Messages!!!
Old May 29, 2007 | 07:17 AM
Lsrevhard's Avatar
2005 C240
Messages!!!
Is there anyway that you can turn off warning messages i tinted my sidemarkers and took out the bulbs so it would be all black and now i have the messages poping up all the time!
Old May 29, 2007 | 07:40 AM
C24owner's Avatar
'08 E550 4Matic
nope.
Old May 29, 2007 | 09:32 AM
outaurleague's Avatar
w211 e500
lol damn Nick, didnt even give the guy hope. LMAO
Old May 29, 2007 | 09:35 AM
C24owner's Avatar
'08 E550 4Matic
Well, there isn't a way to turn off the messages.
Old May 29, 2007 | 09:37 AM
B189s's Avatar
1996 MB E320 & 2010 Nissan Elgrand
I thought you could turn off your DRL using star computer?!
Old May 29, 2007 | 09:39 AM
w211 e500
Interesting... I have never heard of that being done. wonder if it works ?!?
Old May 29, 2007 | 09:49 AM
B189s's Avatar
I know my friend had this done to his Bimmer and I thought 14cue mentioned smth about this too.
Old May 29, 2007 | 09:51 AM
w211 e500
That is pretty sweet. Imma look into that and see what i find.
Old May 29, 2007 | 10:03 AM
C24owner's Avatar
'08 E550 4Matic
You could turn off the DRL with out the star diagnostics. You can do it through the instrument cluster.
On the other hand, the side marker lights can not be turned off completely.
Old May 29, 2007 | 10:09 AM
JohnCL's Avatar
'01 C320 || '14 Honda Pilot EX-L
Yep, sure is...............
PUT THE BULBS BACK IN!
Old May 29, 2007 | 10:22 AM
w211 e500
2nd
Old May 29, 2007 | 10:25 AM
Lsrevhard's Avatar
2005 C240
i guess i could do that but i herd u can wire the negative and positve on the cable the bulb goes into and it will send a feed to the computer thinking the bulb is in there?
Old May 29, 2007 | 10:28 AM
w211 e500
I mean you can try it, Just dont fry anything or Merc is going to rape you. I would just leave it alone,
OR find a small black rubber cover of some sort and cover the wedge bulb that will not melt and your good !
I finally had my red bull now i can think ! yeah that is the safest way to achieve what your trying to do. and not worry about wiring.
Old May 29, 2007 | 10:31 AM
B189s's Avatar
Put the bulbs back and try to hide the bulbs inside somewhere,just remember someone posted this trick. You could spray the bulbs first before hiding it
Old May 29, 2007 | 10:36 AM
w211 e500
That too. Just leave the bulb plugged in and remove the wire and light from the socket. Tape it off or some sort Outta the way, and there you have it !
I dont want you posting a "Oh **** look what happen to my car while driving" Post about your catching your car on fire.
But yes that is another way to achieve your goal. Hope it helps, Also post pics !
Old May 29, 2007 | 12:20 PM
JohnCL's Avatar
I can tell you from experience that there is plenty of space to leave the bulbs in and tie them back. I had euro impact strips and no messages.
Old May 29, 2007 | 02:37 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
someone should make a 'blank' bulb so u don't get error message and not have to worry about bulb going out...
Old May 29, 2007 | 02:44 PM
johnand's Avatar
Super Moderator
2007 C230SS; 2014 ML350 BT
Should be easy to do, just select the right resistor
Old May 29, 2007 | 02:59 PM
jgsx's Avatar
04 C32
It's a 30ohm power resistor.
Old May 29, 2007 | 05:16 PM
c230 o5's Avatar
BMW 135i
why dont you just take the wire with the bulb and let it hang out from the sidemarkers. push the bulb out and just let it hang from the wire
just like i did.. simple as that
Old May 29, 2007 | 05:38 PM
rlee02135's Avatar
2004 C32 ///AMG
just wrap the bulb in aluminum foil. worked perfect for me.
Old May 29, 2007 | 05:46 PM
c230 o5's Avatar
BMW 135i
Why whats wrong with my idea
j.k
Old May 29, 2007 | 05:47 PM
rlee02135's Avatar
2004 C32 ///AMG
j.k
it'll melt the bumper.
Old May 29, 2007 | 06:02 PM
c230 o5's Avatar
BMW 135i
no it wont . its not touching the bumper
Old May 30, 2007 | 07:23 AM
Lsrevhard's Avatar
2005 C240
the foil wont catch on fire from the heat?????????????????????????????????????????? that thing get hot im guessing
