Erratic Climate Control - Advice??
Old Jul 9, 2007 | 05:08 PM
JPCoetzer's Avatar
I hope somebody can assist with this problem - the MB agent just tells me they "cannot find the problem"
I own a 2002 (RHD) C270CDI. The climate control intermittently switches itself off, and even does so again shortly after being switched on manually. At times it does the same between the car being switched off at night and started again the following morning.
Problem is that it is intermittent, but it is getting worse as time goes on, and as the end of the service plan nears ......
Any suggestions?
Old Jul 9, 2007 | 05:26 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
i haven't had that problem...
ask them to replace the climatronic for ya...
hopefully that will fix the problem...
Old Jul 10, 2007 | 03:19 PM
JPCoetzer's Avatar
Thanks - sounds like the expensive option ....
Strange enough, if I give the centre console a bang with the hand on the passenger side, it goes OK for a while - and no, do not ask me how I found that out!
Old Jul 11, 2007 | 07:12 AM
johndddd's Avatar
2023 C300w/AMG package
Any suggestions?
have you read this post:
https://mbworld.org/forums/c-class-w203/118100-strange-ac-problem.html
I changed the Electronic Blower Motor Regulator over the weekend and its fine now. I'm not saying this is your problem, but It could be.
Old Jul 12, 2007 | 04:37 AM
SPORTCOUPE's Avatar
2003-c230K 2001-c230k sportcoupe - 1998 A190 - 2008 Smart Fortwo Brabus
I have a similar problem in my 2003 c230 sedan...
I think it has to do more with the controls on the climatronic console.
I'm looking to buy a replacement (off ebay) probably to check if that's the problem.
Otherwise it may be some vacuum tube issue (I was told by a non-expert)...
