Stupid brake light!!!
Old Mar 13, 2007 | 10:47 AM
rpayer's Avatar
C320
So my left brake light went out yesterday... I went to the local autopart store and purchased the correct bulb to replace for the break light. this morning I popped the cover off and removed the light tree. Since I wasn't sure which one was the brake and which was the rear fog light I just replaced them both. Guess what... left brake light still doesn't work! Am I missing something here?? I know its the right bulbs because I cross referenced the numbers on the bulbs. The rear fog light works so I switched that bulb with the bulb that was in the brake light position to make sure it wasn't just a bad bulb...no dice. Why do I have a feeling this isn't going to be as simple as replacing a light bulb???
Old Mar 13, 2007 | 10:59 AM
outaurleague's Avatar
w211 e500
Had the same problem, but when i switched the lights back, it worked fine. Take both of them out and match it with the other tree, i cant remember the format cuz i have the s-tails now, but hopefull that works for you. Good luck
Old Mar 13, 2007 | 11:09 AM
rpayer's Avatar
C320
What do you mean "switched them back"? You put the old bulbs back in and it started working again?
Old Mar 13, 2007 | 11:27 AM
w211 e500
Yeah i took the old ones out, and ordered new ones from http://www.autolumination.com/, when i plugged the new ones in, they worked perfect. what number bulbs are you using ? That may be your problem. Even more so if your using oem bulbs. I'm using aftermarket and they are working fine.
Old Mar 13, 2007 | 11:32 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
have u tried putting the new brake bulb on the right side to test???
Old Mar 13, 2007 | 11:48 AM
rpayer's Avatar
C320
hmmm... I dont know the number off the top of my head but the numbers matched the OEM bulbs that I took out.
Old Mar 13, 2007 | 11:52 AM
rpayer's Avatar
C320
I havent had time to do that. I plan on it this evening. I did however replace the rear fog bulb along with the brake bulb abd it worked with the new bulb. It wasn't out before but I would think that would tell me the bulbs are good. I even tried both bulbs in the rear fog socked and the both worked. I'm wondering if the brake bulb section of light tree could be bad...
Old Mar 13, 2007 | 11:55 AM
w211 e500
Beat me to that, i was going to say, there may be a short somewhere in your tree.
Old Mar 13, 2007 | 12:01 PM
rpayer's Avatar
C320
Great! I'm sure this will end up costing me $300 before its all said and done. I assume that will have to be purchased from the stealership? Could I test it with a test light?
Old Mar 13, 2007 | 12:39 PM
mleskovar's Avatar
'17 Jaguar XF
I experienced the same frustration with mine but fortunately it was during warranty and they replaced the whole light panel and the rear SAM.
Old Mar 13, 2007 | 12:47 PM
rpayer's Avatar
C320
I am under warranty. I guess if the actual light tree were bad this would have to be covered under warranty. I just had the car in for warranty work and I was having a similar problem with the passenger side rear lighting. the stealership said they changed a wiring harness. I wonder if my rear SAM is going out also. I sure hope the independant shop I plan on using from now on does warranty work... I have given up on the stealership.
Old Mar 13, 2007 | 12:49 PM
w211 e500
Damn im with you on that one.
Old Mar 13, 2007 | 12:57 PM
rpayer's Avatar
C320
This was the straw that broke the camels back....
https://mbworld.org/forums/showthrea...ted+suspension
Old Mar 13, 2007 | 01:03 PM
w211 e500
Please tell me this isnt what they told you ?
Old Mar 13, 2007 | 01:13 PM
rpayer's Avatar
C320
Told me?? Man thats what happened. They had my car for like 2 weeks while they were trying to milk the warranty company for everything they could. It finally got fixed and I still came out of pocket almost $400 for "warranty" work.
Old Mar 13, 2007 | 01:40 PM
rpayer's Avatar
C320
Problem solved!! I was getting aggravated so I went down to the parking lot to have another look at this. I removed the harness from the lighting tree and firmly plugged it back in. All my rear lights work now! I dont know how this could have come lose since I have never removed the cover but oh well... Glad I dont have to even think about warranties or the stealership now!
Old Mar 13, 2007 | 01:45 PM
w211 e500
Pluggin it in ? Lol that could work too. Glad it worked! without all the
Old Mar 13, 2007 | 02:51 PM
rpayer's Avatar
C320
lol...Thats what I said... Its not like it was unplugged...maybe just a little loose. I moved this past weekend and had some things in my trunk but the plug/light tree is covered by the fabric panel. who knows....
Old Mar 13, 2007 | 02:59 PM
w211 e500
thats crazy, im glad you fixed it. Could have caused some stress.
Old Mar 13, 2007 | 03:06 PM
rpayer's Avatar
C320
me too! believe me...i know! thanks for the help.
