Sponsored by: Red Tiger
Speed Sensitive Rack installed
Old Apr 11, 2007 | 07:04 AM
SUNILP's Avatar
2015 E250D
I did this mod several months ago and forgot to post details on it. It makes a world of difference especially with 17 or 18" rims. The system stiffens the rack at higher speeds and makes it loose at lower speeds. Not a great picture but here is my old rack I removed.
Old Apr 11, 2007 | 07:54 AM
benzmodz's Avatar
W203 slightly modified
After the operation did you put the old rack in a jar filled with alcohol.
Old Apr 11, 2007 | 08:06 AM
nlpamg's Avatar
Super Moderator Alumni
2019 GT3 RS, 2017 M3 30 Jahre
wow, that is impressive! but not surprising considering all your other mods!
so you basically upgraded to a late build 2006 rack? what was involved? any software modifications?
Old Apr 11, 2007 | 08:58 AM
WaveyKat's Avatar
Something Slow
damn i just got my Rack replaced 2 days ago "Chit" how much does this RACK cost?
Old Apr 11, 2007 | 09:13 AM
jgsx's Avatar
04 C32
OMFG! I WANT! Send me the details.
Old Apr 11, 2007 | 12:27 PM
Code3 Performance's Avatar
C32, Cobra, 700hp Vespa
Very interested as well. With 100k miles, its time to take care of it. If I can upgrade, I would rather
Old Apr 11, 2007 | 12:49 PM
flush's Avatar
2003 C32
ok, I'll bite what is a speed-sensitive rack?
Old Apr 11, 2007 | 12:50 PM
drexappeal's Avatar
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Dr. Sunil. You are just out of hand ridiculous!
Old Apr 11, 2007 | 12:56 PM
Saprissa's Avatar
From: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
Dr. Sunil,
simply amazing ! Tell us more.........
Carlos
Saprissa@aol.com
Old Apr 11, 2007 | 04:06 PM
pshek's Avatar
2003 C-Class Sportcoupe
Cool. I want that, but will it make a difference on cars with coilovers? More details please on function, etc.
On a related note, BMW M3's have an engine-speed sensitive hydraulic assist unit equipped with a special power steering fluid pump on the steering rack. The result is greater steering effort at low speeds in trade for sharpened road feel and response at higher speeds.
Old Apr 11, 2007 | 04:22 PM
Blake P's Avatar
'09 A4 S Line
Originally Posted by Saprissa
Dr. Sunil,
Old Apr 11, 2007 | 06:42 PM
SUNILP's Avatar
2015 E250D
The rack is a pretty straightforward swap. A lift really helps. On earlier w203 cars (2001), will require a special wire harness and control unit. Later cars can have the steering rack wired directly to the ESP module. It does help at low speeds GREATLY. It's a matter of personal preference and I prefer to have a easy to move steering wheel at low speeds. I felt it was too stiff after I went to 17" and later to 18".
Old Apr 11, 2007 | 06:45 PM
rlee02135's Avatar
2004 C32 ///AMG
amazing mod! is this the one from the newer sedans with looser steering?
Old Apr 11, 2007 | 06:50 PM
Saprissa's Avatar
that's the first thing I noticed when I drove a 2006 C230 loaner this past week. Steering play on both my 2003 C-SC and 2004.5 C-SS are not even close to what I experienced.
So is the swap pretty much direct ? No need to re-program modules, other electronics, or weird sensor deals ?
Carlos
Saprissa@aol.com
Old Apr 11, 2007 | 06:58 PM
rlee02135's Avatar
2004 C32 ///AMG
$1060 retail....
http://boston.craigslist.org/gbs/pts/308791790.html
Old Apr 11, 2007 | 07:09 PM
nlpamg's Avatar
I never new that. it makes a lot of sense now...
Old Apr 11, 2007 | 07:28 PM
SUNILP's Avatar
2015 E250D
the swap is direct. Nothing fancy required as long as your ESP module supports parametric steering.
Old Apr 11, 2007 | 07:29 PM
SUNILP's Avatar
2015 E250D
Originally Posted by rlee02135
That's actually a steering column. Not steering rack.
Old Apr 11, 2007 | 07:35 PM
Would you mind posting the appropriate part numbers needed. My rack is in need of replacing, and I would love some more low speed help. I am on 18's and COs right now. After six shoulder operations, anything helps.
Old Apr 11, 2007 | 07:45 PM
WaveyKat's Avatar
Something Slow
how can you tell if your car supports parametric steering
Old Apr 11, 2007 | 10:06 PM
SUNILP's Avatar
2015 E250D
Steering rack part no. is
203-460-1300 up to chassis a666024 (check the last digits of your VIN)
203-460-5200 from a555897
Basically first one is for 2001-2004
second one is 2005-2006
To check your ESP, 213 PML may be stamped on the front of it. Check engine bay.
OLD ESP no. are weeded out of EPC but the current ESP modules are
209-545-0832, 0932, 1032 which all support this mod
If you must replace your rack, might as well replace it with this rack and update the ESP module later on. The rack will function as a regular rack if you don't have it wired up.
Old Apr 12, 2007 | 12:06 AM
So for an 02 that wants to update to the latest rack, we should purchase 203-460-5200?
Old Apr 12, 2007 | 12:45 AM
Saprissa's Avatar
I was going to ask the same thing.
I knew there was a catch !
So, I take it these part #'s are for the W203 Sedan...
what about the CL203 Coupe ???
Carlos
Saprissa@aol.com
Old Apr 12, 2007 | 06:59 AM
SUNILP's Avatar
2015 E250D
No, since you have an 02, you have to get the earlier rack. Carlos, I'll check part no's on the coupe but I think they are the same as sedan.
Old Apr 12, 2007 | 11:50 AM
So just to verify for sure before I order.
203-460-1300
This one, although for the older model, will be speed sensitive? Also, this will work for the C32?
Thanks for the help!
