View Poll Results: What PSI do you keep your C230 sedtires at relative to the door sill recommendations?
2+ psi under
0
0%
2 psi under
2
5.13%
exactly at recommendation
16
41.03%
2 psi over
5
12.82%
4 psi over
13
33.33%
6 psi over
2
5.13%
6+ psi over
1
2.56%
Voters: 39. You may not vote on this poll
TIRE PRESSURE thread - All you want to know
Rating: Thread Rating: 5 votes, 4.00 average.
Old 06-03-2002, 02:57 PM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
Originally posted by Mark08859
For those of you that run higher than 32 psi on your tires, have you noticed premature treadwear in the center of you tire. Or, has it been even?
Also, what advantage does one get by running the rears at a higher pressure than the fronts? If the car was front wheel drive, would someone use higher front tire pressure? Thanks for any info shared.
MB itself recommends higher pressure in the rear tires. No indication of premature wear of the centrer part of the tread after 4000mi.
By varying tire pressure, you can slightly change oversteer/understeer: high in the front, low in the rear ==> more understeer; low front, high rear ==> more oversteer
Old 06-03-2002, 03:05 PM
Duffer's Avatar
2002 C230K, 2001 Audi TT 225 Coupe
Gosh, this is a tough one
Salesguy said to keep the same difference between front and back if I vaey from specs as he says MB set it up this way for the car's handling.
Having listened, I think 32f/28r is too low so I am experimenting with 34f/30r
Old 06-03-2002, 03:31 PM
Smoky's Avatar
MB coupe.
Thanks for all the replys.
Good information. I guess this is what the forum is all about.
I'm going out to the driveway now and put some extra air in my tires and see how this improves handling.
Thanks, Smoky
Old 06-03-2002, 04:14 PM
speedfrk's Avatar
C230 coupe 6sp
Changing the front tire pressure to something close to the rear will make the car handle in a more neutral manner. They specifically set the front pressure lower to make the car understeer (front loses grip before the rear) so that people are less likely to get into trouble. In most cars, when the front starts pushing or losing traction, letting up on the gas will bring it back in line. If the rear loses traction first, well, you better know what you are doing, or you will spin out and usually hit whatever object is in the way Higher tire pressure will help handling to a certain extent because the sidewalls flex less when cornering, so you have better response. This is at the expense of ride comfort, however. 32/32 makes my car pretty neutral, and still gives me a smooth ride. Experiment and see what you like, (it's real cheap tuning), but remember that the changes you make may not show their complete effect until you are in an extreme condition.
Old 06-06-2002, 03:11 PM
snowjacky's Avatar
02 silver C320, charcoal, xenon headlamp, CD changer
tire pressure sticker
My 02 C320's tire pressure sticker behind the fuel door is actually for W202 model. Is it normal or they put the wrong sticker on? That means the tire pressure would be the same for both models?
Old 06-06-2002, 03:15 PM
session's Avatar
2007 VW GTI
i noticed that too, that the coupe's pressure sticker actually shows a sedan. i checked on my mom's coupe and she had the same one. i suppose they were just trying to empty some inventory as both PSI recommendations were the same
Old 10-15-2002, 09:21 PM
  #32
MBSJ's Avatar
C230, C2, C7, Leather
Question Tire Pressure
I just got C230 about 5 weeks ago (C2, C7, Auto, Leather, 1500 milies). I added 1 extra PSI for all my tires (29PSI front, 33PSI rear) about 2 Sundays ago. I just checked the tire pressure last Sunday and lost 1 PSI for both front tires and .5 PSI on both rear tires (in one week). I am going to re-check the pressures next Sunday however I am a bit concern about this pressure loss. Is it because they are new tires, temperature changes (both times the car was parked in my garage from Friday night to Sunday morning without running) or somthing that I shoud be concern about? Any feedback?
Old 10-15-2002, 09:46 PM
  #33
Lynn's Avatar
It is perfectly normal. Pressure does vary by temperature, and no seal between the tire and wheel is perfect.
Old 10-15-2002, 09:52 PM
  #34
MBSJ's Avatar
Thank You! That was very quick response! This forum provide me with very useful information (which is why I regisgtered). C230 is a great car! I love it so far.
Old 10-15-2002, 10:01 PM
  #35
604_kpEscoba's Avatar
c240
what should be my tire pressure be?
i havent checked my tire pressure ever since i bought it
can some one plz tell me what it should be
THX
Old 10-15-2002, 10:14 PM
  #36
shtatc's Avatar
2001 C240 6spd
Before someone blasts you with a RTFM....
MB recommends 28psi front and 32 psi rear for the stock 16 inch wheel/tires. I have 17's - and have set mine at 32psi front and 36psi rear. Also depends on what tires you have and how comfortable a ride you want.
Old 10-15-2002, 10:16 PM
  #37
Former Vendor of MBWorld
BlackC230Coupe's Avatar
Fast Cars!
RTFGC, (read the fu*kin gas cap) LOL, just made that one up. :p
Old 10-15-2002, 10:50 PM
  #38
Matt230K's Avatar
2010 C300 4matic
Why do they recommend so little in the fronts when it seems like that is where all the weight is? I just keep mine about 35-36 all the way around on my 17's. Rides pretty good, and I don't like anything lower, it just looks like it's riding on the sidewall.
Old 10-16-2002, 12:02 AM
  #39
session's Avatar
2007 VW GTI
i have the stock 16s on my coupe and i keep it 32/front 36/rear in the winter and 30/front 34/rear in the summer.
Old 10-16-2002, 01:29 AM
  #40
vadim's Avatar
C CLass cars, being RWD, have a close to 50/50 axle weight distribution. The pressure recommendations printed on the inside of the gas filler door are for the base 16" wheels with higher profile tires. I'm sure these recommendations take the ride comfort into account more than folks with 17" wheels and Z-rated tires care about. Varying the tire pressure between front and back affects handling (understeer/oversteer), not too much, but still noticeable. So - experiment and find what works the best for you.
I have found that 33 front/37 rear works ok for me. The car handles better, yet the ride is not too harsh. Plus - those 17" rims can be damaged very easily; higher tire pressure can help prevent this to a certain degree.
Old 10-16-2002, 12:16 PM
  #41
CHATMANR's Avatar
Location: From Oxnard; living in Ocean View Hills, San Diego, CA
'01 C320 SS
My setup is:
f 235/30/19 @ 35psi wheel size is 8.0"
r 265/35/19 @ 36psi wheel size is 9.5"
On a 40mph slightly banked left sweeper, I usually go about 70-75mph with no under/oversteer or drift. This is on Nitto 555's and H&R springs.
Old 10-16-2002, 12:38 PM
  #42
Mark08859's Avatar
2008 C300 Sport
In general, tire pressure s/b checked once a month. Many folks who drive their coupe hard probably check the pressure once a week.
Old 10-16-2002, 12:52 PM
  #43
TimmyC230boy's Avatar
Location: Sitting behind thing freakin desk of mine. Dreaming I was playing my Taylors, and driving my Benz. Long Live The VRAA!!!!!!
C230 Sports Coupe
i check the preasure once a week. Takes 2 minutes but could save much more in costs of new tires.
Old 10-16-2002, 02:26 PM
  #44
patronus's Avatar
2001 C240 / 6-speed
Rules of thumb for automobile tires:
10 degree F change results in a 1psi pressure change
Tires lose 1 psi per month, regardless of temp
Always check tires stone cold with a cold engine and cold brakes (to eliminate radiation of heat from them to air in the front tires)
Old 10-16-2002, 03:02 PM
  #45
C230 Sports Coupe
Good points.
Also I think there are valve caps that tell you what pressure is in there. But those tire monitoring systems are just way too cool.
Old 10-16-2002, 05:22 PM
  #46
yodlebenz's Avatar
C230 K
what pressure?
just curious what pressure most of you run? I noticed a sticker inside the gas flap that says like 28/f and 35/r (don't remeber exactly). is this for a 'stock' c230? what about one with C7 (mine)? The tires on my C7 wheels say max is 51 and had 40ish when i checked the other day.
what pressure seems to be a good compromise between ride and handling?
anyone?
Old 10-16-2002, 05:31 PM
  #47
Lynn's Avatar
Re: what pressure?
anyone?
According to Luke at Tirerack the pressures posted on the gas flap are good for all the sizes of tires shown as acceptable by MB.
As for the best compromise between ride and handling, that will depend on your personal preferences. Experiment to find what is right for you.
Old 10-16-2002, 06:01 PM
  #48
mdp c230k's Avatar
2002 c230k
Pressure varies tremendously with tire temperature, not air temp. If you drove hard before you checked your pressure it will read higher than if it was just sitting there for a while. The most important factor other than checking the pressure is the difference between from front and back pressures, it controls under/oversteer. The car will handle very differently with changes in the balance of pressure. Try changing the front by + or - 2 psi and see the changes.
Old 10-16-2002, 07:10 PM
  #49
yodlebenz's Avatar
C230 K
+ or - which one induces understeer, which induces oversteer (when changed on the front)?
thx
Old 10-16-2002, 11:22 PM
  #50
MBSJ's Avatar
What are your opinions regarding Acutire pressure gauge (digital)? That's what I use to measure my tire pressure.
You have already rated this thread Rating: Thread Rating: 5 votes, 4.00 average.
Quick Reply: TIRE PRESSURE thread - All you want to know
