View Poll Results: What PSI do you keep your C230 sedtires at relative to the door sill recommendations?
2+ psi under
0
0%
2 psi under
2
5.13%
exactly at recommendation
16
41.03%
2 psi over
5
12.82%
4 psi over
13
33.33%
6 psi over
2
5.13%
6+ psi over
1
2.56%
Voters: 39. You may not vote on this poll
TIRE PRESSURE thread - All you want to know
#177
I could understand how over inflated tires could cause a bumpier ride.... but.... how does one place say you have bent rims, and the other say you have over inflated tires? When i got my car (used) the tires were over inflated and the ride was quiet a bit rougher. I bought a little tire pressure gauge, fixed the tire pressure accordingly (28 in the front and 32 in the back) and my ride was quiet a bit smoother.
I think you should explain your "problem" a little better here and clarify upon: "pressure in the tires thing?"
-j0hn
-j0hn
So i am like, whatever, let me drive with it and i will see... so in the meantime, i take it to dealership B. i did not tell them what A said, so they take two days, call me up, "the technician said the pressure was too high in your tires. so he lowered it, and then took it for a test drive and it seems to be fine now." i am like.. "uhhhhh, ok."
so i go down, pick it up, drive it home, and it is better, but i can feel the vibration, shimmy, shake, whatever you want to call it.. in the back of my seat now instead of the steering wheel AND seat.
i am just wondering what the guy at B actually did? I mean, i have NEVER heard of tire pressure affecting the ride that much.. especially when it was only 8PSI over, and my tires can handle 20psi over the suggested.
thanks.
#178
excites your girlfriend
tire pressure is a vast right wing conspiracy that originated around 1998 from the bush administration when large auto companies lobbied the white house to push for increased tire pressure in luxury automobiles.
it's a bunch of baloney you don't need this so called "tire pressure". get rid of it!
#179
Stock rims and tires at 40 could feel that way.
IMHO, the best thing to do is take it to a local aftermarket shop that knows what they're doing and have them check your rims.
If you're feeling some vibrations, it's either your paranoia or an actual problem. A dealership isn't the best place to get a good opinion from. Besides, if it is a bent rim, it'll be very hard to get that warrantied, as they'll most likely say that it was not defect-related, and you'll be hard-pressed to change their minds.
#180
2006 c230 mars red on grey
HELP correct tire pressure for 19"
I just put some 19" amg replicas and was wondering what the correct tire pressure would be for the smoothest ride POSSIBLE on a 19 and even wear on the tires? Should I still use the chart in the door jam ? Thanks for any help.
#185
I wouldnt follow the chart on the door since that recommendation is for the stock wheels and tires, I honestly haven't looked at the tire pressure chart over there. I just pumped some air yesterday and I'm using the tire pressure recommendation stamped on the tire itself, mine says not to exceed 40 psi. I did about 35 psi. With a low profile tire I don't think it's a good idea to run the tires soft. Driving on 19"s for a couple months now, they're not as smooth as the stocks but it's not bad at all. I have 265's at the back also, mine rubs, even by myself when I hit a hard dip on the road.
#186
2013 E350 Bluetec, 2008 Audi S4 Avant, 2011 VW Golf TDI, 2015 Audi S3, 2020 GLB250
Have you trimmed off the plastic tabs on the inside of the wheel well? I'm about to trim them off, but if they don't help, then I won't bother...
#188
Administrator
Someone posted a thread in the SLK forum where he measured temperature on the tires to arrive at the correct pressure. TOO LAZY TO STFF.
Tirerack recommends pressures on their website for this as well as gives reasons for it all.. I also wouldn't follow the printing on the side of the tire. It all depends on your load, speed, etc.; i.e. weight, temperature, volume.
P.S.
Ask our super mod VRAA as he is right now studying these gas laws in college.
P.S.
#190
Tire Pressure
Hello, i've been reading to try to find out what is the best tire pressure for my 2007 C230 sport with stock Michelin tires. If i look on the side of the door it says 28f / 32R. Now if i look on my tires it says a maximum of 51 psi. When i bought the car from a mercedes dealer it came with 33f and almost 40R . I've also read people put more pressure in the front. I am kinda confused here. I need some recommendations. Thank you for any help.
#191
Nov 04 W203
I normally get mine done at mercedes for free..Gas stations sometimes have uncalibrated air pressure pumps..my service guy says to bring it in whenever and they will check on the pressures for free..since their pumps gets calibrated regularly so they know exactly what it is required..far better than me fumbling about and getting everything wrong..and u know what happens when you get the pressures wrong..handling,consumption,tyre wear all come into play..
#192
08 Silver Lexus IS250 (manual),73 air cooled super beetle-- black 2004 230 ss is gone
I use a gauge at least once a month (first thing in the morning when tires are cold) and put in 2 lbs more than recommended in each tire
#193
'14 CLA 45
#195
Agreed, I add a little more too with the stock 17s.
I invested in a digital gauge to ensure accuracy, I also (try to) check the pressure once a week. I do have the passive TPMS but it has never thrown a fault, but when checking pressure I will notice changes +/- 3-5PSI.
#196
The pressure listed on the side of the tire is the MAXIMUM for that tire. It is usually much more than the running pressure. If you over inflate your tires, they will wear faster in the center. If you neglect your tires, and allow them to run under inflated the edges will wear faster. Properly inflated tires will run cooler, with greater gas mileage. There are exceptions to the placard values, and they are explained in the manual.
A digital pressure gauge is not more accurate. A calibrated gauge is more accurate. Most digital gauges cannot compensate for altitude pressure variations. A $ 30 Flaig gauge is perfect for the glove box. They are German made, read in Lb/sq-in and Bar, and are available from our sponsor Performance Products. I have used this gauge for ages, and they remain accurate for decades. With the price of a set of tires around $ 1,000. one of these is very cost effective.
http://www.performanceproducts.com/p...aig+Tire+Gauge
You can increase the life of your tires and rims by not filling them with air. Nitrogen is in tires of aircraft, race cars, and Costco shoppers. Look for the green valve caps, those tires are filled with inert Nitrogen.
#198
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
I never, ever go by what Mercedes indicates. I always go by what it says on the actual tire. Majority of aftermarket tires are 50 max, so I usually go with 40/44, since majority of my drives are not very long distance (70 miles at the most). If I go for a long trip (i.e. Vegas, Nor-Cal, San Diego) that's between a 2-6 hour drive away from LA, I usually bring it down to around 32/36 w/ the assumption that the tires will heat up and expand.
#199
#200
2019 C300 Wagon; '75 Triumph TR6; previous: 2004 C230 6spd sold after 17 years of driving
Go by what the car company suggests. Tons of research has gone to what is the optimal for the best handling
The number on the sidewall is the maximum that the tire will allow but is not the optimal for your car. Because all cars are different weights the pressure has to be adjusted accordingly. Imagine if our car was 1000lb lighter our pressures would be much lower for the same size of tire.
Higher pressure does not equal better handling. F1 cars have a pressure around 8 to 14psi.
By adjusting pressures you can dial in more understeer or more oversteer
Running at very high pressures will have a much harsher ride.
