Aiming of clear fogs after install on C32
Steve
raise the car on ramps
remove three screws in fender well
remove three fasteners on bottom/one in fender well
remove plastic cover(located directly under fog light)
unplug light
remove two screws that hold light assembly in place
unit will now lift out
FYI2:the fasteners mentioned above,to remove them you need to pry the center shaft down out of the plug about 1/4 "
this will allow you to grasp this shaft with needle nose pliers and pull straight out
when reinstalling leave shaft out /insert plug/then reinstall the shaft
Steve
unplug light
There is a small hole just to the side of each foglight. You need a long philips head screwdriver that will fit through the metal grates. Turn your fog lights on and aim appropriately. NOW, here's the imporant part. As you're turning the screw, the outside of the fog light housing will not move. The aiming is done by moving the inner housing lens.
Here is my passenger side fog light, the circled hole is for adjustment.
Good info. I thought I had to adjust the fog lights BEFORE installation :x
