My engine Leaking?? *pics*
Old Jul 13, 2007 | 02:34 PM
KIRA's Avatar
2002 C230 coupe , NOt THE AVATAR!!
yes, i tried STFF but i don't know what these called so i think i might as well post a pics that worth a 1000 words
i don't know what they are and where they lead to, everytime i wipe it, it happened again?? my car hasn't been service for 15000 miles, and service B is coming in 200 more miles, but i want to know what it is before i tell them. any help??
Shot with DSC-T7 at 2007-07-13
Old Jul 13, 2007 | 02:49 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
have no clue...
but y haven't u got ur car serviced for 15k+ miles???
Old Jul 13, 2007 | 03:01 PM
mleskovar's Avatar
'17 Jaguar XF
Looks like crankcase vent line.....common leak/weep point in most cars. Hose clamps at the tube ends helps contain it. As the rubber heats and cools and ages it increases. Also, as cars get older crankcase pressure increases with rings wearing so it leaks more. New rubber and clean vent path helps for a while. Not something to worry about unless it really starts blowing a lot of oil.....and you'll know because of the burned oil smell and drops to floor after the cover fills up.
Old Jul 13, 2007 | 03:33 PM
KIRA's Avatar
hmm this problem start when my car is 3 years old with 25000 miles, now i got 46000 miles on my car now, everytime i wash my car i wipe it but this time i might wanna share it
Old Jul 13, 2007 | 03:41 PM
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Why don't you just unscrew the engine cover and check the color/consistency of the fluid? That will help in determining what the possiblities are.
i'm not that familiar with the m111 and how it was designed.
Old Jul 13, 2007 | 04:25 PM
Blake P's Avatar
'09 A4 S Line
I'm pretty sure that's the plutonium that runs your flux capacitor.
EDIT: I just STFF and found out it requires 1.21 gigawatts of electricity and the M111 is known to use less, which causes the leak.
Old Jul 13, 2007 | 05:23 PM
drexappeal's Avatar
Doc Brown is always around when you need him! How's that train workin' for ya?
Old Jul 13, 2007 | 05:32 PM
SeaCoupe's Avatar
2002 C230K, 2013 BMW 328, 2015 BMW X5
This is no biggie. Its a vent line from your valve cover housing into your intake tract. The intake tract then burns the vented gases.
Try putting a zip tie around the base of the leak, or buy a replacement hose.
When old, the hoses get brittle so don't mess with it until you have a replacement, or you are going to zip tie the base at the valve cover.
E
Old Jul 13, 2007 | 05:42 PM
drexappeal's Avatar
E
Zip-ties FTMFW!...
I knew eventually you would chime in, E. I was going to call you out and have you come in and answer his question, but glad you saw it before I did that...LOL
btw, did you get my pm the other day with the new digits?
Old Jul 13, 2007 | 05:46 PM
Blake P's Avatar
'09 A4 S Line
E
Stop messing with him. You know darn well it's a plutonium leak!
Old Jul 13, 2007 | 05:52 PM
drexappeal's Avatar
And unless he can get the car up to 88 MPH, he's gonna be stuck in the Wild West!
Old Jul 13, 2007 | 05:54 PM
Blake P's Avatar
'09 A4 S Line
See...Drex knows the deal! Ed almost had me with his runaround explanation until he told him to use zip ties. Nobody in their right mind would use those things to hold a hose (or grille for that matter) in place.
Old Jul 13, 2007 | 06:05 PM
drexappeal's Avatar
Zipties are the best for mounting a license plate also!
Old Jul 13, 2007 | 06:11 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
drex is sponsored by 3M...
they fund all his mods...
Old Jul 13, 2007 | 07:01 PM
SeaCoupe's Avatar
Zip-ties FTMFW!...
Yeah, I got your digits. I'm thinking of calling Jose about my Porterfield Pad install, but feel bad about bothering him during work hours.
E
Old Jul 13, 2007 | 07:09 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
josefina's working hours are after hours...
Old Jul 13, 2007 | 07:17 PM
SeaCoupe's Avatar
Yeah, well, likely the only reason I ahve a question is because I have yet to have a Gin and Tonic Today. I'm a much better mech with liquid courage.
Ohhh, Brabus, your hose is P/N S111-018-29-82. You may need to drop the S when ordering. Installs by hand. Cost about $5 bucks.
E
Old Jul 13, 2007 | 07:21 PM
Blake P's Avatar
'09 A4 S Line
E
C'mon Ed, even I changed my own brake pads. I'd expect a grease monkey like you to be able to change the pads with a blindfold on...just how Josefina likes it!
Old Jul 13, 2007 | 07:25 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
i'm impressed B!
Old Jul 13, 2007 | 07:31 PM
Blake P's Avatar
'09 A4 S Line
i'm impressed B!
I followed a DIY, and it helped that the calipers were not on the car at the time. Now that I know how it's done, I'll probably DIY brake pads from now on.
Old Jul 13, 2007 | 07:36 PM
drexappeal's Avatar
LOL...I wish. I'd have more flexible cash to use on mods!
Old Jul 13, 2007 | 07:40 PM
drexappeal's Avatar
i'm impressed B!
Me too!
Old Jul 13, 2007 | 07:41 PM
KIRA's Avatar
E
thx ed for the help
Old Jul 13, 2007 | 07:42 PM
patrick_y's Avatar
2006 E55 and 2002 E320
+1
Definately plutonium leak.
Good luck with the fix.
Old Jul 13, 2007 | 07:48 PM
E4///Turbo's Avatar
Very Slow Mercedes
so you been running 15,000 miles on the oil and want to know why there are oil forming outside your engine?
