My Rotor has a hole in it!
Oh well...another reason for some slotted/drilled rotors
trezaei....when I saw the hole in my rotor...the first thought was "hey hey hey!! already on my way to getting drilled rotors...hoorayyyy!!"
I agree with the manufacturing defect. While I have not seen this before, I would get it replaced ASAP. You don't want to run the risk of cracking.
E
u have nothing to lose right
Bob
Buy a new rotor (or both) and slap it in, 10 minute job, and about 30-50 bucks.
Lesson learned. Don't resurface rotors.They warp.
Is it front or rear?
It's not worth the hassle.
I disagree with you here. Rotors wear into the pads that have been used on them. This bedding process creates the fine lines that circle the rotor. When you resurface the rotors you get rid of this. Then you get a better bedding in of the new pads. As long as the rotor has enough metal on it, I prefer to get them resurfaced.
Resurfacing insures that I don't get brake wobble/steering wheel feedback during hard braking.
There are a number of procedures that MB recommends that I don't follow. Like changing oil. I always do it from the pan. I guess it is because I'm old school, but there are habits that I'm don't see a reason to change.
E
