H&R Springs Installed
2005 C55, 1988 260E, 2000 Chevrolet Silverado
The rear might rub a little on the inside, the front should be good. I agree on the tire size, you could run a 3mm spacer on the rear if you need a little clearance.
I agree, H&R sport spring's with #4 in the rear sets the car level. The gap will be different, but the car will be level and handle better. If you drop the nose to low to get the gap in the front the same then it will make the rear light in the corners. This will cause oversteer and thats not good if your going for hadling.
#33
I definitely like the springs, the spring rate was actually higher then i realized which has resulted in a slightly "oversprung" ride. I'm using struts/sways from an 05 C230KSS (they're supposed to be more heavy duty then my 03's).
Don't get me wrong... it's really close, but not perfect.
Anyway, next time around i would've just got a set of H&R Sports, H&R Sways & Bilstein Sports. I was trying to keep it OEM but whatever...
BTW - just got my alcantra/leather AMG med F1 steering wheel installed!! Pics up soon
#34
When I installed #52732 H&Rs in my W203, the front came down ~1.5", but the back dropped more than 2 inches. The rear was too low, with very little wheel travel. Add a passenger or two, and it was riding on the jounce snubbers. Ditched the original #2 pads and installed #4, but they only raised it ~1/4 inch. Trust you installed #52792, but seem to have suffered the same result!
Spoke with Josh Scott, (888) 827-8881, http://www.hrsprings.com. He was very helpful and accommodating. He provided a pair of their #52792-2 rear springs, gratis. Now, the rear is down ~1" from its original height and feels/looks "proper."
Was pleased with H&R's support, so I've subsequently installed their #70392(2) and #71392 anti-roll bars. Combined, the springs and bars resulted in a substantial improvement in cornering speed and overall handling dynamics.
Scary how you predicted my scenario to the T! Yes, i ordered the #52732's... i may end up leaving it for the time being. BTW, your car looks great!
Cheers,
#36
Grand Cherokee Limited
is the website formymercedes.com a reliable site? i want to buy the monoblock vi replica's from them justwondering if anybody knows
__________________
__________________
#38
2006 C230SS Blue/Black, 2003 SL500 Silver/Black
I would adjust it as lower rears (no puns please) don't look right.....
