Just got my '02 Coupe, suggestions on sound?
In a car you feel and hear the bass go up due to the pressure diference with the windows open. We would sometimes see a 2-3Db increase with an SPL meter when opening the windows on competition cars. The pressure in a car with the windows closed is pretty stable, it can not change as quickly due to the sealed environment. With a window open the pressure can change much faster. As well as alowing the woofer to travel quicker due to the lack of the sealed car holding it back so to speak. I actually blew 2 10's one day because some moron opened the rear door of the car as I was tuning the amp, and I overdrove the woofers just a tad. I had not had a change to turn the gain down yet. I was in the process. But as the back door opened it allowed those poor woofers to travel to the fullest and they seazed in there fully extended positions as the voice coil welder itself to the magnet.
'06 Lexus GS300 RWD, '07 Camry SE V6 auto, '91 190E 2.6 auto
Ussually you do it closed since in an IASCA comp they would do the SPL with the windows closed. And yes it does act as a bandpass enclosure when you open the window. Since you are changing the amount of air in front of the woofer it adds to the SPL by a few db. It has been a while since I have built and installed systems though. But sadly I am not buying the C230 for its sound system and I do not need a booming system anymore. I can have boom at home with my home audio if I want to listen to deep loud bass. The car is a mode of transport and as I get older I do not listen to loud booming music anymore. I just like good *** fill. The funny thing is that when I test drove the coupe I did not even turn the radio on. If I do not like it I will add my own system later. But I am getting the Bose, so I am sure it will fulfill my audio needs.
Originally posted by x15jq
Thats exactly what I would like to do!
Where did u tap the line to get it to the amP?
Is it really hard to run a line back from the HU to hook up a sub and amp in the trunk?
I think the sound is great but the bass just muds out the rest if its loud.
All i want is a dedicated sub!
Thanks BlackC230Coupe!
Didnt want the post to turn into a flaming war against what a real system is.
Hey its your car, if I want a subwoofer for some more bass so be it.
I personally dont listen to my stereo super loud, just that the bass distorts the rest of the sound when its up high.
So I figure if i get a sub, I can lower the bass down on the standard speakers so they dont get mudded out.
Thats all.
Thanks everyone!
Thats all.
Thanks everyone!
Hey don't get me wrong, I did not listen to the Stereo yet. I will buy the car no matter what the Stereo sounds like as I can add to it later if need be. I am happy to see that adding an amp is relatively painless, because that is what I will most likely do to retain the wheel controls. So best of luck in adding the amp and sub.
#33
Thats all.
Thanks everyone!
Thats all.
Thanks everyone!
goodluck
#34
Moderator, please read...
Moderator, please read this unsolicited e-mail I received from "hokusbenz", aparently for daring to have a different opinion than him ...
Subj: your big mouth
Date: 10/7/2002 2:39:11 PM Eastern Daylight Time
To: jcbanville1@cs.com
This is a message from hokusbenz at MBworld.org Forums ( https://mbworld.org/forums/index.php ). The MBworld.org Forums owners cannot accept any responsibility for the contents of the email.
To email hokusbenz, you can use this online form:
https://mbworld.org/forums/member.ph...rm&userid=2695
OR, by email:
mailto:hokus208@aol.com
This is the message:
shut it
----------------------- Headers --------------------------------
Return-Path: <Webmaster@MBworld.org>
Received: from rly-xb01.mx.aol.com (rly-xb01.mail.aol.com [172.20.105.102]) by air-xb01.mail.aol.com (v89.10) with ESMTP id MAILINXB11-1007143910; Mon, 07 Oct 2002 14:39:10 -0400
Received: from VIA-SMTP.imconline.net (imc-015.imconline.net [207.141.150.55]) by rly-xb01.mx.aol.com (v89.10) with ESMTP id MAILRELAYINXB15-1007143852; Mon, 07 Oct 2002 14:38:52 2000
Received: from ded-047 ([207.141.150.102]) by VIA-SMTP.imconline.net with Microsoft SMTPSVC(5.0.2195.5329);
Mon, 7 Oct 2002 14:38:31 -0400
Date: Mon, 07 Oct 2002 14:38:31 +0500
Subject: your big mouth
Message-ID: <VIA-SMTPYe4nhrKtzcb0001c3d6@VIA-SMTP.imconline.net>
X-OriginalArrivalTime: 07 Oct 2002 18:38:32.0082 (UTC) FILETIME=[BC8FC720:01C26E30]
Is this acceptable behavior by a member of this forum? I HOPE NOT!
thank you for your attention
Jim Banville
OR, by email:
shut it
Jim Banville
#35
I dont think its appropriate to just invade my thread with you and whoever else's flames.
At least he didnt cuss you off, only 2 words.
I know its tempting, but its hard as hell to get answeres to our questions when everyone starts flaming each other.
Lets try to get along!
#36
Did you figure out what you wanted to do yet. Personally I would add an amp and a small sub. Maybe even a bazooka if you want to save space, or a bazooka type woofer, one with an amp all built in. Here is a link to what a guy did with his Bose system. Only diference would be getting your signal from the speaker wire behind the deck.
https://mbworld.org/forums/showthrea...threadid=18680
#38
Behind the deck? Im pretty lost with the c coupe, the speakers all in the doors, so would the wire come out of the door to tap signal?
Im confused
Hehe thanks everyone!
Im confused
#40
Take what you read on here and form your own opinion. We should be all adults and not children.
It all depends on what type of bass you want; jazz/classical type or rock/pop type.
Pick and choose; then compare to what your friends system sound like and then make your choice.
All advice is good advice. It stimulates the brain.
#41
