Washer resevoir
Old Aug 14, 2007 | 01:17 PM
Rick's Avatar
C230K Coupe/Orion/C4/C5/CD/AMG Spoiler/V60/TeleAid, 2 MGB's
Washer resevoir
Ok...so I was out of washer fluid fluid...the multi-function display said so.
So I open the hood, pop the lid and start adding fluid..and it comes pouring out of the bottom of the bumper. I take the 4 clips and the two screws out to remove the splash guard below the bumper, and reach up behind the resevoir....there's a 6 mm hole that looks like something should fit into it.
The sensor is attached, the hoses for the windsheild and headlamp washers are intact and connected. Am I missing something.... or is there a rubber plug that fits in it?
Old Aug 14, 2007 | 01:45 PM
tommy's Avatar
2004 Civic Si. FWD for the Win!
If my car were working right now, I'd take a look.
Logically, a drain plug that came off sounds like a definite possibility.
Old Aug 14, 2007 | 02:57 PM
romz's Avatar
2001 C240
it is a rubber washer that should be there. I had the same problem but like you I did not investigate the problem instead I assumed there was a crack and I bought another reservoir and now I have a spare one.
Old Aug 14, 2007 | 04:39 PM
Rick's Avatar
Dealer parts guy insisted that it's the "rear washer connection grommet" but failed to find a part number. All he could locate was a part number for the rear washer connector hose...$23.87
I'm guessing that's for the wagon.
So a $0.19 cent part at Pep-Boys fixed it.
Old Sep 4, 2007 | 01:11 PM
numba41's Avatar
CLK 320, C32 AMG
Do you have the part description from Pep Boys? Saves having to dismantle the splash guard twice. Thanks.
Old Sep 4, 2007 | 07:41 PM
Rick's Avatar
The piece I used was a cone shaped rubber plug from PepBoys. Thy have sets of plugs like this in generic blister packs marked H.E.L.P. - 10 assorted plugs for $1.89.
Old Sep 4, 2007 | 11:01 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Nice work on that DIY repair. When I'm faced with no alternative, I'll go to Pep Boys to get lubricants and other consumables for my worktruck. When I needed a transmission pan gasket for the GMC, they couldn't ensure I'd receive the right part unless I could confirm it had A/C and cruise. LOL!
Mention M-B to the guy at the parts counter and he'll somehow become even less engaged. H.E.L.P parts FTW!
