battery replacement
Old Oct 31, 2006 | 07:17 PM
dac086's Avatar
2003 c320
battery replacement
i have close to 60k on my car and brought car in for service. they are telling me to replace battery. any good batteries i should get or should i just get a oem battery?
Old Nov 1, 2006 | 12:31 AM
Moviela's Avatar
You will not be able to easily find a battery with the same capacity as the OEM battery. You should call Roadside, they will bring a battery, replace it for free (you pay for the battery only), and reset all the electrical items that go limp when changing the battery. The price of the battery is not that much more than a lesser capacity aftermarket battery like DieHard, and a lot less than racing products like Optima.
Old Nov 1, 2006 | 01:37 AM
yeuchau's Avatar
Stage 2 C7 A6, QX60
interstate battery is good, don't know if i spell right
Old Nov 1, 2006 | 11:29 AM
dac086's Avatar
2003 c320
i dont have to pay roadside assistance for anything, if i call them just for the battery?
Old Nov 1, 2006 | 11:43 AM
shadowgriffen's Avatar
is a German Tank
Go to autozone or any other car store, ask if one of the assistants can help you with removal, take your old battery and have them minus the core charge for your old battery towards your new one, and you'll only end up paying like 40-50 bux.
Old Nov 1, 2006 | 11:46 AM
is a German Tank
PS: Dont foget to read this if you're gonna DIY.
https://mbworld.org/forums/c-class-w203/115277-list-faults-occur-after-disconnecting-battery.html
Old Nov 1, 2006 | 12:16 PM
mleskovar's Avatar
'17 Jaguar XF
Moviela gave you the best advice.....take it. No charge other than the battery. About $120 and you get the correct 100 ah battery. I couldn't even find a 100 ah battery of the correct size so I will wait for mine to die before replacing it. Unless....unless....someone can point me to a 100 ah battery of the correct size that is gel filled/spiral wound (a truly sealed new technology battery...like Optima). Some people have replaced the standard battery with a lower ah rating without side effects (that I've heard) but I don't think that's the way to go.
