Motor Oil Help
Old Jun 25, 2007 | 09:57 AM
Lsrevhard's Avatar
2005 C240
Motor Oil Help
Hey guys I need a little help so i called mercedes and one person told me i need to put 5w40 oil in another person said 5w30 in it...i want to put royal purpel in my car but they only make it in
0w10
5w20
10w30
is it possible to any of thoose in my car?
Please thanks
Old Jun 25, 2007 | 11:45 AM
Ryanr317's Avatar
R129, XF Sportbrake, SC400
Use 0-40
Old Jun 25, 2007 | 12:23 PM
Lsrevhard's Avatar
2005 C240
does royal purpel make ow40???????
Old Jun 25, 2007 | 12:36 PM
XenonBenz's Avatar
2004.0 C230 Sedan
0w10
5w20
10w30
Please thanks
Royal Purple makes SAE 5W20, SAE 5W30, SAE 5W40, SAE 10W30, SAE 10W40, SAE 15W40, SAE 20W50.
MB recommends Mobil 1 0W40 Euro Formula. 5W40 is probably the closest oil to the recommended 0W40, however I personally wouldn't recommend using the Purple Royal. What's wrong with Mobil 1?
Old Jun 25, 2007 | 01:05 PM
Lsrevhard's Avatar
2005 C240
I personally cant say theres anything wrong, i just herd RP was best now and have seen pictures of what it does so IDK lol but if i decide RP your saying 5w40 is my best bet? and if i were to get M1 to get 0w40...and how many quarts does a MBc240 take my guess is 5 that i have to buy?
Old Jun 25, 2007 | 04:41 PM
aecasasus's Avatar
'04 C230K SS
Almost 6qts.
Old Jun 25, 2007 | 06:07 PM
QQQ's Avatar
QQQ
MY2001 C320
Mobil 1 0W-40.
Old Jun 25, 2007 | 06:15 PM
w203elegance's Avatar
c240 elegance
I wonder why my dealer has been using 5w-50 on my car?
Old Jun 25, 2007 | 06:18 PM
XenonBenz's Avatar
2004.0 C230 Sedan
I know that Royal Purple is a GREAT synthetic oil. I have used it in Honda's that I have owned in the past. The only reason I have reservations on using it in my C Class is that MB engines are much different than your average car. If you do buy RP, I would recommend the 5W40.
The owner's manual recommends 0W40 Mobil 1 European Formula. I personally wouldn't even risk normal 0W40 Mobil 1. The European Formula is different than the Mobil 1 for the US.
Originally Posted by aecasasus
Almost 6qts.
Incorrect. C230's use 5.5-6 qts. C240's and C320's need 8.5 qts.
Old Jun 25, 2007 | 06:35 PM
XenonBenz's Avatar
2004.0 C230 Sedan
There are other oils on MB's approved oil list other than 0W40 weight. The 0W40 is recommended for the average US climate. I noticed that you are in BC, Canada. Your climate is a bit colder than "normal", so the dealer probably is using a different weight oil that is better for the colder conditions where you live.
Old Jun 25, 2007 | 09:12 PM
alymo's Avatar
2001 c240, 65 MG Midget...5.0L V8
well i went to the dealer a while go to ask about changing the oil and they told me they use Penxoil 15w40 which is "mercedes recommended for my car" and that they only use Mobil1 0w40 for AMG cars. well i asked in europe and mobil one is recommeneded for ALL newer mercedes cars, so i guess the dealership is trying to save money. ended up buying the Mobil10w40 and changed it myself. Use Mobil10w40 supersyn, if its good enough for AMG cars its definetley good enough for ours.
Old Jun 25, 2007 | 09:31 PM
Ryanr317's Avatar
Pennzoil?!! I think your dealer may have been smoking that stuff. They recomment Mobil 1 for all of their engines, AMG or not.
Old Jun 25, 2007 | 11:42 PM
QQQ's Avatar
QQQ
MY2001 C320
There is an approved oil list but why not use Mobil 1 0W40?
Old Jun 26, 2007 | 12:12 AM
Lsrevhard's Avatar
2005 C240
i actually bought the ow40 M1 and it took almost 8qts cause i bought 7 and had to go get one more
Old Jun 26, 2007 | 02:47 AM
Stormin's Avatar
'06 SS
I thought that the new C230 2.5L 6cyls were also 7+ Quarts?
Old Jun 26, 2007 | 03:39 AM
Moviela's Avatar
Only Mobil 1 0W-40 that says it meets Mercedes Sheet 229.5 on the container is the only oil you should put in a gas powered C class. It has an additive package that is different than other Mobil 1 synthetics. Mobil has dropped the "European Formula" moniker from the bottle.
Some bottles say Mobil 1 is used by Mercedes and a few other marques. Don't assume that means it can be used in current W203 cars. Look for Sheet 229.5 on he rear label. There are some other brands now listed, but none of the new brands are certified for AMG.
Here is a list for NAFTA vehicles, with thanks to the gentleman who maintains it:
http://www.whnet.com/4x4/oil.html
Old Jun 26, 2007 | 08:19 AM
Poursang's Avatar
Mercedes C180 Sports Coupe
I was wondering, is MB recommending the same type of oil across all regions? I mean, there will be different weather conditions in Greece and eg Canada... They will still recommend the 0-40 type?
Just a thought..
Old Jun 26, 2007 | 09:45 AM
boon4376's Avatar
I find it hard to believe that thicker oil is recommended for a colder climate.
15w40 in a Canadian winter? While im not expert with merc engines yet, I'd be surprised if an average car would start!
Go with a 0w40. the 0w means it will be thin at startup temperature, giving better flow and protection before it heats up. It will act normally like a 40 weight at operating temperature.
Old Jun 26, 2007 | 10:55 AM
aecasasus's Avatar
'04 C230K SS
Sorry...had forgotten was a C240.
Old Jun 26, 2007 | 11:54 AM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
0w10
5w20
10w30
Please thanks
You need to look in your owners manual, as it would have told you everything you need to know. Actually it's a booklet, called MBZ approved lubricant or fluids or something as that in the little black binder.
Geez, I think this was just covered....another thread on oil.
C'mon people.
Old Jun 26, 2007 | 03:14 PM
SeaCoupe's Avatar
2002 C230K, 2013 BMW 328, 2015 BMW X5
C'mon people.
T, don't get your panties in a bunch. Yer just mad that MBKlasse is gone.
The pain will go away.
E
