Hitting Redline
Old Jan 28, 2007 | 04:38 AM
C-Benzino's Avatar
C230K-Sport Sedan
Hitting Redline
I recently bought a 2005 c230 sedan and its auto. I've noticed when that when I floor it, it gets really close to redline. I used to drive a mazda 3 and I could floor it for a while before it would even get close to redline. I've had a friend tell me its dangerous to take the car near redline, so I'm wondering if its actually possible to hit redline driving an automatic c230 without using triptronic or does the car automatically shift to the next gear. And if I am taking it close to redline, would be do any damage to the engine and could it void the warranty.
I'm kinda noob so don't flame me
Old Jan 28, 2007 | 05:01 AM
aceer4u's Avatar
'07 c230
it shifts up before u hit redline
Old Jan 28, 2007 | 06:20 AM
yeuchau's Avatar
Stage 2 C7 A6, QX60
won't void the warranty, and nothing will happen to ur engine
don't worry about it
Old Jan 28, 2007 | 07:20 AM
raklert's Avatar
C200K W203
its okay to hit redline...as long as you dont get it pass 8000 rpm everytime you drive then you should be fine. you worry too much.
Old Jan 28, 2007 | 02:29 PM
SlvrC230SS's Avatar
2006 C230SS & 2009 E350
don't worry.
Old Jan 28, 2007 | 03:01 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
Its gonna explode! dont do it!
Old Jan 28, 2007 | 03:49 PM
BlackLiquorish8's Avatar
C3Twon AWD Jumpofffff
your drivin a benz it'll be okay
Old Jan 28, 2007 | 04:16 PM
ScottW911's Avatar
Super Moderator Alumni
a C32 AMG & S-Works Tarmac
The redline is there for a reason. It is the upper limit, just like a speed limit sign on the highway. It's OK to take it up to that point but times spent any higher than that (RPM or speed) can get you into trouble. Now, go out and enjoy the revs.
Old Jan 28, 2007 | 08:24 PM
Boom vang's Avatar
2019 C300 Wagon; '75 Triumph TR6; previous: 2004 C230 6spd sold after 17 years of driving
One of the main reasons of a redline is because of 'valve float' and thus can not extract any more power, in fact you actually loose power because you have decreased compression.
In case you all are asking what the heck is v-f here is a definition:
From Wikipedia, the free encyclopedia
Valve float is a condition which occurs when the valves on an internal combustion engine do not stay in contact with the camshaft lobe. Stiffer valve springs can help prevent this but only at the expense of increased friction losses.
Valve bounce is a related condition where the valve does not stay seated, due to the combined effects of the valve's inertia and resonance effects of metallic valve springs that effectively reduce the closing force, and allow the valve to re-open partially.
Various techniques have been used to offset the effect of stiffer springs, such as dual-spring and progressive-sprung valves, and pneumatic valves.
The motorcycle manufacturer Ducati uses the desmodromic (springless) valve system to counter this problem and allow for higher engine speeds. The system consists of a mechanical lifter mechanism that uses a second rocker arm to push the valve closed. Formula 1 engine manufacturers use a pneumatic system to close the valves to allow for very high engine speed without valve float.
Old Jan 29, 2007 | 06:12 AM
alex007mayn's Avatar
c240 and 69 cadi cdv conv
is it just my car or do all 01 C classes not have an autoshift feature, in triptronic gear my car won't shift automatically, it'll redline and not accelerate past a certain point.
Old Jan 29, 2007 | 06:45 AM
raklert's Avatar
C200K W203
mine doesn't shift either.
Old Jan 29, 2007 | 10:01 AM
Vivid's Avatar
It should have a rev limiter. It will just bounce off of it if you hit it.
Old Jan 29, 2007 | 11:09 AM
tee_tz's Avatar
ML63 AMG
You do not want to start going past the red line, so once your car hits it, it'll automatically shift to protect the engine. Of course with a manual you have to shift yourself, but you aren't suppose to go above that line ... well, that's why it's there and that's why they call it a red-line.
Don't know if the 2005+ C-Class has this, but BMW's have an indicator depending on how warm the engine is. Therefore, if it's a cold day it will show some markers on the RPM gauge showing you DO NOT GO ABOVE THIS YET. You need the car to warm up properly; then as the car warms up, those white markers disappear.
Tee_Tz.
Old Jan 29, 2007 | 11:11 AM
Mercus's Avatar
2006 C230SS Blue/Black, 2003 SL500 Silver/Black
No biggie
Old Jan 29, 2007 | 11:39 AM
BKLYN_C's Avatar
MB
Tee_Tz.
Don't have it, but it sound as a good precaution thing to have- lets the engine last longer
Old Jan 29, 2007 | 06:23 PM
C-Benzino's Avatar
C230K-Sport Sedan
Thanks guys! I guess I was just being a little paranoid with the new car. The manual says that it will automatically shift up even in tiptronic mode.
Old Jan 29, 2007 | 08:33 PM
sirenebekim's Avatar
is the tiptronic the automatic shifter
dumb question but i dont know
Old Jan 30, 2007 | 12:39 AM
ctC230K's Avatar
excites your girlfriend
1. the point of tiptronic mode is to shift manually. if you did not want to shift manually why would you put it into tiptronic mode in the first place?
2. on the 2005 c240, 2006 c280 that i've driven i think they both shifted up to the next gear if they hit redline even in manual mode, iirc
Old Jan 30, 2007 | 08:28 PM
BKLYN_C's Avatar
MB
All tiptronic does is limiting you to the selected gear. I mean if you have it in third, the tranny will be shifting the way it wants to the selected gear and constraining revs on the red line
