Heated Mirrors?
Old Sep 8, 2002 | 01:07 AM
Silver_Lana's Avatar
Heated Mirrors?
I noticed that the external mirrors are heated on the C Class cars. What triggers the heating?
Also, the mirrot adjustment button in my car has just the 2 selectors beside the 4 directional button. I have seen some have 4 buttons around them 2 on top, 2 on the bottom what are they for other than the 2 used to select the left or right mirror?
Thanks!
Old Sep 8, 2002 | 02:22 AM
Apollo's Avatar
E320 CDI Elegance auto
Hi
Normally the rear heated screen switch triggers the heated mirrors as well, for all of us that live in countries with crap weather. I also have the heated windscreen wash to stop the pipes freezing up.
I have the 4 buttons and the 2 at the top operate the foldback mirrors for parking and for putting into garages with limited space.
Old Sep 8, 2002 | 02:49 AM
dswildfire's Avatar
2002 C230K
heated mirrors come on automatically. don't know what sensors they use, but whenever there's condensation on them, they turn on.
Old Sep 8, 2002 | 04:04 AM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
the manual says: "the heater switches on automatically, depending on the outside temperature", p. 90.
BMWs use the same way of controlling them.
In Volvos the side mirrors get heated in sync with the rear window, which I find more useful, as you have more control over it (e.g. after a rain).
Old Sep 8, 2002 | 01:55 PM
Originally posted by Apollo
Hi
Thanks!
I was wondering what those buttons were for.
Old Sep 8, 2002 | 06:12 PM
Apollo's Avatar
So the mirrors are triggered by low temperatures, another sign of Benz quality. Must be linked to the outside temp guage, all of the previous cars I have had have been linked to the rear heated screen.
Old Sep 10, 2002 | 12:38 AM
blueC230K's Avatar
2002 W210 M112 | 2021 X247 M270 | 2015 Audi SQ5 | 2015 VW Golf R
Question Folded mirrors
For the U.S. spec W203, can the side mirrors be folded manually at all?? I am afraid to break it so I just want to make sure if we can. thx
Old Sep 10, 2002 | 12:45 AM
Lynn's Avatar
Re: Folded mirrors
No, they can't be folded.
Old Sep 10, 2002 | 12:51 AM
vadim's Avatar
Re: Folded mirrors
They are sprung mounted - meaning, you can folld them manually, but they will return to their original position once the external force is gone.
Old Sep 10, 2002 | 12:59 AM
Lynn's Avatar
Re: Re: Folded mirrors
I'll take your word for it. I am not going to experiment.
Old Sep 10, 2002 | 01:32 AM
vadim's Avatar
Re: Re: Re: Folded mirrors
It's safe, trust me This is the second car I own that doesn't have foldable mirrors the first one was 14 years ago
Old Sep 10, 2002 | 07:31 AM
avlis's Avatar
2008 VW GTI
It's true. And they are sprung in BOTH directions. Isn't this unusual?
Old Sep 10, 2002 | 10:10 AM
MarkL's Avatar
2002 C240 6-spd (ret)
From my experience, I wouldn't call them "foldable". They move about 1/2" in each direction, but I wouldn't want to force them.
Old Sep 10, 2002 | 02:14 PM
dwang's Avatar
C230K and ML320
Wanna bet??? You can move them alot farther than that... Don't worry about putting too much force on the mirrors. They will not break. The spring is ultra strong. To be able to remove the outer shell, you need to push the mirror all the way back (towards the front of the car) to get to the clip that releases the shell. That's how I know... From past experience.
I always thought that the heaters were triggered by the rear defogger, and not by a temperature trigger. The electric wires that cause the heating element in the mirrors run to a relay that also houses the rear defogger. Also from past experiences, my mirrors never heated up unless I had the rear defogger on. But this is on older MB cars (1999 C230K and 2000 ML320).
Dave
Old Sep 10, 2002 | 02:17 PM
preyx's Avatar
'02 C230K Coupe
Re: Re: Re: Re: Folded mirrors
Does this mean it's possible to get to the turn signal bulbs that are mounted on the rear-view mirrors of the C230K? I've been interested in trying take it apart to replace the bulbs, but I wanna check to prevent wasted time/effort.
Old Sep 10, 2002 | 02:38 PM
dwang's Avatar
C230K and ML320
Preyx,
I have never taken apart a CL203 C230K blinking mirror. I only have experience with the non blinking w202 mirrors and blinking w210 mirrors. The w210 mirrors have a LED based flashing bulb. The blinking portion is in a sealed housing with the LED bulb inside it. In order to get to the LED bulb, you would have to break the housing, something I was unwilling to experiment with (it looks like if you took a heat gun to this housing you would be able unseal the housing and get to the bulb). If I'm not mistaken, the CL203 mirror is the same way. I'm assuming you want to switch to a white bulb LED rather than amber LED??? Sorry I couldn't have helped you more.
Dave
Old Sep 10, 2002 | 03:26 PM
Lynn's Avatar
Dave, the bulbs in the coupe mirrors are incandescent. preyx and others are trying to figure out a way to switch to led's.
Old Sep 10, 2002 | 03:47 PM
dwang's Avatar
C230K and ML320
Oh, OK. I understand now. I really would have to take a look at the inside of the mirror housing in order to determine if the incandescent bulbs can be removed. I need to know how the bulbs are housed. Has anyone removed the mirror housing yet? I would be able to tell with a picture... I can also give instructions on how to remove the housing if someone needs it.
Dave
Old Sep 18, 2002 | 04:21 PM
preyx's Avatar
'02 C230K Coupe
Dave, can I get instructions on how to dis-mount the rearview housing? After that I can poke around with it to see what I can actually do.
(I currently have PIAA HID-white turn signals in the front, and to get a fully-white look from the front I need to change the rearview mirror blinkers too. )
