Cold Air Intake
Old Jun 6, 2007 | 07:38 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
Originally Posted by advans
haha robert.
My snorkle tubes were burning hot today! I remember seeing frank having these insulating tapes.
anyways, while we are on subject.
DOES ANYONE KNOW IF THE NEW 350/280 kevlar snorkle tubes would fit the prefacelift ones?
what the hell, im gonna go buy one tomorrow!
i took the tape off. gonna get the insulation cloth instead. while it worked I want it to work better.
Old Jun 6, 2007 | 07:46 PM
advans's Avatar
C55 ///AMG, 535xi
I bought 2 kevlar tubes and 2 umnitza cf "tube things" for the airbox, should be cold enough!
Old Jun 6, 2007 | 08:52 PM
valexv's Avatar
02 cl203
so is renntech the only one who makes aftermarket air box? also has anyone tried the air intake resonator removal. another member posted how to do it but wanted some more feedback from other member if they tried it. any performance gain or just changes the sound. thank
Old Jun 6, 2007 | 09:37 PM
advans's Avatar
C55 ///AMG, 535xi
for? the M111 M271 engines?
Old Jun 7, 2007 | 01:42 PM
valexv's Avatar
02 cl203
sorry, M111 02 c230k
Old Jun 7, 2007 | 02:17 PM
nuclearhappines's Avatar
does anyone have the part number (and MSRP) for the stock snorkel ?
I want to get a spare one and hack it up to make a direct path intake where the filter sucks in from the closer grill hole...
Old Jun 7, 2007 | 02:18 PM
  #32
valexv's Avatar
02 cl203
Originally Posted by kompressor85
yes there is two 02 sensors that i took note of..... one where the pipe makes a turn and becomes parallel with the ground, and a second just past the cat converter.
also: to remove the intake resonator on M111 engine, remove stock airbox. the bolt on the right and hoseclamp on the left. remove the intake assy on the passengers side of the car (left hand drive car that is), which is a torx bolt or two. then disconnect the six bolts holding the bottom peice (big peice of aluminum) in place. now take that off of the car and remove the plastic peice. find an aircraft locknut to seal the hole that would be left. tighten. re assemble. its really rather easy, but requires a toolbox that has both internal and external torx.
well, i'm off to go fly a mission. ciao!
heres for the intake resonator
Old Jun 7, 2007 | 09:06 PM
  #33
Lsrevhard's Avatar
2005 C240
acually you can get your car alot louder but itll be a hot air intake like mine lol...but hey just my input cut the plastic that comes from your engine top slide to AEM cone filter on each one remove the filters inside the box by removing the torque screws under and youve got the sound of more air into the engine
Old Jun 8, 2007 | 12:02 AM
  #34
advans's Avatar
C55 ///AMG, 535xi
just take the stock "plastic" snorkle tubes off, and you'll notice a gain in sound. even with the stock airbox. that is what I have discovered.
Old Jun 8, 2007 | 12:31 AM
  #35
Lsrevhard's Avatar
2005 C240
ya and than you have the risk of stuff going into your engine cut the plastic AEM filter on each end there you go safe and loud
Old Jun 8, 2007 | 01:40 AM
  #36
advans's Avatar
C55 ///AMG, 535xi
actually, there is a higher risk with the stock tubes. I have discussed this topic with a known tuner on this site. dont want to point fingers or name names.
With the tubes off, there is more "space" for air, if you were anthuny85, you would understand what I mean. He has done this test. I even proved it to some local guys (who are mbworld members as well).
Working with this, I am developing something...some sort of a "better" intake for the M112 motors, and hope it fits the M113 motors as well.
Old Jun 8, 2007 | 02:23 AM
  #37
Outland's Avatar
2002 C230 Coupe(M111)
Time to cut that hood. A couple of NACA ducts would work great.
Old Jun 8, 2007 | 04:27 AM
  #38
c230ftw's Avatar
2006 C230
I have a 2006 c230 SS the air filters in it differ a lot from the c230Ks right? Is there anything i could do to make my car have the intake sound?
Old Jun 8, 2007 | 08:15 AM
  #39
Lsrevhard's Avatar
2005 C240
advans...i dont understand this is how mine looks...i dont see were anything could get into my engine
Old Jun 8, 2007 | 09:15 AM
  #40
sanf's Avatar
E53
nice, hows the sound of that thing?
Old Jun 8, 2007 | 11:54 AM
  #41
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
I'm all for people trying new and inventive things with the intake, but you do realize that this is less functional than the OEM setup, right?
This in essence has changed your intake from a cool air intake to a short ram intake. Instead of sucking air directly from the grille inlets to tubing, this is sucking more air from the engine bay as well, which will obviously be hotter air. The whole idea is to get cooler air (which is more dense) to introduce more oxygen for the combustion of fuel.
The OEM tubing blocks more of the hot engine bay air than your current setup. It may sound cool, but just realize that you also may be losing power (especially on hot days).
Old Jun 8, 2007 | 12:19 PM
  #42
Lsrevhard's Avatar
2005 C240
i know that i just love the sound please i cant feel a diffrence and its like 100 here so drive on bro
Old Jun 8, 2007 | 12:20 PM
  #43
Lsrevhard's Avatar
2005 C240
o and sanf sounds pretty loud lol
Old Jun 8, 2007 | 12:35 PM
  #44
drexappeal's Avatar
All good. Just wanted to make sure you were aware of it.
Old Jun 8, 2007 | 12:56 PM
  #45
sanf's Avatar
E53
Lsrevhard, what size is your cone filter? i just want to do one side of the dual intakes. at least i will still get some cold air from the oem one then. hahaha i just want some sound
Old Jun 8, 2007 | 01:07 PM
  #46
Lsrevhard's Avatar
2005 C240
aem the hole is 3 inches
Old Jun 8, 2007 | 01:09 PM
  #47
sanf's Avatar
E53
i have two cones at home with 3" input and it's no go. the 07 v6 only got enough room for maybe a 2" filter cone on the left intake and that's about it.. oh well.
Old Jun 8, 2007 | 01:45 PM
  #48
advans's Avatar
C55 ///AMG, 535xi
my intake setups...
heres a few types of intakes I have done for the car.
TYPE 1
TYPE 2
AMG AIRBOX
RENNTECH CARBON FIBER AIRBOX
DONE ON A CROSSFIRE 3.2 W112 MOTOR
*EDIT*
now i am working on 2007 Kevlar tubes for my renntech box. then with 2 mystery parts. lol, all I can say is that. its from umnitza
