IPOD installation
Old Dec 15, 2006 | 12:05 PM
PsiTERROR's Avatar
2003 c230k sport 4 door
IPOD installation
Does anyone know what I need to connect an Ipod to my 2003 C230K?
Anyone have instructions on how to remove the radio?
Old Dec 15, 2006 | 12:27 PM
C24owner's Avatar
'08 E550 4Matic
The search button is your friend. There are numerous posts about this. There is one thread 5 or 6 below this one.
Old Dec 16, 2006 | 10:03 AM
PsiTERROR's Avatar
I've search but none of them have the answer i'm looking for.
Is there any other way to install it without that dealer cable?
Like RCA cables?
Old Dec 16, 2006 | 10:32 AM
Rick's Avatar
C230K Coupe/Orion/C4/C5/CD/AMG Spoiler/V60/TeleAid, 2 MGB's
The "dealer cable" won't work on your model year. That aux interface is only available to 2004.5 and newer cars.
Others have modified the head unit, disabling the cassette deck, but that's a lot of work. Still more have installed other third party devices but these installations are still controlled from the iPod itself (skip track, ff, rew, play etc). Don't go for a cassette adapter - they (expletive deleted). Most fm modulators fall into the same category.
No reasonably priced third party device will control from the steering wheel.
Of course, if you have the COMAND navigation system, you can use the aux in on the front panel of that.
Or....
You can buy and install one of these:
http://www.harmankardon.com/drive-1/default.aspx
I've tried a lot of fm modulators - this is by far the best.
Old Dec 16, 2006 | 11:04 AM
PsiTERROR's Avatar
So I have to spend more money for that (drive+play) to play my Ipod?
I don't want that ,is there a simple way just to use my Ipod?
Old Dec 16, 2006 | 11:06 AM
Rick's Avatar
NO!
Old Dec 16, 2006 | 12:16 PM
C24owner's Avatar
'08 E550 4Matic
You can always use an Fm modulator. Get one that is hard wired to your antenna, (about $50.00) the quality will be better than the ones that transmit the signal but not as good as a cd.
Do you have Comand (navi)?
Old Dec 16, 2006 | 12:25 PM
Blake P's Avatar
'09 A4 S Line
I have the Soundgate iPod kit installed in my 2004 C230 and it works great, but expect to change out all the connectors that come with it because they're pretty cheap.
Old Dec 24, 2006 | 09:45 AM
PsiTERROR's Avatar
Shows how much you guys know.
The easiest way to play my Ipod was a simple 10 buck item
http://www.ilounge.com/index.php/ipo...sette-adapter/
Old Dec 24, 2006 | 11:17 AM
drho2004's Avatar
2005 C230 SS
Easiest, but not best. It was mentioned above by someone else that cassette adapters are not very good. And in the review from your link, it states that it has that 'hiss' that all cassette adapters often suffer from. But if you are not picky about sound, then yes this is the easiest way. But if you want steering wheel control, track title name etc. Then there is no cheap solution for your model year. Heck for nobody's model year actually
