AC dont work, blows warm air.
Old 04-24-2007, 01:40 AM
advans's Avatar
C55 ///AMG, 535xi
Originally Posted by LuxuryC240
LOL I was trying to comprehend the manual today...they write it in such a confusing way. I just turned the vents to 64 and full blast, and it was pretty cold. Is that the ac? Do I even touch the AC button?? From what I read in the manual and what advans has said, the red light is no good. Is that right? Can someone try to clear me up?
my AC OFF button constantly stays on, even if I press it, its still a "red light" and the yellow light (or was it red as well) where "rest" is supposed to be on, it doesnt turn on. no diff.
Old 04-24-2007, 12:37 PM
netboy's Avatar
2003 C320 coupe/c450 in Feb 2016
i got the same problem 2 years ago, i got it fix under warrenty. the dealer said the pipes is loose.
Old 04-24-2007, 01:05 PM
raymond g-'s Avatar
99 E320
EC stays on is a safety feature....keeps compressor off so it' s not damaged.
Not familiar with 203....any chance you have similar onboard diagnostics as we
do with W210s?
read this first....
http://www.eclassbenz.com/node/27
...diagnostics
http://www.eclassbenz.com/acdiag
Old 04-24-2007, 08:16 PM
advans's Avatar
C55 ///AMG, 535xi
thanks guys! i did schedual an appointment about a 1 1/2 weeks from not for another engine oil leak. im gonna tell them the AC doesnt work as well.
Old 04-24-2007, 08:18 PM
KIRA's Avatar
2002 C230 coupe , NOt THE AVATAR!!
do you drive naked?
Old 04-25-2007, 09:53 PM
Arn560's Avatar
Black 04 C230 Kompressor SS
Mine works just fine. I'm trying to figure out how to sell you guys some cold air!
Old 05-01-2007, 11:23 PM
  #32
buddy333's Avatar
Hey Avans, thanks for posting on my thread.
I read yours and I'm interested in finding out what the dealer finds about the AC problem we're both having...
Have you taken it in yet?
I don't really have a problem with any of the indicator lights that people are talking about.
I have automatic climate control (maybe they all have them) so the AC turns on automatically... I believe I'm able to turn off the AC by pushing the button to the right.
The only thing that happened to me is, I had a high pitched wistle whenever the air is on (hot or cold, louder when cold) and then the AC stopped working.
BTW, I have a 2002 C240... and moved to TX 2 months ago...
It be HOT....
Old 05-02-2007, 07:47 AM
  #33
advans's Avatar
C55 ///AMG, 535xi
ah I see, I havnt bought my car in yet. But Its schedualed for next tuesday. we'll see wth is going on.
Old 05-02-2007, 07:56 AM
  #34
raklert's Avatar
C200K W203
If the AC blow strong but not cold then probably your coolant is not delivering right. Could be leakage or loose somewhere.
Old 05-03-2007, 10:25 PM
  #35
coin's Avatar
'06 CLK500
Brought my car in for service today after looking at this thread.
The stealership detected low refrigerant. They "evacuated and recharged A/C" with FREON 10th.
They charged me $133.20. Do you guys think I was raped ?
Old 05-03-2007, 10:40 PM
  #36
advans's Avatar
C55 ///AMG, 535xi
yeap. any warranty left on ur car?
Old 05-03-2007, 10:58 PM
  #37
coin's Avatar
'06 CLK500
When I went to pick up my car, my SA had already gone home. I was really shocked to see the bill though.
My original warranty has expired but I have the extended Starmarked.
Old 05-03-2007, 11:28 PM
  #38
advans's Avatar
C55 ///AMG, 535xi
hmm extended starmark warranty only limits certain things, my car is still covered under standard warranty, lets hope they pay for all this.
Old 05-03-2007, 11:37 PM
  #39
coin's Avatar
'06 CLK500
Good luck and keep us posted
Old 05-09-2007, 03:05 PM
  #40
C230SportsCoupe's Avatar
Update?
Old 05-09-2007, 04:52 PM
  #41
advans's Avatar
C55 ///AMG, 535xi
I'll update you, I bought the car in for service yesterday, the SA called me today and said they are still working on it,
but if you check the recall list, AC OFF CONSTANTLY LIT is a recall!
will scan my service sheet once i get the car back! hopefully tomorrow, I miss it already!
Old 05-17-2007, 08:18 AM
  #42
bump, what was the fix?
Old 05-31-2007, 08:20 AM
  #43
advans,
I have an apointment on Mon for no cold air, could you update this thread with what the fix was for your problem.
Old 06-10-2007, 12:09 AM
  #44
timstrats21's Avatar
C280
Are there codes for a 95 C280 a/c unit? My blows cold air for a minute or two after starting the car, then blows hot air and squeels a high pitched sound. I was told it could be a temp or pressure sensor. Help!
Old 06-10-2007, 12:25 AM
  #45
advans's Avatar
C55 ///AMG, 535xi
hey.
the fault was AC compressor. it jammed the code in the climatronic thing. and they measured the boost. it had about 30, they pumped it up to 40boost and replaced the AC compressor.
Old 06-10-2007, 08:14 AM
  #46
maryjcl's Avatar
09 E350
AC Recharging
I see a lot of people here speaking of relatively frequent AC recharges. Just an fyi, but you should rarely, if ever, need to recharge a properly sealed and functioning AC system. If you do, it means you have a leak somewhere. You can continue to recharge it, but it will only get worse until you fix it as most of the system is under some degree of high pressure.
I am surprised that shops or dealers would even recharge it. Most shops, when they see cars as relatively new as these, will try to find the leak before recharging.
Just don't want to see people pissing money away on refrigerant that will soon leak out due to a fault in the system.
Quick Reply: AC dont work, blows warm air.
