Will CLK rims fit C230?
2002 C230K, 2013 BMW 328, 2015 BMW X5
Ha, I couldn't get a straight answer before I went, but now there's 20+ replies.
The wheels are
17 x 7.5 E37 front
17 x 8.5 E30 Rear
They fit fine, and look pretty good.
I wasn't looking to get a set of wheels, I just wanted 2 C7 wheels, but
after 3 weeks of driving on bent rims and no luck I bought these
Yes, I have AMG BBK and CO's, and they fit perfect.
Even was able to use the same bolts.
The rears are tucked, a spacer would accentuate the stagger.
They have PS2's on them, and ride and drive very nice.
Lucky catch from craigslit!
The only bad thing is if I get a flat on the front, there is no wheel that will fit
(due to C32 brakes spare won't fit, and with 8.5 on the back, I can't move to front), unless I drive around with an extra full sized rim in all the time.
I'll have to get a can of fix a flat, but that sh_it causes the tread to seperate.
The wheels are
17 x 7.5 E37 front
17 x 8.5 E30 Rear
Dood, I told you it would fit. I have the EXACT setup you have. My suspension is a H&R Cup Kit.
![](http://i74.photobucket.com/albums/i262/emrliquidlife/AMGBrake.jpg)
![](http://i74.photobucket.com/albums/i262/emrliquidlife/SeaCoupeside.jpg)
This photo is deceptive because there is a decline, so the car is sitting high on the passenger side.
If you don't mind me asking, what did you pay?
E
'09 A4 S Line
Ed, the difference between your setup and his is that he has coilovers. As he goes lower in the front, his tire gets closer to the larger coils. I think stock C7's have an offset of 35ET and my tires were uncomfortably close to the coils when I had my TEIN Basics installed. Then I got the B's (35ET) with 5mm spacers up front (effectively 30ET now), so now I have plenty of clearance.
so I'm looking at putting a CLK rim on my rear passenger side- just one b/c the old rim's cracked. Will the offset of 30 vs. 34 on the c230 make a difference since the other rear rim will not be replaced???
