Aftermarket HID Conversion Kits & required setting XENON=PRESENT thread
Rating: Thread Rating: 64 votes, 5.00 average.
Old 05-27-2003, 01:15 AM
  #451
levelr123g's Avatar
you will need to run a relay off of the original lighting circuit to the hid's. this should work just fine without changing your setings and without any alteration to the interior switch.
Old 05-27-2003, 01:26 AM
  #452
Scylas's Avatar
C230 Kompressor (02 Copupe)
SOOOO....
If I do this...
I would always have the error msg on display because the computer would never find any headlights, right?
Old 05-27-2003, 01:55 AM
  #453
Scylas's Avatar
I dont know if I should sell my kit and lose $90 bucks (selling it for 300 when i got it for 390) and buy a new one, or do this bypassing ****... hm...
Old 05-27-2003, 09:48 AM
  #454
Scylas's Avatar
Unhappy ??
Old 05-27-2003, 10:23 AM
  #455
bajaiman's Avatar
01 C200 Kompressor, 02 C32 AMG
Quite a number of people have this flickering problem when they installed aftermarket HID, changing your computer setting to "xenon" present should fix it. Good luck
Old 05-27-2003, 11:06 AM
  #456
young's Avatar
GLB 250 4matic
it definitely turns off if the hids settings haven't been changed. but i do remember that brabusclass, i think, had the problem even after it was changed. i don't think it was ever resolved and he did something else.
i say don't panic and have the setting changed, and see if that works (as it should).
Old 05-27-2003, 01:07 PM
  #457
firstkill's Avatar
coupes seem to work fine when the computer is set to xenon present.
its the sedans that throw the error.
my hid kit works fine with the changed settings.. (philips kit)
~fk
Old 05-27-2003, 01:10 PM
  #458
BrabusCClass's Avatar
GL450, Sienna SE
Some people just worked fine by switching settings. Kineda used resistors and his works fine. Mine was just done strait to the switch. Im sure it will be ok.
Hey when did they get all these new smiles? Hmm.
Old 05-27-2003, 04:54 PM
  #459
blueC230K's Avatar
2002 W210 M112 | 2021 X247 M270 | 2015 Audi SQ5 | 2015 VW Golf R
Thumbs up I just installed mine too!
Make sure turn on the lights WITHOUT keys in, wait like 10-15 seconds, then start the engine. This way works fine for me. The only complaints that I have is that the lights was yellowish in the beginning, but it is better now. I have 6000k.
Old 05-27-2003, 06:37 PM
  #460
clotzki's Avatar
Hei,
I had the same problem too if you look at my previous post. Installed the aftermarket HID, they will only flicker when you turn it on. Im scared to death now everytime I drive cause I dont know if they will just shut off automatically. As I've heard from people, all you need to do is reset the check engine to 'xenon present', which I havent had a chance to do. But I will give that a shot. My symptoms is i have to turn on the light before i turn on the engine, so that's kinda bugging. I want to be able to work it as normal, so I'd definitely post the after results when the dealer reset the check engine. Do you know if this is a non charge service from Mercedes??
Thanks!
Old 05-27-2003, 08:59 PM
  #461
Scylas's Avatar
UPDATE ON MY HID's
Ok MB of ft.lauderdale suxks ***.. would nto even touch the computer....
so I drove up to Autohaus in Pompano, and they helped me out....
after I came back to pick up my car and I paid I checked the lights and guess what, "not working" ****.. so they took it back to the shop and they told me they tried everythign btu could not get them working, the settings are on Xenon but they still only blink just for a little longer.
They told me that it is because the lights use too much energy, and the computer sends a signal to turn it off.. So well Im stuck without lights and cant drive at night, Im pretty pissed off and dont knopw what else I can try. I dont want to wire it like BrabusCclass directly to the switch.
What did Kineda do?
any suggestions?
IU might try to get $350 on ebay and get the HID4less ones..
Old 05-27-2003, 09:01 PM
  #462
GL450, Sienna SE
email Kineda on Csportcoupe. Or ill try to have him post here.
Old 05-27-2003, 09:05 PM
  #463
Scylas's Avatar
thx...
I PM him and posted a msg on sportcoupe...
Old 05-27-2003, 09:29 PM
  #464
Scylas's Avatar
hm..
Brabus could u please xplain me your setup... I might end up doing the same thing you did if I dont fidn another way around.
They told me in the dealership it had something to do with the wattage or something... so I dont know if theres a way around...
Old 05-28-2003, 02:30 PM
  #465
TimmyC230boy's Avatar
Location: Sitting behind thing freakin desk of mine. Dreaming I was playing my Taylors, and driving my Benz. Long Live The VRAA!!!!!!
C230 Sports Coupe
Re: hm..
Your Stealership is BS'ing you big time. The Xenons only use 35watts of power, where the halogens use 55watts. The Xenons will also burn cooler than halogens too.
I still think there is a way to use a certain ohm resister to cut the 55watts of power coming from the computer, to the 35 watts required for the xenons. Thus still letting the computer send 55 watts, and not setting off an alarm, and allowing the xenons to get there 35 watts. Any electronic people know what value we would need to put in series?
Old 05-28-2003, 02:46 PM
  #466
Scylas's Avatar
well....
they told me something close to what u told me timmy... still after changign the settings to xenon the lights last a little logner but still go off afetr a second...
I heard kineda used a setup using resisters or soemthign like that but seems like hes not around...
Old 05-28-2003, 03:34 PM
  #467
levelr123g's Avatar
ok do what i said,
also measure the resistance of a stock light bulb, you will need to show this same resistance with a resistor across the wires b4 the relay and you will not have an error message.
Old 05-28-2003, 04:14 PM
  #468
firstkill's Avatar
How did the shop wire the HIDs?
I actually had to cut my stock wires..... and it works fine
Some people used these spade things to plug the HID ballast into the sockets of the halogen bulb.
~fk
Old 05-31-2003, 09:03 AM
  #469
CarlssonCRS's Avatar
r171
yea thats right. when you turn on your lights after the engine is running, they demand power and the computer will automatically shut it off. this is the same problem that you will get if you installed the bi-xenons. you will need to take it to the dealer and have them reset your computer to have xenons on. usually with the bi-xenons we have to kinda bribe one of the technicians workin at the dealership cuz MB doesnt want people changing their headlamps from the normal ones to bi-xenon.
Old 05-31-2003, 05:22 PM
  #470
fat_jim10's Avatar
will the aftermarket hid kit harm the warrenty??
my car is leasing right now, i would like to know is the hid kit harm my warrenty??
Old 05-31-2003, 10:43 PM
  #471
clotzki's Avatar
CarlssonRs...
Thanks for your reply. One more thing, for Xenon reset , does the Dealer usually charge you ? or that's something you can negotiate? And also one thing, is it safe if I just turn the light on everytime before I turn on the engine?
Which Dealer would you recommend for me to go? How about santa monica w. simonson or bhills?
Old 06-01-2003, 12:53 AM
  #472
r171
clotzki - the dealer wont do it for you. the way we do it is have a technician who works there do it for us. this install usually cost about $150 (more of a bribe that labor).. pretty much he will reset your system to have xenons on.... we have a guy who will do it for us at Downtown LA motors....
Old 06-01-2003, 12:18 PM
  #473
levelr123g's Avatar
no
Old 06-01-2003, 01:28 PM
  #474
tifosiv122's Avatar
SLS AMG | S65 AMG | GL550
I think it would.
You might want to check with your dealer first. You can call without giving your name if you don't want them to know its you.
Erik
Old 06-01-2003, 01:48 PM
  #475
Harris's Avatar
warranty of what???.....for anything related to the headlight system - yes. Because you'll be changing the wiring and harness. And I am 100% sure that your dealer will say "Yes" because no dealers would recommend any MB owners to put any aftermarket stuff on his car. If you want to put aftermarket HID, be prepared to take the risk.
You have already rated this thread Rating: Thread Rating: 64 votes, 5.00 average.
Quick Reply: Aftermarket HID Conversion Kits & required setting XENON=PRESENT thread
