Tein SS thread issue
Old Feb 20, 2007 | 08:31 AM
tman88's Avatar
06 c230
Hey everyone, i searched the forums for this answer and couldnt find an answer. im trying to raise my rear up more. (assuming moving the the rings DOWN will raise the car in the rear...that could be wrong, also i couldnt test it) I figured my rear is real low and the ring is 1/2" or less from the top so that would mean lowering the rear rings would raise the car... so on to the problem.. when i turn the rings to go down the threads move with it so its not actually lowering the rings. i sprayed some wd40 on the rings maybe to loosen it up but had no luck.. anyone else have this issue and how to fix it??? thanks a lot!!
Tony
Old Feb 20, 2007 | 10:05 AM
rlee02135's Avatar
2004 C32 ///AMG
its easier to do the rears if you take the whole spring out
Old Feb 20, 2007 | 01:03 PM
tman88's Avatar
06 c230
im doing this at home so i wanted to try to avoid that. lets hope i dont have to pay someone to do that to adjust my springs! haha that would suck!
Old Feb 20, 2007 | 03:52 PM
Blake P's Avatar
'09 A4 S Line
I've heard it's all but impossible to adjust the rears without removing them, but never actually tried. I just had the rear set all the way down the first time with no intention of ever needing to re-adjust!
Old Feb 20, 2007 | 04:07 PM
coin's Avatar
'06 CLK500
I am planning to drop my rear but I have not tried it out.
I think dropping/raising the rear may require some professional help though
Old Feb 20, 2007 | 08:15 PM
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
It's a real pain in the A$$ to lower the rears, but it can be done. I'm assuming you're using the TEIN wrenches that are provided, correct? If so, just know that it take some "elbow grease" to do it.
Old Feb 20, 2007 | 08:22 PM
coin's Avatar
'06 CLK500
elbow greese and muscle, which I don't have .
Anyway, is there step-by-step instruction on how to do this? I searched the forum but haven't found any answers yet.
Old Feb 20, 2007 | 10:15 PM
WaveyKat's Avatar
Something Slow
ok i raise and lower mines a few times without removing the entire suspension its takes a while and few cuts on the fingers lol
what i did was turn the TOP ring all the way up and tighten with the copper color adjuster thingy do this so that when you turn the botom ring the copper thing turn and the upper rings turns too...... use the TEIN wrench to hold the upper ring in place and then turn the bottom ring with the wrench try that.
and yes i think you need to turn the bottom ring downward for the car to raise up higher.. hope that helps
Old Feb 21, 2007 | 06:21 PM
tman88's Avatar
06 c230
thanks for the input guys.. i know you can adjust them and YES it is a BI#$% to do it at home..hopefully i can try again this weekend! thanks again
Tony
Old Feb 21, 2007 | 06:46 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
to lower the rear you will have the jack up the car and the suspension cannot have any load on it, so you will be actually be able to turn the knuckles. Moving the knuckles down = raising the car up.
I raised mine up all the way. It's at 1 finger cap on the 19s.
