CoupeCrazy03 Photoshoot =)
Rating: Thread Rating: 3 votes, 4.33 average.
Old May 14, 2012 | 04:56 PM
  #801
CoupeCrazy03's Avatar
2003 C230 Kompressor Coupe, 2003 E320, 2003 Chevy Corvette Z06
Thanks for the kind words fellas! Tommy, what do you mean by sandwich bagging them?
Old May 14, 2012 | 05:09 PM
  #802
tommy's Avatar
2004 Civic Si. FWD for the Win!
Putting a sandwich baggie (glad, ziplock, whatever your pleasure) or saran wrap around the lugnuts so that the coloring on the edges doesn't come off with repeated use of your wrench. They do get nicked up pretty quickly otherwise.
Old May 14, 2012 | 07:10 PM
  #803
Midnight Koop's Avatar
CL203
Originally Posted by tommy
Looking good - need to get the silver-frosted turn signal bulbs, though.
i think the amber turn signals go well with the yellow fogs and gold theme...
Old May 14, 2012 | 07:39 PM
  #804
tommy's Avatar
Obviously, you're mistaken.
Old May 14, 2012 | 09:27 PM
  #805
Nah i dont plan on doing that. I was pretty carefull when putting them on and it came out fine
Old May 14, 2012 | 09:38 PM
  #806
Yeah im actually diggin the different colors in my headlights
Old May 15, 2012 | 02:38 AM
  #807
TruTaing's Avatar
Moderator Alumni
w203 m112
Looking awesome! What specs are you running on your wheels/tires?
Old May 15, 2012 | 08:51 AM
  #808
Thanks Tru but I could have sworn Ive posted specs before
Front: 18x8.5 et +12, 215/40/18
Rear: 18x10 et +14, 225/40/18
Old May 15, 2012 | 10:24 AM
  #809
tommy's Avatar
Thanks for editing, that response makes more sense. Watch it if you have to take the car to a shop for any reason; impact guns will really do some good damage.
Old May 15, 2012 | 11:43 AM
  #810
TruTaing's Avatar
Moderator Alumni
w203 m112
Ya might have posted them, but I was being lazy to search. Thats quite the stretch on those rear wheels!
Old Sep 17, 2012 | 09:39 PM
  #811
BAM! +9 offset in the rear with the VS-XX
Old Sep 18, 2012 | 08:28 AM
  #812
tommy's Avatar
Those rims wouldn't stand a chance with the way I parallel park.
Old Sep 18, 2012 | 11:33 AM
  #813
TruTaing's Avatar
Moderator Alumni
w203 m112
danggg 18x10 et 9?!?! I love the poke. Looks awesome. Could ya get lower up front? :x
Old Sep 19, 2012 | 01:06 AM
  #814
I want to see how much lower it would go if I were to take out the lock ring
Old Nov 8, 2012 | 11:26 AM
  #815
C350_Coupe's Avatar
C350 Coupe (CL203)
nah, don't like that look ..... lokos like you already got a puncture lol
not a fan of stretched tyres, that said the 255's now on my brabus 9.5" rears and the 225's on 8.5" art the front do look a little stretched, but i just can't get away with 265 and 235, would rub like crazy
Old Nov 8, 2012 | 02:23 PM
  #816
lepez's Avatar
CLS320cdi, GL350BT, ML270cdi
that look's awesome !! I'd really like to see more pictures of your current stance.
definitely the best looking coupe on the forums.
Old Feb 4, 2013 | 09:16 PM
  #817
Thanks for the kind words sir. . . its been a while and I have to say I still love my car
Here are some more recent pics of what she looks like today from last years Socal Euro event here in San Diego.
Well besides with the update on the car. . . I follow up with an inquiry I think ill be trading my AMG wheels for some CLS wheels but I need some tire size suggestions. I want to run a "proper" setup this time so I can just daily mash around the streets of SD. I was thinking 225/30/18 in the front and 255/35/18 in the rear. . . thoughts? Suggestions?
Old Feb 5, 2013 | 07:48 AM
  #818
C350_Coupe's Avatar
C350 Coupe (CL203)
225's in the front will be ok, be careful going bigger, or less offset, i found while experimenting with mine that on 8.5" Rims i needed spacers not to clear the caliper, but to clear my suspension strutt, and in doing that it pushed the edges of the tire close to the front and back of the inner arch when on full lock, had i gone to 235's on the same profile it would have likely rubbed because the track is effectively wider for the same pivot point of the steering.
Also, you got your profiles backwards - fronts should be 35 rears 30 on that size if your looking to return to stock kind of setup.
255's in the rear are fine, and i don't think i need to tell you where to watch for rubbin'
Rim width depends on the look you like, u like that stretched look, i dont, but if your looking to stray away from that, then 9.5 on the rear and 8.5 up the front gives a little stretch, stock is 7.5 and 8.5, those are pretty good, or 8's and 9's would also give the stock look
Old Feb 5, 2013 | 12:20 PM
  #819
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
225/40/18 and 255/35/18 would be the right size.
or you can run 235/40/18 265/35/18 if you want to raise the car up a little.
Old Feb 5, 2013 | 01:08 PM
  #820
Thanks guys, profile suggestions duly noted. Im probably going to go with 225 and 255. I still want to remain at the relatively same height. When its all done I will update with pics. I will most likely paint them black since I'm all over the murdered look at the moment. Thanks again
Old Feb 5, 2013 | 04:04 PM
  #821
phister's Avatar
06 C230 SS 6spd
looking good man... how come my stretch looks more than yours in the rear but I'm running 245/40 on the rear. maybe its just the angle lol... I'm aiming for wider wheels instead of lower offset now... going to order 3.5" lips in the rear so I'll be at 18x10.5 in back.
You should do mag blue for the wheels instead of black.
Old Feb 5, 2013 | 06:25 PM
  #822
tommy's Avatar
Be careful, young jedi - the murdered out look gets very old and very boring very quickly. Can't wait to powdercoat my RPF1s next month for the crx.
Old Feb 7, 2013 | 04:00 PM
  #823
C350_Coupe's Avatar
C350 Coupe (CL203)
here's mine on the brabus rims....
Sorry for the crap photo's i don't have any others right now, of these three there is really only th first one that i like that gives you some idea of the way they fill out the arches, obviously i am at stock hieght so looks like i have lots of gap The fronts stick out from the arches a lot more than is visible in those shots, but it's not too far to cause a problem.
And those 255's on the back look really good from the rear
Old Feb 11, 2013 | 12:10 AM
  #824
JDM_love's Avatar
2002 Miata
Heres a pic of white RPF1s on my bros rsx! (I sold the rsx to him)
Old Feb 18, 2013 | 04:08 PM
  #825
Alright nix the CLS wheels, the deal fell through so Im just gonna get new tires for the AMG Style 3's. Quick question though, I am currently running 225/45/17 in the front and 245/40/17 in the rear. Can I/should I size up at all in the rear to a 255/40/17? Granted that the rears are 8.5 inches wide. . . is there any benefit to running 255 as opposed to 245? Oh what do any of you guys have any experience with Hankook Ventus V12's at all? If so how did you like them and how long did they last?
You have already rated this thread Rating: Thread Rating: 3 votes, 4.33 average.
