Rough cold start
Old Jul 20, 2007 | 08:24 AM
benzoc230k's Avatar
05 C230K SS
Rough cold start
When I start the car cold the needle drops down like it's going to die then comes up and runs fine afterward. No check engine light either. Any clues guys?
Old Jul 20, 2007 | 08:29 AM
diamondblak05's Avatar
Too many to list
On a few occasions during the extreme cold months, mine did the same thing. It would start up but the rpm drops and shakes but remains on. The m271 4-banger is known for rough starts in the morning...do a search. There have been several threads on this topic. If you're still under warranty, have it check by the dealer. Good luck.
Old Jul 21, 2007 | 04:46 PM
benzoc230k's Avatar
05 C230K SS
Thanks. I'll call the dealer about this issue.
Old Oct 21, 2008 | 06:04 PM
Utahkompressor's Avatar
W124, W203, W204, W251
What did the dealer say?
I just bought my 05' and it has the exact same problem as yours when the weather is cold.
And a few week ago, it didn't start...it bumped up to 500rpm and just shuted off by itself.
Old Oct 21, 2008 | 06:19 PM
B189s's Avatar
1996 MB E320 & 2010 Nissan Elgrand
Not sure if my case is the same as yours, but..
I've always got a squeaking cold start especially if I started the engine for the first time in one day. It started to squeak after I didn't drive/start the car for 3 months.
Went to a shop and I was told to spray some WD-40 onto the belt. I haven't done that tho since I think squeaking is almost gone now that I've driven my car prety much everyday
Old Oct 22, 2008 | 10:59 AM
I think that's just a normal superchager noise and I don't think you suppose to put WD-40 on the belt...it's gonna make the superchager lose pressure.
Where is the OP? I still need the answer.
Old Oct 22, 2008 | 11:06 AM
M-bENZ's Avatar
Corrolla
dang where ya live??? is it cold already?? any Snow lately??
Old Oct 22, 2008 | 12:32 PM
Glyn M Ruck's Avatar
Super Moderator
Do not under any circumstances spray WD - 40 on the Poly V belt. It is petroleum based and will damage the belt - ultimately leading to failure. If you have to spray something on the belt then use belt dressing. The same stuff you sprayed on your squeaky old Chev fan belt. It is at least compatible with the rubber, synthetic rubbers etc used to construct the belt.
