FYI - Signal Lamp Info
2001 C240 6spd
To all older 203 C-Class owners (01 and 02)...
I went to the MB dealer today when a Malfunction message showed up on the screen - Left front signal lamp was out. Evidently, according to the tech, the older bulb assembly units short and the contacts have a higher incidence of burning out - this may be a problem for those who live in hotter climates. They are replacing both signal lamps with a newer design bulb assembly. So, if anyone who has this same problem - it may not be the bulb, but the assembly unit itself.
Scott
Scott
03 C320 Sedan
Re: FYI - Signal Lamp Info
I had an 01 C320 that had that same problem on the front left (driver side), turn signal. They eventually replaced the whole headlight.
2001 C240
Same Problem
I live in Scottsdale, Arizona and I had the same problem. I had the right turn signal go out and the dealership replaced the bulb assembly unit with a newer version. They went ahead and replaced the other side also, eventhough the bulb was not out.
C200K (w204)
I live in Australia and 3 months ago my left indicator was out, they replaced the bulb and told me if the bulb burnt out again then they gonna replace the whole assembly
