Possible MAF issue
Old Mar 20, 2007 | 01:44 PM
rpayer's Avatar
C320
Possible MAF issue
Yesterday I brought my '01 C320 to a reputable, independant MB shop here in town for an oil change. When I picked my car up they said they went ahead and checked the air filters and such. Well now I think something may be wrong as a result of the work/inspection I had done. Everytime I've driven the car since picking it up it hesitates badly at least one time upon pushing the gas. Say if i'm stoped at a red light and the light changes and I try to accelerate the car well hesitate for 3-4 seconds then decide to go. Could they have possibly damaged the MAF? Wouldn't I get a check engine light? I was going to reset the ECU but I dont know if there is any point. Any ideas?
Old Mar 20, 2007 | 01:49 PM
johnand's Avatar
Super Moderator
2007 C230SS; 2014 ML350 BT
Check to see if the air filters are seated correctly and the housings completely latched.
Old Mar 20, 2007 | 01:52 PM
rpayer's Avatar
C320
They did say they checked the air filters....
Old Mar 20, 2007 | 01:53 PM
Ryanr317's Avatar
R129, XF Sportbrake, SC400
I have a similar issue that happened after i took out my filters to clean them. I sprayed my MAF withe MAF cleaner as well. Mine only idles rough sometimes when the car is cold. I don't get a CEL either. Any insight?
Old Mar 20, 2007 | 01:55 PM
rpayer's Avatar
C320
I haven't really noticed a rough idle. It did seem to be idling low however. I noticed idling at 500rpm when I was at a red light earlier.
Old Mar 20, 2007 | 01:57 PM
johnand's Avatar
Super Moderator
I know THEY checked the filters, that is why I am just advising you to double check their work and make sure the filters are seated, and the filter housing and hoses are tight and latched.
Old Mar 20, 2007 | 01:58 PM
Ryanr317's Avatar
If you think you'll be ok with it, i'd suggest removing the airbox and doing a thorough inspection of it, the filters, and the airway as well as the MAF sensor. Are you using any filters that require oiling such as K&N?
Old Mar 20, 2007 | 02:01 PM
rpayer's Avatar
C320
I'm just running OEM filters. I have heard of the MAF issues with using Green or K&N filters... If they did the work and possibly made a mistake shouldn't I take it back to them to fix it? I dont really want to remove the airbox. I know how, I just dont have time...
Old Mar 20, 2007 | 02:09 PM
johnand's Avatar
Super Moderator
It is your call, spend a few minutes checking their work, or take it back to the shop and tell them what the problem is, and have them fix it.
Old Mar 20, 2007 | 03:08 PM
rpayer's Avatar
C320
I just ran up to the shop and had them look over it. He said that the tech didn't remove the entire airbox to check the filters. He just removed the tubes and looked at the filters through the front of the airbox. The owner of the shop drove it around and said they he felt it idle rough once. He said the MAF is probably on its way to busted. Great...
Is the a DIY for the MAF?
Old Mar 20, 2007 | 03:34 PM
johnand's Avatar
Super Moderator
I would try the method posted in the archives for cleaning the MAF.
Old Mar 20, 2007 | 04:10 PM
rpayer's Avatar
C320
I discovered that a little while ago... On my way to pep boys right now...
Old Mar 20, 2007 | 04:37 PM
alymo's Avatar
2001 c240, 65 MG Midget...5.0L V8
hey i can't find that article you guys are talking about, how do i find it in archives, ...where are the archives
Old Mar 20, 2007 | 08:35 PM
rpayer's Avatar
C320
Update
I went to pep boys and picked up a can of the MAF cleaner and then swung by the stealership and grabbed 2 new air filters. I removed the airbox and the MAF. I then cleaned the MAF and changed the air filters. I put everything back together and it looks like I may have solved the problem! No rough idle and no more hesitation. I also reset my ECU. Talk about throttle response I haven't felt in a while! Thanks for the info guys!!!
Old Mar 20, 2007 | 08:47 PM
Buellwinkle's Avatar
They make have knocked some dust loose from the air filter and it fell in the intake and that may have dirtied the MAF wire. You have to careful these days with filters, the MAF wire is sensitive. I vacuum out the box and make sure the new filter sits in there perfect with the gasket and all. I think the reason that aftermarket filters have problems is not the oil coating, it's that they don't fit right and let dust through. I felt the K&N had a sloppy fit and poor quality.
Old Mar 20, 2007 | 08:55 PM
rpayer's Avatar
C320
Read through a few of these articles...
https://mbworld.org/forums/search.php?searchid=2806275
It is talked about in quite a few of them but there is no DIY threat for cleaning the MAF.
Old Mar 20, 2007 | 08:57 PM
rpayer's Avatar
C320
Has anyone ever put some type of chicken wire or mesh over the air intakes? As in the opening directly behind the grill... I'm surprised I didn't find a bird in there! There was a lot of BIG debris in my air box!
Old Mar 21, 2007 | 10:41 AM
rpayer's Avatar
C320
Maybe so... I couldn't see anyhting on the MAF wire but it def seeems to be running better now.
