W203 Question on Sirius/XM Users...
Old May 21, 2007 | 03:20 PM
TXKompressor's Avatar
2004.5 MB C230 Kompressor
I am about to order the XM tuner for my Z1 Avic...
I have a question about the Sirius/XM users.. Does the Mercedes W203 that can have sirius does it come from the factory with the antenna for Sirius?
Old May 21, 2007 | 04:50 PM
IsaacRN's Avatar
2006 c230
Yes it does. You can however always aftermarket xm/sirius without buying thier(dealership) antenna.
Old May 21, 2007 | 05:18 PM
good so if I already have an antenna in my car, where is it located?
Old May 21, 2007 | 07:04 PM
jlee-'s Avatar
c230k
most likely its on ur trunk
Old May 21, 2007 | 08:17 PM
then if that is where it is then I do not have one..
Old May 21, 2007 | 09:03 PM
Moviela's Avatar
The antenna is not installed on the cars at the factory through the 2005 model year. The sat antenna was installed on the trunk of sedans and the roof of wagons by the VPC (vehicle preparation center) or the dealer. Many cars had fiber optic cables labeled SDARS and a power/wakeup electrical connector. The installer had to make a 20mm hole in the sheet metal for the antenna. A tool called a "unibit" was specified because a drill would spoil the panel. The factory also specified some primer on the bare metal edge of the hole. The antenna itself has two cables that connect to cables going into the receiver. The antenna is black, but some folks had them color matched to the body color.
Old May 21, 2007 | 10:52 PM
Thanks Moviela.. I do not think I am going to be using my unibit on the body of the car.. I had my XM antenna on my old car under the bumber cover and it worked flawlessly esp. with the metal to so called ground itself to. sounds like that is where I will put it on my C. Since the bumper will be off to get re-painted.. They do not have GPS antenna's pre-installed do they?
