Just installed my OEM 2005+ Headlamps
03 C230K
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
The quality of the light output (using HID conversion kit) is terrible compared to my OEM frosted one. It has different beam pattern between the left and the right one. Damn.. Anyone has input? Do you guys have the same problem with me?
I think I am going to sell it and buy the depo projectors or back to frosted one.
The look is 1000X better with the clear but the output is 100000X worse...
2007 C350 SS
03 C230K
Does anyone has a light pattern using an HID conversion in an OEM clear housing or depo projector?
03 C230K
1996 MB E320 & 2010 Nissan Elgrand
But, how come your clear headlights generate a worse light output??
I thought it should've been a lot better and brighter compared to the frosted ones.
03 C230K
![Unhappy](https://mbworld.org/forums/images/icons/icon9.gif)
The frosted ones should give you a better light output compared to Depo headlights, unless you replace the projectors of your Depos.
2007 C350 SS
any pics of the light pattern on a wall?
03 C230K
I think something's wrong with the headlights.Why don't you try to play with the position of your bulbs (Ex:turning your bulb 360,and slowly)and stop turning when you see the best light output.
GL
GL
03 C230K
Does the Depo projector can be retro-fitted using the e55 projector?
I'm really not sure,SORRY.I read it here some W210 owners that have Depo headlights replaced their Depo projectors with projectors from Acura (TL,I believe).You could STTF and find out.I know this guy with Raymond-G or smth nickname did this for his W210.
03 C230K
03 C230K
I always noticed W203s with clear headlights( halogen bulbs ) had a better light pattern and output compared to frosted ones with halogen bulbs as well.
03 C230K
Yep. I agree with that. But if you use H7 conversion kit, the frosted is much better since the light does not spread as much as the clear one.
