Noisy Air Conditioner ?? Stepper Motor Replacement / Clicking & Hissing
Let us know if that was it.
KARO now = Owned lol
I get a ticking sound sometimes not all the time in my car. There is no sound when i start up the car, but as the car moves faster the ticking gets faster and when the car is slowing down the ticking is slowing down too. I can't tell where the sound is coming from, to me it sounds like its coming from the roof, or somewhere in the front. I also get no air in the passenger feet area, all other vents work.
What do you guys think is the issue?
Thanks,
-riBO
Been driving with the guts hanging out for 2 weeks now lol. So busy with school.
Thanks for the help.
Step 9 - Once the console is loosened MOVE IT BACK, it will help when taking out/re-installing the moldings under the steering wheel and next to the glove box.
Step 12 - When you remove the side cover there is only one screw you have to remove. It is in the lower left corner. The rest of the screws that are technically in/around there will be removed if you continue to follow the steps (behind light switch, e-brake, etc).
Step 12 - When removing the plastic ring around the ignition switch it unscrews. Don't put the flat tipped screw driver under the switch and try to pop it out. Put one or two small flat tipped screw drivers on the slots within the ring and turn. Lefty loosy, right tighty! Once you start to get it loose you should be able to turn it by hand.
Took me about 6 hours to do the work. If I had to do it again I bet it could be done in 3 or less.
I have a CLK 240 - W209 I have the dreaded clicking noise in the dash, the left/right defroster vents will not work. Do I have to remove dash to fix ? I'm in the UK anyone our there want to fix this for me ? Area KENT United Kingdom.
New to this forum thanks for all your help
"You'll here the flaps opening and closing and the air will be directed out of different vents during the resynch cycle. After a couple of minutes the lights should go out and the procedure stops if everything is ok. If it just keeps going and going then there's a problem with one or more of the motors or linkages and that could be your problem."
If there is a problem with the stepper motor or the broken linkages will the procedure ever stop lol? How can I stop it?
At this point, I'm wondering if just cracking it off to prevent the noise would be a good option, lol.
Thanks for all the help. I'm going to leave all the stuff out for a little while more and see if I can figure any way to make a "mini socket" wrench, or hold a bit with pliers to get in the 1 inch space behind the bracket to get it out.
i have this clicking problem and no A/C (so only heating or not refrigerated air).
i carried the car in for a diagnosis and found
M2/15 ( servo footwell) blocked
M2/21 (servo fresh air) no communication via canbus
by the HVAC-203 pdf you attached previously it seems that the fact that i don't
have refrigerated air is not correlated to these two servos.
any advice? what do you think?
if i remove just the radio (and the center panel) do you think it would be
easy to repair / change the stepper motors or do i have to remove also the two
sides of the center panel?
ps by the way, since all servo have the same part number i guess that you have to
code each one before mounting to set its location?
thanks for the help
I'm just playing, no need to Karo me.
