Fender Roll?
Old Sep 10, 2002 | 03:44 PM
TK2001_C's Avatar
2001 C240
Fender Roll?
I have a 2001 C class and want to put some 19inch wheels on the car. I have been told I need a fender roll done. Is this ture? Does anyone out there have 19's on their C, that could help me.
Thanks a lot
Old Sep 10, 2002 | 04:33 PM
KWiK's Avatar
2002 C230 : 2007 C230
maybe, maybe not. It depends on the wheels your are getting.
What is the wheel width?
Offset?
What size rubber will you be putting on?
The wheel manufacturer and/or the shop you buy them from should answer these question and tell you if a fender roll is in order.
Old Sep 10, 2002 | 04:39 PM
Boo2's Avatar
C32 AMG
Fender roll is for wider wheels. If you are doing +1, +2, +3 sizing without changing the tire width, the diameter doesn't change so rolling fenders isn't needed.
Old Sep 10, 2002 | 10:28 PM
E_Corleone's Avatar
2001 Silver C320
i have a 8.5" width on a 19" tire lowered with no rubbing at all and no modifications or rolling of fenders required. just have someone who knows their s**t do the install and you'll be fine.
Old Sep 11, 2002 | 03:06 AM
W0n6_3d4n's Avatar
C200K (w204)
your rear fender is already rolled, your front fender is not too bad unless you really lowered the car
Old Sep 11, 2002 | 03:24 PM
Boo2's Avatar
C32 AMG
I was told that only the C32's were factory rolled.
Old Sep 12, 2002 | 10:38 AM
W0n6_3d4n's Avatar
C200K (w204)
well ever since i put 19, the rear was rubing quite often so i went to my panel beater and told them to roll my rear fender, and they told me the rear fender is alreaddy roled and you can actually feel it, it's difference from the front one. One way too make your guard bigger is to flare it or cut the rolled part.
If you gona put 19, watch out for the sharp plastic bits on the rear guard, i have to grind some of those part
