View Poll Results: Opinion of the Panorama Roof
The Panorama Roof is a Necessity
107
75.35%
Take it or Leave it, I don't care
12
8.45%
Forget it, Spend your money on a Pulley
23
16.20%
Voters: 142. You may not vote on this poll
CL203 Coupe Pano-roof Maintenance - MB lube Grease Part #s, gears, & fixes
Rating: Thread Rating: 12 votes, 5.00 average.
Old Jun 23, 2003 | 07:10 AM
  #176
cliffybabe's Avatar
CLK Coupe 200 Komp 53 Plate
I know had the same thing on my coupe in the end I went to Les Smiths and bought a can on windows lubricant and now its fine.
I know I shouldnt have to do it but I did and it solved it.
Old Jun 23, 2003 | 07:35 AM
  #177
tommy's Avatar
2004 Civic Si. FWD for the Win!
Re: Wished I'd never had Pan roof!!!
Originally posted by latent
But should I have to do this on this quality of car?
I think you answered your own question there.
My roof does creak, but I'm such a fan of it overall that I'm willing to put up with it. Also, turn your radio's volume up - works for me!
Old Jun 23, 2003 | 07:47 AM
  #178
avlis's Avatar
2008 VW GTI
I have heard some people say - just keeping lubricating the seals. But should I have to do this on this quality of car?
So the car is supposed to maintain itself?
I have to keep putting gasoline in my fuel tank because every few hundred miles the fuel reserve indicator comes up on the MFD. My dealer says there is nothing they can do and just keep telling me to gas it up. I never expected to have to visit a gas station with my new Benz!
Old Jun 23, 2003 | 07:58 AM
  #179
latent's Avatar
avlis
Sarcasm is the lowest form of wit
Old Jun 23, 2003 | 08:03 AM
  #180
jpb5151's Avatar
Does the manual mention anything about keeping the panoramic sunroof lubricated? I don't know the answer, but if not, I'd suspect that it's up to MB to keep it maintained.
Old Jun 23, 2003 | 08:09 AM
  #181
tifosiv122's Avatar
SLS AMG | S65 AMG | GL550
Thats odd...I have my car for several months now, 12,000 miles on her, I use the roof everyday its not raining, and no sounds out of the car when its closed at all. No rattles, squeeks, etc.
Erik
Old Jun 23, 2003 | 09:46 AM
  #182
mctwin2kman's Avatar
Well, lets see there is a big hole in the roof of your car that of course lessens the structural rigidity of the roof line and you wonder why it creaks. All moonroof's from all manufacturers squeak eventually. That is life, if you did not want creaks and squeaks you should not have gotten the pano roof. There is no way to ever totally eliminate this issue, if there was every manufacturer would do the fix and then we consumers would have to ***** about something else. Also glass and aluminum have diferent expansion and contraction points, meaning aliminum will expand and contract at a far diferent rate that glass, so there is really nothng you can do, unless they go back to making aluminum panels and then we would crab about the fact that you can't see through it anymore. Just deal with it or get wrid of the vehicle there is no fix for this problem and most likely never will be in the near future. We need clear aluminum to fix it and I don't see that happening anytime soon. And squeaky roof has nothing to do with quality or quality control. I assume this is your first vehicle with a moonroof so I will give you the benifit of the doubt on this one.
Old Jun 23, 2003 | 10:29 AM
  #183
Jim Banville's Avatar
'06 Lexus GS300 RWD, '07 Camry SE V6 auto, '91 190E 2.6 auto
Go to ANY vehicle brand enthusiast forum and you WILL see complaints of sunroof squeaks.
Old Jun 23, 2003 | 10:30 AM
  #184
avlis's Avatar
2008 VW GTI
Mctwin2kman's post is right on. Minus the sarcasm. Mine was easier and more fun to type though...
Old Jun 23, 2003 | 11:03 AM
  #185
nukblazi's Avatar
I wonder what it would take to repace the fawker with a big CF panel?
hmmmm....
Old Jun 23, 2003 | 11:11 AM
  #186
Yes, I need to work on that one... Less typing is better.
Old Jun 23, 2003 | 11:12 AM
  #187
hmmmm....
I want transparent aluminum darnit.....
Old Jun 23, 2003 | 05:27 PM
  #188
MarkL's Avatar
2002 C240 6-spd (ret)
That's a bit of a generalization, IMO. The moonroof in my '99 VW Passat did not make any rattle or squeaking noises in the 3 years I owned it. Nor does the moonroof on my '02 C240 which is coming up on 2 years in August. I wonder if the panoramic gaskets are different than the sedan roofs, because last time I looked at mine, it was set up differently from most other cars -- the way the gasket surround is designed, without the usual "tray" which catches any water that might make it past the seal. Our new Acura TL, on the other hand, has started squeaking, and I think it is the gasket -- I'm going to try and lubricate it...
Old Jun 23, 2003 | 05:32 PM
  #189
Well, the pano does have a diferent design and is a heck of a lot larger. It is a big hole so I just look forward to the squeaks. Plus that non-moveable rear glass panel, being there can not help. The whole roof is glass except the support beam in the center and the glass all melds together so there is one heck of a seal up there. If designed well the roof should not really squeak until the seal gets dirty, worn and dried. But sometimes they just squeak due to the temperature. As well as the hot to cold to hot again cycles and how wide they swing in temperature. I use mine all the time so it gets a lot of travel. Maybe this person does not use theres and the seals were a little dry.
Old Jun 23, 2003 | 06:22 PM
  #190
Steve H.'s Avatar
2002 C230K Sport Coupe M6 C5 desert silver
This is a 5 min fix. I had the same problem this winter and it was driving me crazy as well. Get some silicone spray from your favorite store (usually a hardware store will carry this stuff). The more silicone the better. Tilt open the window (don't let it slide back). You should be able to see the rubber gasket/seal for the window on the metal support beam in roof (where the shades come out. Spray that gasket/seal fairly heavily with the silicone from outside of the car. Immediately close the window so the mating surface gets coated as well. Then open the sunroof as far as it goes and carefully spray the tracks along the sides. I used a paper towel to screen off any overspray. Close the window. My creaks and groans have been gone now for 3 months.
Old Jun 23, 2003 | 07:02 PM
  #191
Benzer's Avatar
I have had my 03 evo pan coupe for almost a year now and boy oh boy do I wish I had never had the panorama sunroof!!
It has been back to the dealer twice. I don't know what they do to it, but it stops the noise for just a few weeks only.
If it continues, I am seriously thinking of getting rid of it!
GRRRRRRRRRRR
Twice is not bad at all Latent - I am on my 5th next Wedndesday.
Old Jun 23, 2003 | 07:15 PM
  #192
Buellwinkle's Avatar
I've seen complaints about the noisy pano roof as early as July/August 2001 and it kept me from getting the pano roof. Yes, it does look great but I can't tolorate sunroof squeaks and creaks and I can tolerate the heat from the desert sun on my bald head even less, even with the shade. Keep bringing it in to the dealer, eventually they'll figure out a solution. Like Benzer said, twice is nothing, that's how many trips to my dealer an oil change takes.
Old Jun 23, 2003 | 08:31 PM
  #193
columbus's Avatar
'05 c240 4matic wagon
hmmmm....
It'd still squeak, tho'...it's not the glass that does it, it's the frame. But you knew that.
I get your point - it would make it (a lot) lighter. Sounds tempting...
Old Jun 24, 2003 | 12:46 AM
  #194
nukblazi's Avatar
Yeah, I don't care about the skweeking....
I just want to get rid of the extra weight. Back seat is coming out this week. That is a legal wieght reduction. :P
Edit- My pano actually doesn't make any noise. If I haven't opened it in a while, it;ll pop when the gasket if broken free from the glass, that is it. My hatch makes more noise. I also have the hatch carpet, and cover removed. That and my tools are the biggest noise makers. But the bass from the bose sounds better.
Old Jun 24, 2003 | 08:36 AM
  #195
jpb5151's Avatar
Nuk's car by the time he's done with it...
Attached Thumbnails CL203 Coupe Pano-roof Maintenance - MB lube Grease Part #s, gears, & fixes-nuks_car.jpg
Old Jun 24, 2003 | 09:51 AM
  #196
tifosiv122's Avatar
Someone P'Shop an MB symbol on that....
Erik
Old Jun 24, 2003 | 01:09 PM
  #197
nukblazi's Avatar
omfg
Naw, it is going to be a two seater... I need the bolts from the backseats for the harness tie downs. The last x I slammed my knee into the door and actually broke skin. I want to be strapped in from now on. Anyone wanna help me build a roll bar for cheap?
btw, I want to lower it more now but I'll need to grind the end of the sways down more so they don't hit the lower control arm
Hand held wheel grinders rock.
Old Jun 24, 2003 | 10:21 PM
  #198
Outland's Avatar
2002 C230 Coupe(M111)
avlis
No humor please, he's British.
Old Jun 25, 2003 | 01:05 PM
  #199
tommy's Avatar
I hope that you're taking spine compression into account when you're designing whatever Frankenstein harness setup you're going to be doing. You're short enough as is! :p
Old Jun 25, 2003 | 05:30 PM
  #200
nukblazi's Avatar
You b@stard! Yeah, and I figure if I ditch the platforms, I'll have better pedal feel but I'll be gnawing on the steering wheel-
You have already rated this thread Rating: Thread Rating: 12 votes, 5.00 average.
