Aftermarket HID Conversion Kits & required setting XENON=PRESENT thread
#1127
Stage 2 C7 A6, QX60
I don't know if the prolumen kit will throw obc error or not, but I do know that it shouldn't throw one on bimmers, not sure about mercedes.
anyway, if you want to install it, here is the installation wrote by Tangerine
https://mbworld.org/forums/showthrea...&highlight=hid
#1128
yeuchau, thanks for the link. I forwarded it to my friend and he installed it by himself. Surprisingly, the HID kits work......... but with one caveat. The bulbs flicker about 10-15 minutes after he switches the lights on. Is this normal? or is it because of not having xenon=present? Thank u.
#1130
2004.0 C230 Sedan
Does his dash show a check headlight error message? If it does, then he definately needs the xenon=present setting done. When the error message comes up, the correct voltage/wattage does not get sent through the headlight wires, hence causing the flickering.
#1131
no error message on the dashboard. First time he turns the lights on, they flickers for 10-15 seconds, then they're fine. He turns off the lights and back on again, this time takes only 8 seconds to be steady.
I did a quick search on the forum regarding to the flickering thing.
There are some possibilities:
1. xenon=pressent
2. add resistor/capacitor? (I don't know which one since I don't have expertise in electrical stuff)
3. bad ballast/ignitor/kit?
Since there was no error message, is it safe to ignore the item #1?
1. xenon=pressent
#1132
consider this thread....
#1133
Stage 2 C7 A6, QX60
i've also heard some people had this problem only when car is cold
so maybe try it again when the car is warm up and see if it still flickers
good luck
Michael
good luck
Michael
#1135
Super Moderator
just wondering if any one has tried any hid kits from this guy http://cgi.ebay.com/ebaymotors/H7-XE...mZ110149423806 i emailed him and he says that he hasent had any problems with c class's but that could be a lie i also was wondering about the wattage halagon takes 55 but the kit is 35 would that damage the hid kit or the car in the long run or am i just an idiot thanks
#1136
04' C240 4Matic
#1137
Is @ Home
Actually the 35 watt consumption is better, it releaves power which could be used by other devices like audio amps, mega ray guns, and super neutron blasters. Seriously, it wouldnt be a problem. In regards to the compatibilty of the kit, there are only a hand full of kits that are true C-Class plug n play... (Carlabs, MTECH etc..) My recommendation is go ahead and have the car programmed for XENON=Present, it will save you the hassle when buying inexpensive HID kits.
#1138
04' C240 4Matic
Nope, its better to go for a better (and sometimes more expensive) kit than to get an inexpensive/crap kit. Siemens is by far the best brand for after market HID kit that you can get for Mercedes. Their failure rate is the lowest in the industry and it does not set off the xenon error message. When I got my Siemens kit it was priced lower than those of Carlabs/MTECs.
#1139
Is @ Home
#1141
Is @ Home
Go to this thread.
Link
In the first post has the seller's info and website link. Although he does not have the kit listed he does have it. Your gonna have to contact him and tell him that Tangerine sent you.
Link
#1142
which do you guys think would match best w/ piaa 6600k? (TERA'S)
i mean it would make sense that by number it would be 6500k tera's, the fact that they are made by the same manufacture.
When i think about the 6600k, this is the output i expect to see:
<courtesy of mj50>
![](http://c24.fear50.com/pics/d2s/d2s3.gif)
![](http://c24.fear50.com/pics/d2s/d2s7.gif)
![](http://c24.fear50.com/pics/d2s/d2s8.gif)
<courtesy of north 44 c55>
![](https://mbworld.org/forums/attachment.php?attachmentid=49838&d=1113829920)
Now MJ50 said that theirs no purple, but in those pictures i see purple.
This makes it difficult for me to match up kelvins by photo.
and when i picture the 6500k it looks like this:
<courtesy of cntlaw>
![](https://mbworld.org/forums/attachments/c-class-w203/89611d1156644353-aftermarket-hid-conversion-kits-required-setting-xenon-present-thread-img_2413.jpg)
![](https://mbworld.org/forums/attachments/c-class-w203/89609d1156644353-aftermarket-hid-conversion-kits-required-setting-xenon-present-thread-img_2378.jpg)
So yeah maybe the 5500k would go ok, what do you guys think?
<courtesy of mj50>
#1143
#1145
#1146
01' C32o
hey, i just got a used phillips hid to mess around with, and after i installed everything and turn on the car, the headlight just flickered for half a second and died, and then 3-4 seconds later the headlight would flicker again then die, in a cycle. i didn't expect it to work, but is this normal, the flickering on, then off for a few seconds, then a flicker again and off? i mean, it is a phillips brand kit, 4300k. if i get the xenon-present option changed will it work? or is the bulb/ballast bad and need to be replaced? these are used. please help me guys, i'm so frustrated.
#1147
#1150
2005 White C230 SS
wow, after this long time ppl still reply this topic. I just want to let you guys know that I shipped my car back to Taiwan already, and yes, both 6000k and led bulb are still running without any problem.
