View Poll Results: What PSI do you keep your C230 sedtires at relative to the door sill recommendations?
2+ psi under
0
0%
2 psi under
2
5.13%
exactly at recommendation
16
41.03%
2 psi over
5
12.82%
4 psi over
13
33.33%
6 psi over
2
5.13%
6+ psi over
1
2.56%
Voters: 39. You may not vote on this poll
TIRE PRESSURE thread - All you want to know
Rating: Thread Rating: 5 votes, 4.00 average.
Old 08-30-2004, 01:22 PM
  #126
Saprissa's Avatar
Location: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
I keep my tire psi at about 2-4 above normal. Lot of highway driving.
I have both a C320 COUPE and C320 SportSedan. Definitely a bigger (heavier) engine than a 230K. Amdeutsch, interested about learning more about the weight balance up front, so I might have to adjust psi settings on front tires.
Both my C320's have staggered wheels (17x7.5 front / 17x8.5 rear).
And no, you cannot rotate staggered wheel set-ups.
Old 08-30-2004, 01:25 PM
  #127
DiamondNoir2K5's Avatar
'05 C230K SS
Originally Posted by Saprissa
Both my C320's have staggered wheels (17x7.5 front / 17x8.5 rear). And no, you cannot rotate staggered wheel set-ups.
I understand that normal rotations involve all for wheels, so that's obviously not possible with staggered wheels.
But if you have staggered, wouldn't it make sense, at least from a left-right treadwear balance standpoint, to at least swap your left and right side tires/wheels from time to time? Do anyone do that?
Or is there something I don't understand about tire rotation that makes left-right swapping a stupid idea?
Old 08-30-2004, 01:33 PM
  #128
CitronC230K_03's Avatar
2003 Citron Green C230KMT
most staggard wheels have directional tires, thereofre you can't do a left-right trade.
Old 08-30-2004, 01:43 PM
  #129
'05 C230K SS
Oh, I see. You learn something new everyday!
While we're on the subject, do any of you folks use an electric air pump to inflate your tires at home? Have any recommendations on a good brand or are they all just pretty much the same?
I'd like to do it at home instead of at a gas station because a) i won't procrastinate as much if i can just do it in my garage any time and b) i don't have to worry about cold vs. warm pressure adjustments.
Old 08-30-2004, 01:46 PM
  #130
Saprissa's Avatar
that's exactly what I was going to say.
My MICHELIN PS tires, specifically say Direction --->
and the in-board side of the tire, says something like "face other side", I don't remember.
Carlos / Saprissa@aol.com
Old 08-30-2004, 01:49 PM
  #131
they usually will specify which side goes inside and out. plus including arrows for the directionally challenged.
Old 08-30-2004, 01:51 PM
  #132
Saprissa's Avatar
I haven't needed the use of an electric air pump. I had the tire pressure adjusted to where I wanted it when I had the tires/wheels installed. Since then, I check them every once in a while with an analog dial gauge, and haven't had to adjust. If I did, it probably wouldn't be that much off, since I go over a bit on the PSI. Nothing a quick stop at the air pump during a routine gas fill-up can't do. Plus, Service A & B intervals check for tire pressure too, and I just make sure to tell 'em just the way I like it. I would think most electric air pumps at reputable auto-shop stores are pretty much the same. I just wouldn't buy one at your local 99cent store.
Old 08-30-2004, 07:09 PM
  #133
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
Originally Posted by DiamondNoir2K5
I don't know by what proportion engine weight grows as a factor of liters, valves, supercharge/turbocharge, but I'm assuming from your answer that your engine does weigh considerably more.
Is there a name of this number that describes fore-aft weight distribution? Is this something I can lookup in standard tech specs for a car like on mbusa.com?
HTH
Link
Old 08-30-2004, 09:43 PM
  #134
'05 C230K SS
Originally Posted by amdeutsch
HTH
Link
Oh. Yeah, that's exactly what I was talking about. Thanks.
Old 09-05-2004, 10:40 AM
  #135
TNblkc230wz's Avatar
C320 Coupe
amdeutsch,
do you think the weight distribution is different for your 320 vs. my 230 sedan since your engine has more power (and, presumably, weighs more)?
also, does the 320 not have staggered wheels? from what i understand, i cannot rotate my tires since they are staggered (narrower in the front).
My coupe doesn't have have staggard wheels. The weight differences is about 50 Lbs over the front axle, but they can both have the trunk load the same
Old 10-10-2004, 02:17 PM
  #136
Nickle's Avatar
Tire pressures for '05 Sport Sedan tires?
Can someone let me know what the factory tire pressure specs are for the '05 SS 17 inch tires?
Thanks.
Old 10-10-2004, 02:46 PM
  #137
Blake P's Avatar
'09 A4 S Line
Factory specs for tire pressure should be on the back side of your gas tank cover.
Old 10-10-2004, 03:16 PM
  #138
Nickle's Avatar
OK, checking the back of the gas cap cover . . . hmmm, since my car is an '02, it doesn't have specs for the '05 17 inch wheels my car has.
Anyone have the specs? Thanks.
Old 10-10-2004, 03:19 PM
  #139
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
Same as MY02 IAW Luke from the tirerack. Check/search the tire forum. HTH
Old 10-10-2004, 03:24 PM
  #140
Nickle's Avatar
The specs for the '02 16s are 28 and 32 front/rear.
That seems awfully low for 17s.
I guess I'll search around.
Old 10-10-2004, 03:48 PM
  #141
Blake P's Avatar
'09 A4 S Line
Sorry, from your post it was impossible to tell what kind of car you have. My bad!
Old 10-10-2004, 04:01 PM
  #142
Nickle's Avatar
No prob! I searched the Tire forum, some seem to recommend using the stock pressures no matter what size wheels and tires are on the car.
That may or may be right, I don't know. But since these are the stock '05 Sport Sedan wheels, I'd like to run them at the pressures recommended by the factory for the '05 Sport Sedan.
Thanks!
Old 10-10-2004, 05:41 PM
  #143
'05 C230K SS
Nickle,
I have seen Luke post several times that you do your pressures more based on the weight and weight distribution of your car chassis rather than the wheels and tires. Therefore you would still go with the pressures printed on your gas flap.
Btw, on an '05 C230 Sedan where those wheels are stock, the pressures are still listed as 28f 32r. I just checked my tires today, I keep them at 32f 36r, which is 4PSI over factory recommendation.
Old 09-12-2005, 07:56 PM
  #144
vdubpower's Avatar
i drive them all, fast and hard
tire pressure
what pressure do u guys run the stock tire/wheel 17s pressure at. i have a sport model. the gas tank lid says 28 ad 32, isnt that low? i think i have the continental tires on there, with 7000 miles
thanks
Old 09-12-2005, 08:04 PM
  #145
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
There have been numerous threads on this subject matter.
Old 09-12-2005, 08:15 PM
  #146
RobertG's Avatar
things with and without wheels
If you want better fuel milage run higher tire pressure like 32 psi
If you want better handling run lower pressure 28 psi.Car manufacturer knows what is best for their vehicle.Keep in mind that when the tire gets hot the tire pressure will increase.
Old 09-12-2005, 08:23 PM
  #147
Admin Alumni
MB-BOB's Avatar
See Garage
For best gas mileage and longevity of the tire, inflate it to the recommended maximum cold pressure on the tire sidewall, or no more than 5-10% less.
The pressure placard on the pillar gives suggested pressures, and is the same (standard) for all C-Class cars (standard sedans, sport sedans, and AMGs). However, there is a wide range of tires (sizes and aspect ratios) actually supplied with the car you buy. As a result, the TIRE can have vastly different max pressure values than the standard placard. Make sense?
My car came with 51psi Pirellis (16in), and I pretty well shortened their 60,000 mile life while following the placard and inflating only to 32psi. At 20,000 miles the tires were thoroughly worn on the shoulder tread (classic underinflation). I bumped the inflation to 42psi and then got another 8,000 miles of even wear from them. BTW, the ride quality was just as good at the higher pressure as at the lower. The tire maker engineers the tire for ride comfort at the pressure intended for each type of tire.
I seriously doubt the plus size tires (especially the 17in tires on the 230K SS) carry a 32psi rating (think MUCH higher). So, in my case, the "manufacturer knows best" adage is not good advice. My Dunlop SP Sport A2 replacement tires have 12,000 miles on them and they look nearly new. I inflate them to the maximum allowed, 44psi, and there is no uneven wear on the tread at all.
So, the rule of thumb is to be guided by the actual tire pressure value molded on the tire. Give the tire what it wants, not what the car wants. Makes sense, really.
Old 09-12-2005, 10:13 PM
  #148
mick1's Avatar
2005 C320wz
I set the pressure on my front tires at 32 and rear tires at 34
Old 09-13-2005, 09:37 AM
  #149
Admin Alumni
MB-BOB's Avatar
See Garage
You guys with 230K SS really should read the max tire pressue value on your tires and then re-read my post (#4) above. Fair warning.
What is the Max pressure allowed on the 17s?
Old 09-13-2005, 03:05 PM
  #150
mick1's Avatar
2005 C320wz
I got the Bridgestone Pozenta tires and the max pressure for them tires is 50 PSI
You have already rated this thread Rating: Thread Rating: 5 votes, 4.00 average.
Quick Reply: TIRE PRESSURE thread - All you want to know
