View Poll Results: Opinion of the Panorama Roof
The Panorama Roof is a Necessity
![](https://mbworld.org/forums/images/polls/bar2-l.gif)
![](https://mbworld.org/forums/images/polls/bar2.gif)
![](https://mbworld.org/forums/images/polls/bar2-r.gif)
![](https://mbworld.org/forums/clear.gif)
107
75.35%
Take it or Leave it, I don't care
![](https://mbworld.org/forums/images/polls/bar3-l.gif)
![](https://mbworld.org/forums/images/polls/bar3.gif)
![](https://mbworld.org/forums/images/polls/bar3-r.gif)
12
8.45%
Forget it, Spend your money on a Pulley
![](https://mbworld.org/forums/images/polls/bar4-l.gif)
![](https://mbworld.org/forums/images/polls/bar4.gif)
![](https://mbworld.org/forums/images/polls/bar4-r.gif)
23
16.20%
Voters: 142. You may not vote on this poll
CL203 Coupe Pano-roof Maintenance - MB lube Grease Part #s, gears, & fixes
#101
2002 C230K Coupe
Originally posted by Big Dog
I had mine in recently for the rattling sunroof (not interior shades). They needed two days but were able to pinpoint the problem to loose bracket(s). Have had no problem with the sunroof since then.
BTW, bought mine at Euromotor as well and have had an MB loaner each time I brought it in. Ususally, the loaner has less than 5k miles. However, the last time I got a C Class wagon with a faulty fuel pump -- they replaced it with an E320!
Any chance they might have SLK as a loaner?
#102
2002 C230K Sport Coupe M6 C5 desert silver
I may have seen you the other day on Oakland Mills Rd around 6. Bad news. Herb Gordon (Silver Spring AutoPark) uses Enterprise for loaners. No Benzes. Right after I got my car it spent a week in the shop. I think I had a Dodge Status or something like. I was very glad to get mine back. No problems since. Knock on wood.
#103
2008 VW GTI
Anyway, this morning the noise was back
This time I used a silicone rubber "protectant" on the seal. While I was doing this I noticed the underside of the moveable panel was extremely dirty in the area where it contacts the seal. I wiped it all down and rattle is completely gone.
#104
2002 C230K Coupe
How come I didn't see your car then? When I drive I do look out
for other coupes....it became habit of mine.
Anyways...
Hmmm.....so Herb Gordon doesn't have benz loaner....that sucks
![Mad](https://mbworld.org/forums/images/smilies/mad.gif)
Maybe I should cancel my appointment and reschedule at EuroMotors.
#105
2002 C230K Coupe
Originally posted by avlis
I checked out the rubber seal again last night and found that the spray lube I had applied the day before had completely dried up.
they don't fix it correctly, then I'll follow your foot steps. Thanks
#106
Harpax I was at the light at Snowden west bound on OM. You were eastbound about 6ish. I was in the right lane next to a truck. I saw you too late to honk.
#107
2002 C230K Orion, Oyster leather, Auto, Sunroof, Bose, Teleaid, CD Changer
Sunroof Noises - Fixed
My C230K with 7,600 miles has had this fixed twice.
Around 5K miles it started making a nasty creaking noise from the right front of the sunroof. I took it back to Herb Gordon where I bought the car from and they fixed the creaking but it now had a rubbing/squeaking noise coming from the rear of the sunroof. Using Amour-All or Vaseline on the rubber seal would stop the squeaking for a couple of weeks.
After a couple of months, the creaking from the front of the sunroof returned with a vengeance. This time I tried American Service Center's new outlet in Alexandria, VA. They had the car for 3 days. They replaced the guide rails (had to remove the sunroof to do it) but their quality control person decided that it was still making noises so they replaced the rails again with another new set. Anyway the sunroof has been perfectly quiet since then (almost 2 months).
#108
Console Switch for Panorama Roof
Went to open the sun shade but noticed the one-time-back didn't work, then I was unable to open the glass at all. Got out and used the remote open with the key and it opened fine. I had heard there may be a way to reset the switch without going to the dealer, does anyone know anything about this?
#110
Thanks! If anyone's roof fails to open someday, remember that there are instructions on how to re-sync it in the owner's manual.
I believe there is a safety mechanism that will put the switch into this error state, like if kids are playing with it or if it attempts to shut with something in it (kids!).
#111
One-Time close button not working?
Hi Guys,
My Panorama switch works just fine for opening in the "auto" mode (opens to the preselected position pushing the button hard towards the back); however, closing the roof will not work in the auto mode (need to keep switch pressed for it to fully close). Is this normal?
Haven't tried to re-calibrate it, but sounds weird that it works fine in one direction and not the other!! Additionally you can 'feel' that the switch has like two stages or positions going towards the back; not the case going forward.
Thanks,
Gianluca/.
Thanks,
Gianluca/.
#113
2002 C240 6-spd (ret)
Originally posted by young
yes, it's normal. there is no one-touch close for the coupe...
like the older mb's...
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
#115
Re: panoramic sun roof
Originally posted by tomjaymac
How do you open the sun roof with the remote?????
Really, how can you drive a car without studying the manual in the first week of ownership?
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
#116
Re: Re: panoramic sun roof
#117
2002 C230K
![Talking](https://mbworld.org/forums/images/icons/icon10.gif)
#118
well, i took the car in a couple of weeks ago to get the rear roller shade fixed but it wasn't a 1/2 hour job as they thought - instead, it would be 6 hours... would i like to reshedule so i could get a loaner car (they ran out). ok.
took it back yesterday and they worked on it all day today. went to pick it up and he said it would never happen again. naturally, i need to test it.
1st thing i notice is that the shade fabric is running over (topside) the end bar rather than the bottom side (under and then around). also, they greased it and i can see the tracks, and the grease, and the fingermarks... hmmmm...
anyway, i get the service consultant and he gets the head technician and we discuss it... they're going to keep it another day, and try to fix it again, and of course, CLEAN it up.
i had a c320 wagon yesterday, got a bordeaux red c230k today (non-c7 so the shifter feels different
before i left, the head technician told me that the roller shade had been slightly redesigned in 10/2001 (mine is from 8/2001) so that some of the roller shade issues were corrected.
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
#119
#122
2002 C-Coupe
They fixed mine yesterday and said everything is fine. Guess not. Now the rear opens only halfway. They also damaged one of the rims and fingermarks all over the interior. I thought my VW dealer is bad.
