Steering problem
Old Mar 28, 2007 | 06:06 PM
C24owner's Avatar
'08 E550 4Matic
Steering problem
Hey guys,
When making a turn the steering makes a "clunk" sound and is also felt through the stearing wheel and gas pedal...
I felt it once a few days ago and like 5 times today. Anyone have any ideas as to what this maybe?
Nick
Old Mar 28, 2007 | 10:08 PM
C24owner's Avatar
'08 E550 4Matic
Bump.
Anyone?
Old Mar 29, 2007 | 10:20 AM
C24owner's Avatar
'08 E550 4Matic
Thinking about flushing the power steering fluid.
good idea??
Old Mar 29, 2007 | 12:11 PM
c230K415's Avatar
AMG GTS
I have a similar problem on my other car...What happens is that whenever I turn the wheel to half of farthest I can go (either left or right)...it will make a clunk that sounds painful...this was after my father curbed the car to avoid an accident...he curbed it so bad it blew his tire and messed up the alignment...we got a replacement tire along with alignment and balancing...afterwards...this clunk was still there...i'm sure some nuts, rod, or something in that category is broken or loose...might wanna check on that before flushing steering fluid...if you recently hit your front against something...it would make sense for this clunk
Old Mar 29, 2007 | 01:18 PM
C24owner's Avatar
'08 E550 4Matic
I have never curbed to wheel or been in an accident.
I am going to take a look at all the components tonight and make sure everything is tight. I might do a flush just for ****s and giggles, since I already have the fluid.
Old Apr 1, 2007 | 08:24 PM
WaveyKat's Avatar
Something Slow
soo.. did u figure out whats making the noise??? are u sure its not something to do with your suspension?
Old Apr 1, 2007 | 09:02 PM
C24owner's Avatar
'08 E550 4Matic
Nope. It's gotten a little worse. I dropped the car off a few hours ago.
I cant figure it out, the problem happens intermittently and used to happen after driving the car for a while, but now its doing when its cold as well.
My suspension is shot but I don't think that it would make the noise since it doesn't make it when going over bumps. I checked to make sure everything is buttoned up nicely under the car and couldnt find anything loose.
I will know tomorrow if it is something stupid like a worn bushing or if I am going to be bending over taking it up you know where form the dealer.
Old Apr 1, 2007 | 09:05 PM
rlee02135's Avatar
2004 C32 ///AMG
did Vogtland come through with the springs?
Old Apr 1, 2007 | 09:08 PM
WaveyKat's Avatar
Something Slow
i get a clucking sound when its about 30-40 degree cold outside for about 20-30mins of driving it goes away.. but i only hear it going over bumps someone told me the rack & pinion might be loose some people say Sway Bar end links, some say the top hat bearing maybe loose. am taking it to dealer on tuesday.
C24owner's Avatar
'08 E550 4Matic
They are almost done with them; so I hear. I will be calling them on Tuesday to get the details. I NEED to drop my 4x4 asap.
Old Apr 1, 2007 | 09:16 PM
C24owner's Avatar
'08 E550 4Matic
Mine usually does it after driving for a while and the car is all warmed up. Which makes me want to think that it has something to do with the power steering fluid. But I checked that and its fine. I have no clue at this point.
Old Apr 2, 2007 | 07:28 PM
C24owner's Avatar
'08 E550 4Matic
Dealership has no idea what the problem is. They cant replicate the sound and everything looks good under the car.
My SA wants me to take a drive with one of the techs.
I swear this always happens to me. I have a problem that is getting progressively worst and as soon as I take it in it goes away.
Old Apr 2, 2007 | 07:33 PM
WaveyKat's Avatar
Something Slow
yup its like going to the doctor you feel so sick at home when you get to the doctor everything seems fine it happens to me all the time everything i take the car for a tech to look at all the problems go away freaking benz like it knows when its gonna be checked out.
Old Apr 2, 2007 | 07:37 PM
alymo's Avatar
2001 c240, 65 MG Midget...5.0L V8
sounds like a ball joint or a tie rod end problem to me .. never had it on my benz but i had it on other cars in the past you can check both by lifting the car up so the wheel is in the air . hold the top and bottom of the wheel and jerk in and out ( so push the top in and pull the bottom out then reverse) if you notice any play then your ball joint is gone...do the same side to side (with someone holding the steering wheel steady) again any play will indicate a worn tie rod end
Old Apr 2, 2007 | 08:01 PM
C24owner's Avatar
'08 E550 4Matic
yep... that was the second thing I did.. there was very very very little play. Which makes me want to think that its something else. But I will mention it to the tech guy tomorrow.
Old Apr 2, 2007 | 10:22 PM
alymo's Avatar
hopefully it'll go alright ...let me know what it was ..just curious (i think that's how it's spelled )
Old Apr 2, 2007 | 10:45 PM
C24owner's Avatar
'08 E550 4Matic
will do.
Old Apr 3, 2007 | 11:41 AM
C24owner's Avatar
'08 E550 4Matic
Just got back form my drive with the tech.. He is almost positive that the problem is with the bearings in the strut assembly.
This means I now have an excuse to upgrade the suspension.
There is a 10% chance that the problem is with the u joint in the steering.
Old Apr 3, 2007 | 11:53 AM
WaveyKat's Avatar
Something Slow
Great i hope everything goes well.
Old Apr 3, 2007 | 12:19 PM
alymo's Avatar
i guess you can replace the tie rod ends while you're at it too, its a 2 minute job if the suspension is appart and then you'll only have to allign it once
Old Apr 3, 2007 | 12:47 PM
jgsx's Avatar
04 C32
My guess would be that it's your SPRINTBOOSTER! It is probably touching the steering column.
Old Apr 3, 2007 | 04:53 PM
C24owner's Avatar
'08 E550 4Matic
Thanks.. I hope it goes well also.
Yep... The whole suspension will be overhauled.Tie rod ends and new sway bar.
mother ******.. Thats the one thing that I didn't check... Problem solved
Old Apr 3, 2007 | 06:16 PM
RES's Avatar
RES
2005 C55, 1988 260E, 2000 Chevrolet Silverado
Don't forget the pesky thrust arm bushings. Check my tie rods warn post for the list of items Mercedes knows are a problem. They just like to sell parts and service.
Old Apr 3, 2007 | 09:31 PM
jgsx's Avatar
04 C32
Nah, it was his improperly installed sprint booster. You gotta shove all that slack cable towards the passenger side.
Old Apr 4, 2007 | 01:05 AM
RES's Avatar
RES
I think wraping it around the brake is better. I just used zip ties, zip tie everything.
