C320 to C350 Performance
I don't know if they did dyno to prove that??
if it's true, than $450 for 24hp and 28tq is definitely worth the money
cause if it' really give me 24hp and 28tq, I think it's worth it.
however, I need to install and paint my bumpers first, so after that I should be thinking about the ECU.
Waveykat, I thought you already had ECU upgrade??
I'm sure that a tuned 320 would have more performance than a stock 350. In fact, as I plan a build up of my motor, my motivation is to beat the 350 motor.
Sauce, stand by the side, sell your car, and let the doers win.
E
The M111s still got some running room to work with - I think we can give 320s a run for their money - well, with the right parts and tuning. Psst... let them spend their $ on bigger airboxes :p.
You guys say that a 230 tuned can beat a 320 stock...so?
Can a 230 tuned beat a 320 tuned with the same mods?
P.S. You're right about not too many 320 owners out there, and of those owners...not many that want to mod. This is simply because the 320 is more expensive (even if it's not by much) and since they sprang the extra money for the higher model, they probably don't have too much left for modding. AND if they did have enough for the 320 + mods, why not an E?
Dude, you've only been a member since February this year. You do realize that there's been a history of different people doing different things to their cars and you do realize that the 320 engine had the most available power upgrades compared to the 240 and/or 230KSS, right?
That being said, not everybody could afford a 320 brand new. When I was looking for a car, I preferred getting a 2004.5 230KSS over a pre-owned certified 320, just cuz it would be less a lot of miles and fully covered under warranty.
So, no need to "defend" your 320, because what is being discussed is primarily what can be done with the cars/engines and for comparison sake, it's easier to compare other engines to what comes stock on the lower powered w203's (i.e. tuned 230K vs. stock 320). I wouldn't be surprised if my car is faster than a 320 right now (even one with small power mods (i.e. cat-back exhaust/airbox mods). Thing is, it's not to down what the 320 has, it's just to say that with the right tuning, you can accomplish good power and so that people can understand where the power will be, you describe other models in the chassis.
So I suggest you get off your high horse and stop defending anything because nobody is trying to down the 320's power or compare power to see whose got the "bigger *****".
My sights are set on the 350. And for the record, at this time, I know I can't take one down.
Kev,
If I were you, I'd stop playing with tail lights and get some rims Pronto!
E
I don't know what mods you do or don't have, but you basically indicated that based on the fact that the 320 stock has more power than a 230, a tuned 230 would still be slower than a tuned 320. That may not necessarily be the case in every instance.
Just watch what you say, cuz you've had a tendency to post stuff that is borderline wrong and that could mis-lead people who don't know anything at all.
Bottom line, the M111 was quite tuneable, and some of us guys have M111s with bolt ons, and some massaging. I guess the only thing we could do between you and I is to compare dyno sheets.
I have been putting off getting one done for some time.
I want to get my injectors cleaned first, but I would be game.
E
