Headlights Question!
Old Sep 15, 2002 | 12:16 AM
PoonerElRay's Avatar
2017 GLA 250 4Matic
I know that on new cars now, the daytime running lights are on whenever the car's turned on.
When I put the switch to auto mode, the low beams will turn on when the sensor senses it's dark outside.
However, last nite I forgot to switch to auto mode. I left the switch in the OFF mode and guess what? The low beams went on when it sensed darkness.
Why is that? What's the point of having auto mode? Anyone with this same problem?
Old Sep 15, 2002 | 12:59 AM
SLK Boy's Avatar
2002 C320
I've never had that problem..then again, I don't have DRL's active either...
Old Sep 15, 2002 | 01:55 AM
Mike T.'s Avatar
2005 smart cabrio; 2008 Mercedes-Benz B 200
Re: Headlights Question!
In the case of the C Coupé at least, the DRL IS the low beam. So if your low beam was off until it got dark, then your car is not set up properly for Canadian regulations.
The point of having the switch in the AUTO position, even with DRL, is that when it gets dark the rest of your lights (instrument panel, tail, side marker, license plate) will go on, something that is preferable to simply having the DRLs only (i.e. low beam).
Old Sep 15, 2002 | 02:00 AM
W0n6_3d4n's Avatar
C200K (w204)
Check your vehicle menu controller, using your sterring wheel button to acces it, you should find your headlight circuit as a constant or the other thing (i forget). if constant then it will on no matter what. BTW does it on at daytime ??
