Power Steering
Old Jan 15, 2007 | 12:11 PM
mattty's Avatar
01 C320
Power Steering
I have a 2001 C320 and I have no power steering when the car is at idle or I am not giving it gas. Is the power steering pump going bad or does is just sound like the fluid is low? Thanks for your help and input.
Old Jan 15, 2007 | 12:53 PM
mleskovar's Avatar
'17 Jaguar XF
You could have checked your power steering fluid in the time it took to write up this post.
Old Jan 15, 2007 | 03:21 PM
mattty's Avatar
01 C320
Where is it located and do you just fill it to the top or is like oil where it needs to be at a certain level. thanks
Old Jan 15, 2007 | 03:31 PM
sirenebekim's Avatar
there should be a full line, if there isn't i wouldn't top it off to the lid b/c the result could be messy...
Old Jan 15, 2007 | 05:05 PM
mattty's Avatar
01 C320
any idea where it is located at?
Old Jan 15, 2007 | 06:32 PM
take off the front engine cover.. it clips into the airbox, or where the cover reads "mercedes benz" If you follow those letters towards the front of the car you will see a break in the plastic, this is the front cover. Lift up on the front of it and it should pop out of place. Installing it is tricky, but get the tabs in first that are to the rear most section of the front engine cover.
Old Jan 17, 2007 | 11:49 AM
mattty's Avatar
01 C320
does anyone have a picture were the power steering fluid should be added at? I think I know where it is but want to double check. thanks for any help.
