every bulb need for your car so that way you always have the bulb you need. what is it like $10 and you will never have to drive light less.
Old Oct 4, 2009 | 11:44 PM
  #941
maverik259's Avatar
why are we talking about bulbs in an avic thread?
Old Oct 5, 2009 | 11:23 AM
  #942
jcnash's Avatar
Agreed!
IllusionX,
Search for an existing thread on bulbs, and post your question there, or start a new one if you dont find it, and post some pics of the message.
Old Oct 10, 2009 | 09:20 PM
  #943
WaveyKat's Avatar
Something Slow
Regarding FM Reception to Those With Aftermarket Head unit... this should Help!
File Type: pdf
Old Oct 10, 2009 | 10:32 PM
  #944
jcnash's Avatar
Thanks WaveyKat.
Ive seen this doc before. However, even after connecting the same wire that plugs into the radio antenna jack on the OEM HU into the Avic's radio antenna jack with the adapter, the FM Reception is still *****.
It could be a problem with the adapter....which is causing signal loss.
Old Nov 10, 2009 | 06:31 PM
  #945
LUKA_CRO's Avatar
w203 Coupe
Originally Posted by fanito
Ok, thanks to all for your patience, moderators, you can merge the other thread with this one. I would like this post to be the first one so people don't have to dig around the thread. Maybe this could be "sticky worth it"
First of all, a disclaimer: Use your best judgement. I am not responsible for what you do or don't do. Sometimes depending where you live using the navigation system is prohibited while in motion. These instructions are only for informative purposes and what works for some might not work for others. Needles to say I am not responsible if your equipment breaks or fails. It worked for me the way I explained it. For any installation if you feel uncapable of doing it get professional help. Ok, with that being said let's get started....
Without further ado, here is the HOW-TO install the PIONEER AVIC Z1 in a W203
Many thanks to cntrylvr79 and ducatiboy from www.avic411.com, the nicest people ever.
... hi, i'm interested does anybody have these fanito's pictures because i can't see them... i need them because i'm planning these days to install double din in my coupe.. THX
Old Nov 11, 2009 | 04:42 PM
  #946
OneOfaKindTrini's Avatar
Nike Turbo Shox
I have a Garmin Nuvi 350. I had it for about 3 and a half years and its still going strong.
Old Nov 11, 2009 | 05:11 PM
  #947
RW C55's Avatar
'10 E63 Obsidiant Black; '06 R350 Alabaster White; 05 C55 Obsidiant Black (sold)
Just follow the pictures in center console removal threads, and once u get the OEM HU out, plug in the adapter & install the aftermarket HU and put everything back in.
Old Nov 17, 2009 | 07:52 AM
  #948
LUKA_CRO's Avatar
w203 Coupe
... thx...
Old Dec 13, 2009 | 06:02 AM
  #949
bheng's Avatar
2003 CLK 320
hey guys. sorry bringing this old topic up again but im still confused. I am in the process or wiring my new avic. and i was wondering if i needed to get the ca-r-p.131 for my system/ My HU is the avic z110bt, and i drive a 2003 CLK with bose system. the reason why i want to use the ca-r-p.131 is because i can keep my steering controls but most importantly, allows me to get easier access to the illumination, rear gear, speed signal and ignition. since i have an 03, im supposed to use the 131 and not the 133 right? any other wiring tips i should know before i continue?
thanks!
Old Dec 14, 2009 | 01:40 PM
  #950
Midnight Koop's Avatar
CL203
considering selling
what would the going rate for an avic-D3 with ipod and bluetooth (CDBTB-200) go for?
i'm considering upgrading.
thanks
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
