audio piolet
Old Oct 10, 2002 | 07:24 PM
firstkill's Avatar
audio piolet
or what ever the thing is that raises the volume of the stereo when there is more noise from driving.
anyone know if there is a mph to volume formula the computer uses? or is there some microphone sensor somewhere?
I was just wondering how the comp knows when to raise the volume and when to lower it.
thanks
~fk
Old Oct 10, 2002 | 08:22 PM
tberry's Avatar
2002 C230 Coupe Black/Charcoal C5 C7 Auto
i think its diff for Bose and non-Bose. I'd be interested in knowing how the Bose one work as well. My A4 had one but it was based on speed of vehicle (and u can adjust sensitivity via the headunit). From what i've read the C230 one is based on dB (then there's gotta be a microphone or something). Can anyone verify that?
Old Oct 10, 2002 | 08:23 PM
young's Avatar
GLB 250 4matic
i believe audio pilot has a microphone that measures ambient noise.
the speed sensitive volume adjustment is based on, of course, your speed - but i don't know the exact formula.
non-bose does not have audio pilot but still has the speed sensitive volume
from bose's website
http://www.bose.com/products/auto/tech-windows2.html
"How does AudioPilot work?
A microphone continuously monitors the total sound level inside the car- both the music you want to hear and the noise you don’t. Then, Bose digital electronics separate the music from the noise, and use a compensation algorithm to modify the signal continuously.
It’s difficult to achieve, because the signal modifications must occur as the music plays, noise enters the cabin, and the dynamics of each continues to change. But with the AudioPilot system, everyone in the car can enjoy all the passages - no matter how loud or soft - with no adjustments. And you and your passengers will perceive no change in the overall volume of the audio system. The volume adjustments are that smooth.
Bose AudioPilot circuitry is completely different from conventional speed-controlled car volume features, which simply raise the overall volume as the car increases speed. The Bose system "listens" to the noise, defines its character, then compensates for its presence by adjusting the specific musical tones affected by the noise. To properly engineer our AudioPilot system, we thoroughly examine the car's environment. This knowledge is an important benefit of the Bose “clean sheet” approach to car music system design, in which the vehicle and the sound system are engineered simultaneously from the ground up. "
Old Oct 10, 2002 | 10:27 PM
firstkill's Avatar
So if you have a subwoofer you can fool the sensor??? and then when ur not even moving it will turn up the volume?
~fk
MB-BOB's Avatar
Admin Alumni
See Garage
On the Bose cars, the microphone is that little black, square grill between the overhead console and the rear view mirror.
Old Oct 11, 2002 | 02:18 AM
Xeon's Avatar
"And you and your passengers will perceive no change in the overall volume of the audio system. The volume adjustments are that smooth. "
what a piece of BS !
Old Oct 11, 2002 | 09:38 AM
young's Avatar
GLB 250 4matic
don't get upset. it's not like bose has never made exaggerated claims.
i look at those kind of comments like when steve jobs give keynote speeches... "Mac are SOOPER DOOPER FAST HYPER SOOPER COMPUTERS... pc sucks."
Old Oct 11, 2002 | 10:17 AM
avlis's Avatar
2008 VW GTI
Personally, I liked the audio pilot. I wish the A10 had it. With the roof open, the A30 could adjust the EQ so that it sounded almost as good (or bad) as it did with the roof closed. I had the speed sensitive volume turned down to the 3db setting and it was nice after that. Now with the A10, the sound "goes out the window" with the roof open and I have to get the speed sensitive thing turned down again.
Old Oct 11, 2002 | 10:19 AM
bagwell's Avatar
From: Houston,TX-moving to The Woodlands,TX SOON!!!
Toyota Tacoma & Lexus IS250
another system that should be consumer adjustable....but of course its NOT!!!
try to explain to the dealer how to change the settings....quote "huh?? what r u talking about?" unquote
Old Oct 11, 2002 | 12:37 PM
avlis's Avatar
2008 VW GTI
Ha ha. What's worse than that: My service dept insists on phrasing my requsts for changes in the form of a problem (sort of like Jeopardy).
The first time I went in I told them to turn the speed sensitive volume setting down to 3db he said, "what's the problem?"
I told him that it was adjustable in 3 steps and to turn it down.
He said, "what's the problem?"
I told him that he needed to connect the Star computer to my car and change the setting for the volume to 3db from 6db but not 0db.
He said, "but what's the problem?"
"Oh I get it", I said. "The volume changes too much as I go faster or slower".
He says, "Ok. No problem, sir. I believe there is a setting in the computer to turn that feature down. We'll get on that right away!"
Old Oct 11, 2002 | 06:49 PM
jlm's Avatar
jlm
Open the pod bay door, please, HAL...
Old Oct 11, 2002 | 09:03 PM
peet's Avatar
09 C63
MB-BOB (and all)... I tried and unplugged that mic. No go. I still have the obnoxious volume changes - even though stealer said they set speed adjust to 0db as requested.
ARRGH.
Anyone working at a dealer wanna make a few bucks? Pirate a ghost image of the MB laptop hard drive
P
Old Oct 11, 2002 | 09:11 PM
preyx's Avatar
'02 C230K Coupe
Yeah, I noticed the audiopilot causes the volume to fluctuate much much more when I drive around with the windows open, especially on the freeway (duh!). I understand their need to adjust the volume for ambient noise, but sometimes it's just too much. The HU turns the volume up quite high at times, causing the sound to begin coming out distorted. Gonna ask them to change it at my next service (B service).
