Plugging in an MP3 player
Old Oct 11, 2002 | 10:54 PM
charlesu's Avatar
C320
Question Plugging in an MP3 player
What is the best way to plug in my portable MP3 player into the stock sound system??
Thanks all.....
Charles
Old Oct 11, 2002 | 10:59 PM
Buellwinkle's Avatar
That's easy, check out this thread on hooking up an Ipod.
http://www.csportcoupe.com/forums/sh...=&threadid=769
Old Oct 11, 2002 | 11:55 PM
charlesu's Avatar
C320
Thanks for the link Bullwinkle.
Is there a way to do this without ripping out the dash?
Old Oct 12, 2002 | 12:11 AM
charlesu's Avatar
C320
I am thinking about simply using a cassette adapter (I know, kinda Mickey Mouse ) but leaving the cassette door open causes the stereo to beep ever 5 seconds does anyone know how to over ride this????
Old Oct 12, 2002 | 03:22 AM
Apollo's Avatar
E320 CDI Elegance auto
Hi, Can you plug the Ipod into the aux in glovebox when you have comand? and are these mac based or can they be connected to pc.
Old Oct 12, 2002 | 11:47 AM
Lynn's Avatar
You shouldn't have any problem using the ipod with the AUX jack. There is an ipod for PC's, but you need Firewire. ipod
Old Oct 12, 2002 | 11:57 AM
Lynn's Avatar
There is a tiny pin type switch on the front of the headunit. Push it in and use a dab of glue or maybe silcone caulk to hold it in.
Old Oct 13, 2002 | 03:53 PM
Apollo's Avatar
Hi
Anyone used the Ipod through the comand aux. Is the quality of sound good, caparable to CD?
Old Oct 13, 2002 | 10:16 PM
SFC320's Avatar
2002 C320
I'm using my iPod (Windows version) through my Aux port. The sound is good, but the bass is missing to some degree. I'm not sure if this is due to the Aux port or the iPod. I still think the convenience of having my entire music collection w/ me on road trips is well worth it. I would still recommend this setup.
Old Oct 13, 2002 | 11:49 PM
peet's Avatar
09 C63
Make sure you get the latest iPod firmware update. It seems, to me at least, that the EQ stuff got turned up a notch in the latest firmware.
If you don't know what I'm talking about - then you're really missing the latest stuff. They added EQ (under settings) as of two updates ago.
Hope this helps!
P.
P.S. I found that dance setting is about the best overall EQ - bass booster muddles the highs.
Old Oct 14, 2002 | 04:35 AM
xc240x's Avatar
2001 C240
those of you using the aux port... exactly what kind of wire are you using, i tried to connect my mp3 player through the aux port with a wire i bought from radio shack... and nothing... and i did select the aux on the comand head unit... pics of the wire and the tips of the wire, would be appreciated, thanx!!!
Old Oct 15, 2002 | 03:15 AM
hphan's Avatar
That's how I have mine set up, but I bought an adapter with a wire thin enough to close the door. It beeped for a bit, but hasn't complained since the first week that I had it set up. I think maybe it gets used to it...
Old Oct 15, 2002 | 06:35 PM
o2bsurreal's Avatar
C230 Sport Coupe
Has anyone ever tried this transmitter from myirock! ? It looks pretty cool but there's always a catch. I found out about it on Apples site of all places.
http://www.myirock.com/players/irock300w.htm
Old Oct 15, 2002 | 07:07 PM
nboyd's Avatar
C230 C-Coupe
"but leaving the cassette door open causes the stereo to beep ever 5 seconds does anyone know how to over ride this???? "
There is an area of the cassette deck, bottom left corner, that is open and the wire will fit without setting off the beep.
Sometimes you have to do again but it fits and you do not need to yank the wire to get the cassette door open.
Since I have the changer I rarely use the cassette & MP3 combo, but when I do it is really easy, once you know where to stick the cable.
Nathan
Old Oct 16, 2002 | 06:03 AM
xc240x's Avatar
2001 C240
can anyone answer my question about the cable they're using for the aux port?!
Old Oct 16, 2002 | 08:28 AM
anthem's Avatar
2007 S
The cable is a standard stereo eighth inch jack.
Ed
Old Oct 16, 2002 | 06:46 PM
todd's Avatar
C230K
Check this thread with my answer:
https://mbworld.org/forums/showthrea...threadid=12021
Also this for general info:
https://mbworld.org/forums/showthrea...0&pagenumber=3
Old Dec 19, 2002 | 07:40 PM
CarlssonPower's Avatar
2002 C240
radio's sound quality is not very good.
