Aftermarket HID Conversion Kits & required setting XENON=PRESENT thread
#1201
04.5' C230 SS
![Talking](https://mbworld.org/forums/images/icons/icon10.gif)
Whats up fellas! Im trying to upgrade my stock headlights to HID headlights w/ballasts...anyone know whats a relaible brand to buy...i know there is some fake crap out there...so im trying to buy good stuff! Has anyone heard of mtec brand? is it good? if you know where i can get some let know please!! thanks guyz!! Im going for the bmw color HID they have...how many kelvins is that? 6000k?![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
btw its for my 04 sports sedan
#1202
04.5' C230 SS
#1206
i hear good things about the slim jlevisw ones
http://jlevistreetwerks.com/store/Me...29f3947a60e56b
i think they're a sponsor so i hope i dont get in trouble
#1207
try www.f1spec.com
#1212
Stage 2 C7 A6, QX60
I had techonehid before, and didn't require setting xenon to present.
and stock bmw HID should be 4300K, as well as Mercedes and other oem HIDs.
#1213
#1214
2002 C230 coupe , NOt THE AVATAR!!
#1215
#1216
2003 SL55, 2010 C63
I have a brand new 9006 kit 8000K that I bought for my fogs but I found out the new fogs on my bumper are H3. It has the original box and everything. If you want, you can have it for $80 plus shipping. I think I paid about $100.
Andy
Andy
#1217
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
MERGED
#1218
04.5' C230 SS
what the difference between all the different types they have....so for 04' sport sedan it would be hid type h7?
#1219
2003 SL55, 2010 C63
Andy
#1222
'08 CLK320CDI AMG// '13 E500 Coupe AMG// '17 E350d AMG
Xenon Bulb Help!?
I bought 2 new bulbs, Osram xenarc same as I have in my headlights.
I installed them and surprise, the light is yellow!!
I know it could be for being new bulbs but, so yellow! I never saw a new car with yellow xenons!
Other thing, any one have instructions how to install the xenon bulbs!?
I install it but the ligth is out of the place, its not aligned!! I removed and installed it several times and can't figure out how the bulb is supposed to be!
Before I install it the beam was projecting good...
Any help please?
Any help please?
#1223
The lamps need a few minutes of "seasoning" when new to reach the final colour. Your lamp must also be very clean when it is installed. The outside and the terminal area should be cleaned with a lint free cloth and isopropyl alcohol. The alcohol should be 99% or better. The connector must also be wiped down with alcohol. You should wear gloves, and be sure the lamp is fully inserted into the housing. The 30,000 volts used to start the arc in these lamps must be respected. If you have an implanted pacemaker, you should pay someone to change lamps for you. When cleaning the lamp socket, if you see any carbon tracks, you must replace the connector. The carbon imbeds in the silicone rubber and cannot be cleaned.
There are a lot of counterfeit lamps in the market. Chinese made copies of Osram and Philips lamps do not meet colour temperature or even dimensional specifications of the OEM lamps.
This might be why your beam is not good. The lamp base is just glued on by hand on counterfeit lamps, versus a precision jig used in the Osram factory.
#1225
The code and model of the lamp are the same of my stock ones, and the seller was a respected seller... so I will install it and wait to see the result.
For the install any guide or tips to do that!?
I'm struggling to put the bulbs right! they look right after I pressed the clip, but when I turn on the lights they are not aligned!!
