wheel dilemma ?
Old Jul 1, 2007 | 09:06 PM
rwdforlife's Avatar
wheel dilemma ?
my bro has a set of works sitting around. size is 18x8.5 et41 front with 225/40/18 tires and 18x9.5 et41 rear with 265/35/18 tires. i tryed test fitting them on but it would hit the shock front and rear. i was wondering how much of a spacer should i run so that it would clear the inside wheel well and the outside fender?
Old Jul 1, 2007 | 09:11 PM
B189s's Avatar
1996 MB E320 & 2010 Nissan Elgrand
As low as ET27/28 on the fronts and ET32 on the rears should be fine.GL
Search for AFTERMARKET WHEELS THREAD to make sure
Old Jul 1, 2007 | 10:09 PM
rwdforlife's Avatar
so if i run a 15mm spacer front and 10mm spacer rear i should be good? also how can i tell which size wheels studs to use after i put the spacers on?
Old Jul 5, 2007 | 03:52 AM
sdsilverm3's Avatar
No spacer. Get wheels with some semi-correct offsets. 15mm is a pretty thick spacer.
Old Jul 5, 2007 | 05:13 AM
CoupeCrazy03's Avatar
2003 C230 Kompressor Coupe, 2003 E320, 2003 Chevy Corvette Z06
Those offsets are just wrong for your car, I do not believe spacers would help any. You can run +32 in the front and +38 in the rear with 5mm spacers and it would be pretty flush with the fender.
Old Jul 5, 2007 | 09:01 AM
rwdforlife's Avatar
my bro and i just fitted the wheels with 10mm spacers rear and 15mm front. it clears from hitting the shock and inside fender well. that was my main concern. now that i know 15front and 10rear would work, where is the best place to get spacers? are ebay ones any good? i know i need hubcentric ones. the spacers i used to test fit i just borrowed from my buddy and they are not hubcentric.
