Ported Supercharger Installed
I think the only solution at this point is a physical one - the injectors that Jose & Jesse have. With the new injectors, I think that will drop A/F ratios and will allow playing around with the timing curves to extract more power.
Bob
Bob
Bob
Y'know, all these mods are depleting my "finish my Mustang SVO" fund. I'm sure my wife would like to have my Mustang drive in and out of the garage sometime before my 5 month old son grows up and moves out of the house.
Hmmm... belt squeal? You're not putting any more stress on that belt than was there before - in fact, I'd say you're putting less stress since the supercharger is more efficient now and requires less power to crank out the boost. It could be that the belt has stretched to its limit? Or maybe a new tensioner? I have to take a look at the C230's tensioner. I know one simple trick for Fords is to notch the belt tensioner so you can advance the spring a little to increase belt tension.
Bob
Bob
Bob
so much so that I actually feel quite inept in comparison to you all. But I will pony up money for good projects and definitely will pony up time (as long as I can schedule it w/ work). As for the decision between the sways and the throttle body...hmmm...I can see the dilemma. Power is so much more fun when you can use it in the turns...LOL. Can you say, "my esp is going nuts!..."
BTW, your sway bars are definitely working hard in my car!
Thanks again!Drex, thanks for the kudos. I think we can all benefit from the development of mods for our cars. Nice to have performance options, y'know?
Emrliquidlife: I haven't had my injectors reworked yet. RC Engineering is a good place for cleaning and flow-matching injectors, but I don't know if they carry the Siemens injectors our cars use. Jose and Jesse found a source, so I'm inclined to just go with what they've come up with since it looks like it's working well in Drexappeal's car. BTW Drex - that video that Flipachu put on youtube of your car was pretty cool.
Bob
Seriously, I've begun to wonder what the diamter of our ring gear is. I know that a Quaife LSD is available for the C32, but not for our cars because our differential is smaller. I'm wondering if there's a really close equivalent that we can use? Maybe a LSD with nearly identical inside diamter for the ring gear that only needs the mounting bolt holes drilled and tapped? I know it's more than that - input splines need to be the same, etc. But it's got me thinking...
Let's just say the car is running like a completely different car, but just as smooth as when it was completely stock. No error messages, smooth idol (except maybe when first starting the car from cold start).
As for the video, that was when the headers were first bolted on. They were so much louder then because they were still breaking in. Now, you can only hear them on acceleration (and it is still super subtle).
I'll give you all more updates tomorrow.
