W203/CL203 City Light Thread (LED, HID, bulbs) - All you want to know
#101
2010 C300 4matic
Why does the blue reflect so much on the little bulbs when the lights are off? My car does that, only on the city lights though. All the other bulbs have blue filters on them too, but they don't show as much. My guess is how close the little one is to the reflector because it is such a small bulb.
#102
Originally posted by tberry
Drew....so u dont get a light-bulb out error w/o load equalizer?
btw, those led bulbs at $11 each seems very fair. i got the polargs and paid $20 for a pair. i don't know what i did w/ them...
#103
Originally posted by Drew_ML
Actually no, not a load equaliser per se as there isn't one that is available to simulate the current draw of a 5 watt W5W incandescent bulb. So, I simply used the bulb itself :p
http://www.newtekelectronics.com/bsm.htm
http://www.liean-gimn.com/products/l/11.htm
#104
My next task is to get rid of that ugly amber bulb in the Bi-Xenons (it's thowing the orange reflection everywhere) and exchange it for an LED bulb. I played around with it for an hour before giving up for now.
#105
'00 ML320 Elegance/'03 C320 4-matic
Originally posted by vadim
Try Philips SilverVision. They are amber bulbs coated with silver paint so when it's not lit, it is silver on the otuside. Can be ordered from www.autolamps-online.com
#106
#107
2002 C230 Coupe Black/Charcoal C5 C7 Auto
I think that you'll find this is true of the high beam or low beam bulbs as well. It is probably the orientation of the bulb in addition to the complex reflector surface, whose effect is exacerbated if you have a clear lens headlamp design :p
#108
DREW you still havent answered. w/o a load equalizer (and Vadim's suggestion) does your LED blubs shows a bulb-out error in the computer or not?
#109
Originally posted by young
drew, are you saying that you basically left the w5w bulb connected and just added the led bulb to the same circuit?
Yes, the pricing is reasonable for what you get. I like the results so much, BTW, that I ordered another pair for my clear corner side markers. From what I understand, these mini-wedge LEDs are available in other colours as well, such as amber, etc. So in effect, you can have a bulb which is clear when off behind the clear corner, but amber when on. This is similar to the amber LED signal bulbs that I have on my ML. In fact, I did something similar to my ML, but with two white LED snakes per lamp also from formymercedes.com
With turn signals flashing:
#110
My bad, both the LED snakes and mini-wedge bulbs are on the site. I just didn't scroll down far enough!
http://www.myroadster.net/led.asp
#111
White LED city lamp ??
Hi,
While I'm waiting my bi-xenon to get here I'm now looking for White LED city lamp so that it can match with the bi-xenon...
Does any1 know what's the best White LED bulbs city lamp that almost have very similar colour temperature ?
please help me find these bulbs
thanks
thanks
#112
https://mbworld.org/forums/showthrea...&highlight=led
Please use the search feature to find what you are looking for. It is very useful.
#113
Oooppss...
Sorry.. I reallly dunno why I didn't think of using the search feature.... but thanks...
But I do have one more quesiton and I did search 1st but I don't think somebody have talked about this before... How to change a city lights ? do I have to pull out all the housing ? and How to change the bumper lense too ? I need to change my OEM bumper lense(orange one) with a clear bumper lense...
thanks alot...
thanks alot...
#114
I know somewhere in this forum there is at least one thread that tells how to remove the city light bulbs. I don't remember how it was done, since I haven't needed or wanted to do so.
As for your other question a search for "clear side markers" should give you many threads about that subject.
#116
2010 C300 4matic
The city lights just pull right out. This is very easy to do on a coupe, but harder on a sedan. It's hard to get a good hold on them on the sedan. The high beam gets in the way.
#118
Doesn't matter much because the LED throws an error to the display and won't light. Tried it - no go. Anyone figure this out? Is there a bulb with a built in resistor - I hate those 'load equalizers' that others have discussed.
P
P
#119
1 Post
2002 C230 Coupe(M111)
Originally posted by Class C
It's alot easier to pull out if you have the Bi-xenons headlamps.
I'm using the Razo 5w city lights bulbs, they are a bit to blue.
#120
Thanks alot for the response guys... really appreciated.... but I still dunno what brand of city light and fog lights have almost the same color match to bi-xenon..
but Thanks anyway
but Thanks anyway
#121
P
P
#122
How did u get them to work properly
I installed mine and all they did was blink acouple of times but they wont stay on. I'm trying to install on a 2001 c320. thanks
#123
#125
Originally posted by Moser
what about the six ohm load resistors they sell on the formymercedes site
do they work as well?
