Finsh with all my HomeWork Tires,Coilover,Spacers,Tints its all here and done Pic.Vid
#53
'09 A4 S Line
Like I've told you before, it's very possible you will have rubbing issues by adding the spacers when you have passengers or hit bumps/dips where your rear tire goes up into the wheel wells slightly. I think you're asking for trouble.
#55
BMW 135i
#56
![Nx](https://mbworld.org/forums/images/smilies/nx.gif)
But the tuner's dyno is broke and he said by Fri it should be repaired, so it'll hopefully be next thurs that I get the bottle plugged in. For now, I'll have to settle for the good old V8 lol
Peace
#57
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
The Invo's are tight! My cousin has those on his galant 235/35R19. They've got a really cool tread pattern, they're decently sticky, and no/very little squeaking. Only problem is they are very rare right now, so hard to get. 260 treadware rating isn't bad.
I may try those next, if they have a 265/30R19 by then. Still have a lot of tread on my tires.
#61
BMW 135i
#63
BMW 135i
#65
BMW 135i
#66
2004 C32 ///AMG
![](http://i64.photobucket.com/albums/h163/rlee02135/DSC03059.jpg)
not like this:
![](https://mbworld.org/forums/attachments/c-class-w203/106304d1180241624-finsh-all-my-homework-tires-coilover-spacers-tints-its-all-here-done-pic-vid-picture-236.jpg)
the piece to adjust the ride height should be on top, not the bottom.
what can go wrong?....would you really like to find out?
would you install your tires in a backwards direction? or reverse the connectors when installing the battery?
best idea would be to take it back and reinstall correctly ASAP.
#67
BMW 135i
this is the way it should go:
not like this:
not like this:
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
anways im going NOW
#69
BMW 135i
my shop told me this is how it has to be installed . thats how they been doing it all these years with bilsteins...tein and bilsteins are diffrent, i am gussing they are diffrently designed.. i called bilistein and they told me that the perch has to be on the buttom of the spring... i see that FRANK W has also tein coilovers.... ONLUN 9 said that he has it the same setup as i do and he has PSS9... so i guess diffrent coilover design?
#71
BMW 135i
i guess so . i mean if it was installed the wrong way wouldnt i feel something wrong? even though i called bilstein and told that the spring has to be ontop of the perch. Im going to also call CarLab and ask them also..
#72
I've never seen coilovers where the spring perch is on top of the springs and not below. Hmmm...interesting.
#73
BMW 135i
#75
BMW 135i
i went low i guess.. as you can see in one of the pictures i had a
tape measure. the gap between the tire and the fender is 1 inch FOR the front... and the rear i can hardly squeeze my finger in-between the fender and the tire (lol) but theres no RUBBING
