Thinking bout doing sways now
H&R - Sway Bar - Mercedes-Benz w203 C-Class (not C32 AMG); w209 CLK320 (All) - Front 26mm, Adjustable (for cars with 10mm end link hole) - 70392 - [HRS.SUS.M03.W03]
$239.00
H&R - Sway Bar - Mercedes-Benz w203 C-Class; w209 CLK320/500/55 AMG - Rear 19mm, Adjustable (2) - 71392 - [HRS.SUS.M03.W02]
$159.00
Anyone tried these yet??? Does anyone know if these will fit my 4matic even though it says that they fit all W203 cept AMG for the fronts. Does it improve handling a lot???
I can't comment on the W203 because I have not done sway bars.
But on my '99 Z28, I upgraded the front and went for a ride and I had a lot of over steer. Mind you, this is sometimes wanted by some for different types of driving (autocross, etc.) I didn't like it. Of course, I went up in bar diameter a bit and had some stiff bushings and endlinks installed too.
When I installed the rear sway bar, every thing seemed almost perfect.
But yeah, you can do one and not the other but you may or may not like the driving style when you are really hauling a$$ through the curves. This is when you are going to notice it, not driving to the grocery store unless you cannon ball run everywhere you go.
. I'd probably go with fronts first? But if you'll eventually be going with both, guess it doesn't matter. Should be able to install these yourself, there are DIY guides both here and on MBKlasse.edit: I take it back, forgot you had 4-matic... choose wisely :\. Now you're really going to want to find some affordable labor.
The rear sway is real easy, took me 20 min.
damn y are the 4matics such a pain in the ***.... so the front ones are gonna be a ***** to do but the rears are gonna be easy
I think it was over steer beacuase the Camaro/Trans Am tires have no camber or tilt on the wheels like the euro car makers put in their wheels which has a different effect, but that may be a line of
too. I am trying to go off memory.I just checked my notes and I didn't comment on it in the install doc's so you may very well be correct.
http://www.installuniversity.com/ins..._documents.htm
Toward the bottom.
Buddy installed a rear sway (stock setup had NO sway bar so use your imagination) on his VW GTI Mark IV, stuffed it into a mountain when it snap oversteered.
If you're going to do ONLY the rear bar, you might want to consider the C32AMG one, as that has the least % increase out of all the rear upgrades.
The good news is he got himself a '91 BMW now with the ins payout. Beautiful machine.
Thanks for asking though
Toward the bottom.
The thicker front bar made the front react much quicker in transients (left/right), thus it oversteered into tight corners and through slaloms . . . BUT, it plowed like a pig when moving to a road course like Road Atlanta - where steady-state balance was definitely tilted toward understeer.
For this reason, the I would run the front bar when autocrossing, but remove one end-link for track events (disconnecting the front bar, and leaving a nicely balanced car for high-speed work).
