Best thing to use to clean brake dust?
2008 E 350
Ok i've been slacking off for a month and my brake dust looks like I hit the side of the car... it's literally all black over the left wheel... anyway, I used WD40 but it was hard to scratch off even the littlest marks... what to do with the massive one?
Re: Best thing to use to clean brake dust?
The best thing is to avoid brake dust in the first place. Replace those factory pads with ones that don't dust. The little dust my Porterfields create after 2 weeks I can just hose off, no chemical, no scrubbing.
i asked the same question a while back and one of the suggestions was to use tru green... i'm not really sure what that is but it appears that some people used it... to be safe.. you can use mcguires tire cleaning products..... or a lot of elbow grease....
2008 E 350
Also, in response to Fuzzo and DCX's comments, are you saying that any wheel cleaner will do? BTW, is WD40 good though?
My car is leased and I promised myself I wouldn't touch anything. Unless brake pad replacement is like changing floor mats, I'm not sure i'd like to get anything "modded."
C- 230 Kompressor,C2,C7,Black,JL sub,A/D/S/ amps,Alpine hu and changer
P21s makes a great wheel cleaner that will not harm your wheels, I think the gel they make is what you need http://www.p21s.com/
'08 BMW e92 335i
Re: Re: Best thing to use to clean brake dust?
Originally posted by DCX Engineer
I would use Castrol Super Clean All Wheel Cleaner and a sponge/brush. Or have you already tried conventional wheel cleaners?
Originally posted by Enze6997
How much are the stock pads cost wise to replace?
'08 BMW e92 335i
i have commented on this before, but from a MINI board suggested to use PAM cooking spray as it is non-sticky, it should allow you to spray off the dust without any problems...
2002 C240 6-spd (ret)
As schwarz C230 already mentioned, P21S is the recognized wheel cleaner in Germany. It is sold by my M-B dealer and is highly regarded. I also bought it through carcareonline.com. The gel formula is good because it sticks to the wheel better and can be left on for a long time if necessary. P21S will not harm wheels. Be very careful of products with harsh acidic components -- they will damage the finish on the wheels.
The factory pads typically last about 15-20K depending on the type of driving you do. You will end up changing the pads probably twice during your lease.
Spray undiluted on wheels, let sit a minute, then use plenty of water and a soft sponge to (easily) wipe dust off, no elbow grease required. Works like a charm.
The purists will say that since it is not primarilly made for car use, (even though K-Mart stocks it in the Auto Dept.) that it can harm the clear-coat on your wheels. But since it's completely bio-degradable, I don't see how this can be. I've been using it for a year, with no affect on the wheels at all.
(I've tried Eagle-One wheel cleaner... completely worthless)
For those of who are worried about using Simple Green on their wheels, there is Simple Green Wheel Cleaner Foam.
2008 E 350
Let me get one thing straight, though. Most of you are saying clean the wheels with _____, however my biggest problem is the brake dust that builds up atop the tire cutout (front side of the car). By cleaning inside the wheels, that brake dust would build up less, but how about cleaning with the solutions mentioned on the actual car exterior?
MB-Bob, have you ever used your brakes? How can they only be 5% worn, no wonder you don't have severe dust problems. The dealer told me 15k miles is normal and a friend had his replaced at 18k miles on his C320. I only mention Porterfield because that's what I have but I also mentioned Pagid, EBC and Mintex in the past for those what want a more cost effective pad that still gets the job done.
Buell, I have the same dust problems others mention here. My C320 is my daily driver to work, 34-miles roundtrip each day at an average speed of 31 mph (equal mix of Interstate highway at HWY speeds and city stop and go). After a week of driving, my front wheels looks as dirty as every other MB in my area.
Unlike in CA, we have yearly state safety inspections here in TX. I use the opportunity to ask the tech how my brakes are holding up. This last round, (at 11,000 miles) he said my brakes "hardly looked used, 5% or so." Since he's not an MB dealer, I'm not sure he knows the benchmark on which to compare, except his opinion that I have plenty of pad material left. To be conservative, I guesstimate I have about 90% of my brake pads left at 11,000 miles.
My rush hour here on a normal day is not as intense as I remember from my few occassions with rental cars in CA, where you often ride the brake in 5-10 mph creeping traffic. Maybe that's the difference. I don't do many panic stops, but I don't baby the brakes, either.
OEM pads on my wife's Dodge minivan lasted about 50,000 miles in the same environment (but hers are short, stop and go trips)
2008 E 350
P21S is the best product for cleaning wheels, it is made in Germany so it is formulated for brake pad dust for Mercedes, and Bmw, they have a paintwork cleaned that is very good also, claybar will clean the paint of your car, I would not use anything on your paint but products like these, many will damage you paint forever,my last car was white, I allways used the paintwork cleaner before waxing, if you dont you could allways see a dirty film around the exhaust and wheels.I just switched to Zaino products because they last longer, I still use the P21S wheel cleaner
Originally posted by phattbam
my brake pads (OEM) lasted me only 22k miles, i replaced them with OEM as some aftermarkets were said to "squeal"...
They don't squeal, they speak to you
Re: Re: Re: Best thing to use to clean brake dust?
be careful, the chemicals that it contains may be harmful to your finish.... i know that stuff gets your skin...
Buellwinkle...
I'm very curious about this brake wear thing, so I called two local dealers here in Dallas. One said the brakes should be good through 20-25K miles. The other said 20-30K miles.
So, to me this means two things. 1) I'll start watching my brake pads sooner, and 2) maybe you folks in CA do experience more rapid pad wear than here in the midwest. (The theory again is that So.Cal. traffic is more slow-speed stop-and-go where you ride the brakes more in 5-15 mph traffic.) Maybe (?) that explains the 15-20K estimates that your dealer tells you.
This is not fact, SoCal240/6... not even an opinion... just a guess.
